Is the angular span of a body executing s.h.m always 2.pi?
6 replies · 3K views
mmainak
a wall is inclined to an angle "a" to the horizontal plane. a pendulum of length "l" attached to the wall making an angle "b" with the horizontal (a >b)is let to oscillate. Collision between the bob and the wall is perfectly elastic.show that the time period of the oscillation is 2.sqrt{l/g}.{pi/2 + sin[-1](b/a)}.
In solving this problem i have found that all other terms are same for a pendulum in normal condition except in place of 2.pi there is 2.{pi/2 + sin[-1](b/a)}.So my question is what is the basis that we generally take the angular span of s.h.m to be 2 pi? Can there be any exception ?
I tried to solve the problem following way.
from it's hanging point to the mean position it goes an angular distance pi/2.
from mean position to the angle a it goes an angular distance sin[-1](b/a), i can prove it as following.
if the angular distance is theta then
[l.sin a].sin theta = l.sin b
taking a,b small,
sin theta = l.b/l.a
hence, theta = sin[-1](b/a)
So effective angular span =2.{pi/2 + sin[-1](b/a)}
so time period = 2.sqrt{l/g}.{pi/2 + sin[-1](b/a)}.
Please tell me whether I am right in my concept or not.
Simple harmonic oscillators execute sinusoidal oscillations, by definition. (That's why they're called "harmonic") The period of the sine function is 2π, so yes, a true SHO will always go through a rotation of 2π per cycle in "parameter space". What you have here is not a true SHO, though - it's more like a truncated SHO.
There are a couple of things I don't understand about your proof, though (maybe I'm just missing something obvious): how exactly do you get this equation?
[tex]l\sin a \sin\theta = l\sin b[/tex]
Also, how can you assume that a and b are small? Those are angles from the horizontal axis, but in order to treat a pendulum as an SHO, it must stay close to the vertical axis.
If you have a diagram you can post, I'm sure that would be helpful.
Here I have uploaded two diagram of this problem. here I have approximated a,b being small
r= l.a
r sin[tex]\vartheta[/tex]=l.b
hence [tex]\vartheta[/tex] =sin -1b/a
well I also feel that I have over-approxiamted this problem . Is there any other way I can proceed?
Your two diagrams are inconsistent - in diagram 1, the angles are defined relative to the horizontal axis (as in the problem statement), but in diagram 2, they're defined relative to the vertical axis. Which is it?
yes that was mistaken . sorry
dia 1 is the original one given in the problem
instead of l.a it should be l.(pi/2 -a)
but that will not make the answer. how can i proceed then ?
Honestly, I can't figure out how to get the answer you're supposed to get. Perhaps someone else can come along and offer a second opinion.
The expression you're asked to derive is incorrect. When the wall is vertical, the period of oscillation should be half the usual period, i.e. [tex]T=\pi\sqrt{l/g}[/tex]. That doesn't match what the expression predicts.
