Is the converse of this theorem true or not?
  • Thread starter Thread starter Byeonggon Lee
    Theorem
The discussion centers on the converse of a theorem from Stewart's Calculus (11.1.6), which states that if $$ \lim_{n\to\infty} |a_n| = 0$$, then $$\lim_{n\to\infty} a_n = 0$$. Participants debate whether the converse, $$ \lim_{n\to\infty} a_n = 0 \Longrightarrow \lim_{n\to\infty} |a_n| = 0$$, holds true. It is established that the convergence of $$a_n$$ to zero and the convergence of $$|a_n|$$ to zero are equivalent, particularly when using the epsilon-delta definition of limits. Additionally, the discussion highlights that absolute convergence in a normed vector space implies convergence only if completeness is satisfied.
  • Understanding of limits in calculus, specifically epsilon-delta definitions.
  • Familiarity with sequences and their convergence properties.
  • Knowledge of absolute values and their implications in real analysis.
  • Concept of completeness in metric spaces, particularly in relation to normed vector spaces.
  • Study the epsilon-delta definition of limits in detail.
  • Explore the concept of completeness in metric spaces and its implications for convergence.
  • Review the theorem on absolute convergence in normed vector spaces.
  • Read "Advanced Calculus" by Loomis and Sternberg, focusing on Theorem 7.11 and Exercise 7.19.
Mathematicians, calculus students, and educators interested in the nuances of limit theorems and convergence properties in real analysis.
Byeonggon Lee
Is converse of this theorem true or not?
$$\lim_{n\to\infty} a_n$$
This theorem is from the stewart calculus book 11.1.6
If $$ \lim_{n\to\infty} |a_n| = 0$$, then $$\lim_{n\to\infty} a_n = 0$$
I wonder whether converse of this theorem true or not
I would say yes.
In fact, that looks more like a definition for "limit" as it applies to complex numbers than it does as a theorem.
Byeonggon Lee said:
Problem Statement: Is inverse of this theorem true or not?
Relevant Equations: $$\lim_{n\to\infty} a_n$$
I wonder whether inverse of this theorem true or not
I think "converse" is the correct terminology.
Can you prove it?
What if the limit is non zero?
Yes you're right. I edited the post.
converse of the theorem:
I tried to prove it by using contrapositive
contrapositive of the converse:
$$ \lim_{n\to\infty} a_n \neq 0 \Longrightarrow \lim_{n\to\infty} |a_n| \neq 0$$
I think if $$ \lim_{n\to\infty} a_n = c$$ $$ (c \neq 0) $$
this will be also true by limit laws for sequences:
$$ \lim_{n\to\infty} |a_n| = |c|$$ $$ (c \neq 0) $$
But I don't know what to do when
$$ \lim_{n\to\infty} a_n = \infty $$
$$ \lim_{n\to\infty} |a_n| = c$$ $$ (c \neq 0) $$
You need to be careful. First, the negation of the statement that ##a_n## converges to ##0## is that it does not converge to ##0##. This includes cases where the limit does not exist.
What you have for the contrapositive of the converse is not right, therefore.
But, in any case, you should be able to prove directly that the convergence of ##a_n## to ##0## and the convergence of ##|a_n|## to ##0## are equivalent. Just use the definition of the limit.
You also need to be more careful if the limit is nonzero and should look at the problem carefully.
Note that in this case the convergence of the sequence and the convergence of the absolute value are not equivalent.
The same goes for sequences that diverge to ##\pm \infty##.
If ##|a_n - 0| < \epsilon##, then also ##||a_n |-0|<\epsilon##, and the other way around. It's just about taking absolute value one or two times.
Trivially true using epsilon- definition. Use that ##||x||=|x|##.
Thanks. Definitely better to use the definition than contrapositive.
the fact that the absolute value is continuous implies the converse is true. More interesting is the fact that the theorem itself is not always true. I.e. the absolute values lie in the real numbers which is a complete field, but the original points may lie in a non complete space, hence the absolute values may converge in the reals, without the original points themselves converging in the original space. E.g. let the original space be the rationals. Then one can have the absolute values of a sequence of rationals converging in the reals to an irrational number, whence the original points do not converge in the rationals. In general absolute convergence of a sequence of points of a normed vector space implies convergence of the sequence itself if and only if cauchy convergence implies convergence, i.e. completeness holds. I hope this is correct; it has been over 50 years since I learned this from Lynn Loomis, but it is pretty firm in memory.
a reference is Advanced Calculus by Loomis and Sternberg, Theorem 7.11 page 221, and exercise 7.19, p. 223.
  • · Replies 34 ·
