Is Newton's Third Law Violated in Electromagnetism?
This discussion addresses the validity of Newton's Third Law in the context of electromagnetism. It concludes that while Newton's Third Law holds true for contact forces, it does not apply to long-range electromagnetic interactions where momentum can be carried by the electromagnetic field. The conversation highlights that the instantaneous momentum transfer assumed by Newton's Third Law is not applicable in these scenarios, thus suggesting a violation of the law in the context of electromagnetic forces. The discussion also references Griffiths' perspective on formulating classical electrodynamics as an action-at-a-distance theory.
  • Understanding of Newton's Laws of Motion
  • Basic principles of electromagnetism
  • Familiarity with electromagnetic fields and forces
  • Knowledge of classical electrodynamics
  • Research the implications of electromagnetic fields on momentum conservation
  • Explore Griffiths' formulation of classical electrodynamics
  • Study the differences between contact forces and long-range forces
  • Investigate action-at-a-distance theories in physics
Physicists, students of classical mechanics, and anyone interested in the foundational principles of electromagnetism and their implications on classical laws of motion.
loom91
Hi,
I was wondering, is Newton's third law true? Let's say I've an electromagnet turned on at a constant intensity for a sufficiently long time for the field to have reached a point some distance away. At that point is another electromagnet, but turned off. Now I turn on the second electromagnet. Immediately it's attracted to the first electromagnet. But before the field created by the second magnet can reach the first electromagnet, I turn it off. So when the magnetic field of the second magnet finally reaches the first electromagnet, it's not a magnetic dipole anymore and thus won't feel a force. The overall case is that there is no balancing parter to the force felt by the second electromagnet. This seems to be a violation of Newton's third law. What is happening here?
Thanks.
Molu
Newton's 3.law is true for contact forces.
For long-range acting forces like the electro-magnetic ones, some of a system's momentum (lost from one of the object) may be carried by the electromagnetic field, rather than being instantly swapped over to the other object of the system (i.e, the instant swapping of momentum pieces between a system's objects is the essence of Newton's 3.law).
This violates Newton's 3.law, but retains momentum conservation for the system as a whole.
Newton's third law is only valid for contact forces; the law assumes instantaneous changes in momentum.
Edit: Arildno got there first... :redface:
So, when the momentum imparted to the second magnet has a counterpart, but instead of being on an object it is being carried away by the propagating field?
Incidentally, Griffiths writes that it's possible to formulate classical electrodynamics as an action at a distance theory rather than a field theory. How would that work?
Thanks.
Molu
  • · Replies 40 ·
14K
