Is the Electric Field Always Conservative?
  • Level: Undergrad
  • Thread starter Identity
    Field
3 replies · 19K views · last reply
Identity
How can you prove that the electric field is conservative? I've learned about stuff like line integrals but I'm not sure how to prove this particular fact.
Thanks
A conservative vector field has the property that the line integral of the vector field is independent of the path and depends only on the end points. This implies that the line integral of the vector field around a closed path is equal to zero. An equivalent property is that the curl of a conservative vector field is equal to zero. Also, the curl of the gradient of a scalar function is equal to zero. The electric field can be expressed as te gradient of a scalar electric potential.
There are enough different ways hinted at in the above paragraph that I'm sure you can easily prove that the electric field is conservative.
Just want to point out that only an electrostatic field is conservative. The electric field induced by a changing magnetic field isn't.
Thanks
If you want to prove experimentally that some electric field is conservative, you can place a closed contour of electric wire, with an in-line ammeter, in the field. If no current flows regardless of the orientation of the wire, then you are dealing with a conservative field. If current does flow, then for selected orientations there is a non-zero emf around the contour and the field is not conservative.
