Is Newton's third law getting violated here?
The discussion revolves around the implications of Newton's third law in the context of electromagnetic interactions, particularly when charges are in motion relative to one another. Participants explore whether the presence of magnetic forces and the momentum carried by electromagnetic fields constitutes a violation of Newton's third law, addressing both theoretical and conceptual aspects of the topic.
  • Some participants suggest that when one charge moves towards another at rest, the electrostatic forces are equal, but only one charge exerts a magnetic force, potentially violating Newton's third law.
  • Others argue that the electromagnetic field carries momentum, and accounting for this can resolve the apparent violation of conservation of momentum.
  • It is proposed that if Newton's third law is generalized to include momentum transferred to fields, then it does not represent a violation.
  • Questions arise about how momentum is transferred to fields, with references to electromagnetic waves and the mathematical derivation of such phenomena.
  • Some participants note that even stationary charges can exhibit momentum interactions, emphasizing the role of the electromagnetic field in these scenarios.
  • There is a discussion about the necessity of invoking field momentum in electrostatics, with some asserting that it is not needed until charges are in motion.
  • Participants reference the Maxwell stress tensor and its relevance in calculating forces between charged particles, indicating that it provides insight into how the electromagnetic field carries momentum and energy.
  • One participant cites a source that suggests the third law does not always hold, emphasizing the primacy of momentum conservation in modern physics.
  • There are repeated inquiries about the implications of electromagnetic radiation and its associated momentum in the context of moving charges.
The discussion remains unresolved, with multiple competing views on whether Newton's third law is violated in the presence of electromagnetic interactions. Participants express differing opinions on the necessity of considering field momentum and the implications of stationary versus moving charges.
Limitations include the complexity of mathematical derivations related to momentum transfer in electromagnetic fields and the varying interpretations of Newton's third law in different physical contexts.
KnightTheConqueror
Suppose a charge is moving towards another charge at rest. At a given instant of time, The electrostatic force applied by either charge on the other is same, but only one is applying magnetic force on the other. Doesn't this violate Newton's third law?
The electromagnetic field can carry momentum, and in general you need to account for that too. If you do that correctly (which is often non-trivial maths) the conservation of momentum holds.
So, if you limit Newton’s 3 rd law to only refer to forces on matter, yes, this is a violation. If you generalize N3 to include momentum transferred to fields then it is not a violation.
How exactly is momentum transferred to fields? I know electromagnetic waves carry momentum, but in this situation I don't understand what exactly is happening. Is something sort of wave being created? If yes then how to we mathematically derive the wave
The momentum density of the EM field is given by $$\frac{\vec S}{c^2}=\frac{1}{c^2}\vec E \times \vec H$$ The field doesn’t need to be a wave.
"The point is that the third law does not always hold, and this is why modern physics has given primacy to conservation of momentum in the hierarchy of physical law."
-- Arnold B. Arons, Teaching Introductory Physics, 1997, John Wiley & Sons
Coincidentally, this is the topic of the lecture I will give in my special relativity class today.
Ultimately, just considering local conservation of energy and momentum means you really cannot have action at a distance compatible with special relativity as it would violate causality. Any force produced between two charged particles must be mediated by the electromagnetic field carrying momentum and energy. In particular, the Poynting vector
represents the momentum density of the field, but also the energy current. The Maxwell stress tensor represents the momentum current.
Integrating the currents over a closed surface will give the total energy/momentum flowing out of (or into depending on normal direction) the enclosed volume. All forces become local and causality is fine again. We also obtain the relativistic analogy of Newton’s third law, ##\partial_\mu T^{\mu\nu}_{\rm tot} = 0##.
The two charges are accelerating so I expect to see EM radiation, which has momentum.
That's not the fundamental issue. You could have a fixed charge and a steady current in a wire.
Or just some stationary charges. Even if momentum density in the field is zero, the momentum current will not be. Computing the force between two charged particles by integrating the Maxwell stress tensor across a plane in between them is an exercise in my relativity lecture notes. Obviously the result comes out to the expected Coulomb law, but it is instructive for working with the Maxwell tensor and for getting a feeling for how the EM field carries momentum and energy.
Well, if you only have stationary charges then there isn’t a concern about the momentum of the charges. The forces on two stationary charges does follow N3.
Sure there is a concern about the momentum. There are additional forces acting on the charges to keep them from moving (there must be or they would accelerate). Those forces by themselves represent momentum being added to the charges and exactly balance out the momentum added by the field interaction. No, these effects are not a Newton 3 pair, but the forces on the charges from the field and the force on the field from the charge are.
Newtonian mechanics doesn’t forbid action at a distance. So because the electrostatic forces are equal and opposite there is no need to invoke field momentum or momentum flux in electrostatics. Yes, it is there in electromagnetism, but it isn’t necessary for the conservation of momentum until one of the charges is moving.
Electrostatics is a limit of electromagnetism and in electromagnetism the fields do need to be assigned momentum and energy. If you compute the corresponding stress-energy of the fields, it is non-zero. Hence, there is a computable energy and stress also in electrostatics. You may not need it for the static situation, but it is perfectly compatible with it.
Yes. I agree completely. And the field momentum flux is only not needed for the static situation in the sense that Newtons laws don’t break without it.
I recommend to take a look at Feynman's discussion-10.5 about conservation of momentum in case of electromagnetic field.
  • · Replies 16 ·
  • · Replies 20 ·
