Trollfaz
- Messages
- 144
- Reaction score
- 16
I have heard that the probability of an unstable nucleus decaying is always constant. Is there any way to change this probability?
Electron capture is called "decay", and the suppression of a decay via adding electrons is changing the decay as well.ORF said:A decay is spontaneous, and initially there is only the nucleus which is going to decay. If initially there was more than one nucleus, it's called "reaction" instead of "decay".
vanhees71 said:There's an extreme example of astrophysical relevance: A ##^{187}\text{Re}##
How else would you call it?ORF said:So, if you don't have external fields (or are negligible), and the nucleus is not affected by the chemical potential of electrons or other external particles, can the change of the nuclear statebe called "spontaneous decay"?
Thanks for finding this. It's pretty much exactly what I had in mind, up to and including applications to nuclear waste mitigation, except the author considers (far more relevant and feasible) electrons rather than muonic atoms.ORF said:@TeethWitener: it's an interesting question. I just found this,
https://arxiv.org/pdf/1509.09106.pdf
mfb said:I don't think it helps to spend too much time on defining words. Just use something that is clear.
That sounds quite trivial.ORF said:If this items are the same, the probability will be the same. If something changes, the probability changes.
