Is the Expanding Universe Slowing Down According to Age?
The discussion centers on the misconception regarding the expansion of the universe and its relationship with the age of distant galaxies. It is established that while farther objects appear to recede faster due to the expansion of space, this does not imply that the universe is slowing down. The Hubble constant is used to measure the expansion rate, which is proportional to the distance of galaxies from a chosen origin. The universe's expansion is actually accelerating, and the perception of older galaxies moving slower is a result of observing them at an earlier time, not an indication of a deceleration in expansion.
  • Understanding of the Hubble constant and its implications for cosmic expansion
  • Familiarity with concepts of isotropy and homogeneity in cosmology
  • Knowledge of the finite speed of light and its effect on astronomical observations
  • Basic principles of general relativity and cosmic inflation
  • Research the implications of the Hubble constant on cosmic expansion rates
  • Learn about the concept of cosmic inflation and its role in the universe's expansion
  • Study the effects of redshift on the observation of distant galaxies
  • Explore the relationship between dark energy and the acceleration of the universe's expansion
Astronomers, astrophysicists, and students of cosmology seeking to understand the dynamics of the universe's expansion and the implications of observing distant celestial objects.
meatym
i've seen many documentaries. most recently nova had one on the expanding universe which prompted me to send them (nova@wgbh.org) the following:
based on the nova shows I've seen, they suggest the universe is expanding.
farther objects are observed as moving away faster than closer objects.
but the farther objects are also older, so according to age, wouldn't that mean that the universe is slowing down?
also, are all objects at a similar distance moving away at a similar speed?
they sent a response that said they forwarded to their producers, but in the meanwhile, i thought i'd look elsewhere...
thanks in advance for any responses.
Astronomy news on Phys.org
Farther objects are older to US because we can only observe them as they were in the past depending on how long light from that object took to get to us. But if you take a constant slice of time at any instant and analyze the observable universe (this is all mathematically) all objects, and I mean at the large where isotropy and homogeneity are preserved, are of course the same distance in time from t = 0. The rate at which objects recede from whatever you pick to be the origin (since you do have that freedom) is directly proportional to the distance between the object and your chosen origin. Objects all at the same distance from "the origin" will recede at the same rate.
The answer to your last question is yes. The Hubble constant which is used to measure the expansion of the universe is based on an expansion speed per distance from us.
So, picture the universe expanding uniformly in all directions. So, the further away a particular object (e.g., galaxy) is, the more expanding space there is between you and it. So it appears to be moving away faster than something which is closer.
And due to the finite speed of light, the older it appears to us (not actually older...it's just that we're seeing it's past because light from its present state has not reached us yet).
So, the ancient galaxies we're seeing at great distances are not causing the universe to slow down. But since the universe expansion is actually accelerating, I suppose we're seeing those ancient galaxies from a time when the universe was expanding at a slower rate.
Clear as mud?
Clear as mud?
but since we are seeing the galaxies as they were a long time ago - the further away, the further back into the past - and the older the image, the faster it is moving...
that would imply to me that the galaxy's age is inversely proportionate to it's speed.
the newer the image, the slower it is moving. wouldn't that mean that things are slowing down as time goes on?
thanks for answering the other quetion, btw
  • · Replies 97 ·
13K
  • · Replies 32 ·
