Is the Function y=x^3 Monotonic at x=0?
  • Thread starter Thread starter player1_1_1
    Function
6 replies · 3K views
player1_1_1
[tex]y=x^3[/tex] is it monotonic in 0?
if i try to solve [tex]y'>0[/tex] it will be 0 in point [tex]x=0[/tex] so that function is not strictly decreasing in 0 but in other way we have [tex]x_1<x_2\Rightarrow f(x_1)<f(x_2)[/tex] so it is scrictly decreasing, its paradox, why?
Why is y' = 0 not allowed for a stricly increasing function?
Isn't [tex]x_1 < x_2 \implies f(x_1) \le f(x_2)[/tex] the definition of monotonic (or strictly monotonic, if you replace the equality by a strict equality)?
Plug in a value before 0 and after 0 in [tex]y'=3x^2[/tex]. You'll see that y' is strictly positive for all real values except 0, where the slope is zero. So it follows that this is neither a minimum nor maximum, and 0 is the only point that has slope zero. We also know that y is a continuous function, so y must be strictly increasing, i.e. monotone.
so generally if [tex]x_0[/tex] is isolated point where derivative is 0 and its positive around this function can be strictly monotonic there yeah? and what about this theorem what i found? if function is scrictly monotonic in every point then function then inverse function has derivative in any point, but function [tex]y=\sqrt[3]{x}[/tex] doesn't have derivative in 0, why?
Because the derivative of the function is not defined at x=0. The best you can hope for is a limit.
Either you have misunderstood something about the statement of the theorem, or it is just wrong.
Counter example:
f(x) = -1 + x when x < 0
f(x) = 0 when x = 0
f(x) = 1 + x when x > 0
f(x) is strictly increasing, but you can't even define a limit of f^-1(0), let alone a derivative, because f^-1(x) is not defined when -1 < x < 0 and 0 < x < 1
[itex]a^3- b^3= (a- b)(a^2+ ab+ b^2)= (a- b)((a^2+ ab+ b^2/4)+ (3/4)b^2)= (a-b)((a+b/2)^2+ 3/4 b^2)[/itex]
Since [itex]a^2+ ab+ b^2[/itex] is the sum of two squares it is never negative and [itex]a^3- b^3[/itex] is positive if and only if a- b is.
