Is the Given Answer for the Classical Mechanics Problem on Earth Correct?
3 replies · 1K views · last reply
WMDhamnekar
MHB
Text-only forum post with a multiple-choice question: planet mass 6 × 10^24 kg, angular velocity 7 × 10^-5 rad/s, options 4.4 × 10^4 m, 4.4 × 10^7 m, 4.4 × 10^10 m, 4.4 × 10^13 m.
We are given the angular velocity $\omega = 7\cdot 10^{-5}\,rad/s$ and the mass $M=6\cdot 10^{24}\,kg$.
To achieve a free fall of $0\,m/s^2$ at radius $r$ we need that the centripetal acceleration is equal to the acceleration due to gravity,
Note that $v=\omega r$, so the centripetal acceleration is $\frac{v^2}{r}=\omega^2 r$.
The acceleration due to gravity is $\frac{GM}{r^2}$, where $G=6.67\cdot 10^{-11}$ is the gravitational constant (leaving out the unit while assuming SI units).
So:
$$\omega^2 r = \frac{GM}{r^2}$$
Solve for $r$.
So:
Solve for $r$.
Hi,
So, we get $r^3 =8.172587755e22m^3/rad^2$ So,$r=43396349.43332m/\sqrt[3]{rad^2}$. Is this answer correct?
Dhamnekar Winod said:
Hi,
I get the same answer.
Do note that $rad$ is not an actual physical unit, but it's a ratio. When we multiply the angular velocity (rad/s) with the radius (m), the rad unit is effectively eliminated and we get m/s.
So properly we have $r=4.3\cdot 10^7\,m$.
It means that answer 2 should be the correct answer.
Admittedly it's a bit strange that it is given as $4.4\cdot 10^7\,m$ instead of $4.3\cdot 10^7\,m$.
Since we're talking about earth, perhaps they used a mass and angular velocity with a higher precision than the ones given in the problem statement.
EDIT: Hmm... in that case we would actually get $r=4.2\cdot 10^7\,m$, so that can't be it after all.
