Is the intersection of two open sets always open?
  • Context: Undergrad
  • Thread starter Thread starter tburnum
    Intersection Sets
24 replies · 18K views
tburnum
[SOLVED] intersection of two open sets
does anyone know how to prove the intersection of two open sets is open?
lol
There's nothing to prove about it. The axioms of a topological space (topology over a set) claim that the intersection of an arbitrary but finite # of open sets is open.
One presumes the OP is talking about the usual notion of open and closed in R. There is something to prove then if one wishes to show this is actually a model of the axioms of a topological space, dexter.
But, this does show the place to start is with the OPs definition of open (or for that matter, in what space are we even talking? R, R^n?)
the open sets are in R, but i need to prove that the intersection of just two open sets is open. once i have that, proving the intersection of a finite number of open sets is easy. I'm trying to use an open ball in the proof.
i'm at a loss.
Let's look at the problem. Let's take (a,b) and (c,d) as the open intervals. What is the intersection of those two sets? There are only a few cases to consider - they're disjoint, one is a subset of the other, and they overlap.
If you want to be fancier, and allow for arbitrary open sets, then what does it mean for X to be open? It means for each x in X there is an e depending on x such that (x-e,x+e) is wholly contained in X. Now suppose that x is in the intersection of X and Y. That means what? That there is an e such that (x-e,x+e) lies wholly in X, and a d so that (x-d,x+d) lies wholly in Y. Can you now see how to find an f so that (x-f,x+f) lies wholly in X and wholly in Y (i.e. in the intersection thus proving that the intersection is open)?
i have been able to prove that there is an e such that (x-e,x+e) is wholly in X and there is an f such that (y-f,y+f) is wholly in Y, I'm having a problem proving that there exists a g such that (z-g,z+g) exists only in the intersection of X and Y. i can't figure out what g should equal to make sure that the it stays in the intersection.
You can't? Well, what if I said x=0 which I may as well do. Then what if e=1 and g=2? Can you really not think of an open interval contained in both (-1,1) and (-2,2)?
And why do you have x,y, and z? You only have to suppose you are looking at one point x lying in both X and Y.
i am having a major brain fart. ok, so if I'm only looking at one point x that is an element of the intersection of X and Y, and e>0.
then the i have to consider the cases:
x is an element in X or x is an element in Y and they do not over lap, then the intersection is obviously open because the intersection is the empy set
so the case i need is when X n Y does not equal the empty set.
got it and i know how to prove an open ball is a subset of X n Y, i just can't figure out what i need my e=?
If x is in open set A, there exist [itex]\delta_1> 0[/itex] such that [itex](x-\delta_1,x+\delta_1)[/itex] is a subset of A. If x is in open set B, thre exist exist [itex]\delta_2> 0[/itex] such that [itex](x-\delta_2,x+\delta_2)[/itex] is a subset of B. Now, how can you find a [itex]\delta> 0[/itex] so that both of those are true?
i'm trying to use the definition of intersection in my proof, but i can't seem to get it right. i can prove the x is an element in X or Y, but it's the and that's tripping me up.
i have to prove it for any X and Y. i has to be abstract, all theory. which my prof told me i have to follow the logic and I'm stuck.
You'll never get to abstract logic if you cannot solve a simple, concrete example.
If you want to be unstuck I suggest you try to work through a simple example like the one above.
it's the number line with shaded between -1 and 1 with circles at the end to indicate that the end points are not included in the set
i'm thinking more of a Venn Diagram for a picture.
i have e>0 and f>0, and i tried g=min{e,f} but that doesn't work because it doesn't guarantee that g will be small enough to only exist in the intersection of X and Y
Can you give an example on R where min doesn't work?
e exists in (-1,1) and =.9999999999...
f exists in (-2,2) and =1.999999999...
in this case, if g=min{e,f} then it works
i get that, but what i don't get is when one is not a subset of the other and they just overlap a little (e.g. (-3,1) and (0,4)
Can you give an example with (-3,1) and (0,4) where min does not work?
Note: You cannot use x=0 because it is not in the intersection, so use any other x.
GAH! Look, what is your definition of open?
I don't know why I'm doing this since it should not be necessary.
Or just forget that. Take two open intervals (a,b) and (c,d) that intersect, and suppose that one is not inside the other. Well, that means that a<c<b<d. But what is the intersection of the two sets? (c,b) and that's an open interval.
Now that ought not to help, because it is immaterial since the definition of open is NOT that it is an interval. It is that for any element x in X, there is an interval (x-e,x+e) about x contained in X. So you are completely missing the point if you're worrying about intervals not overlapping: either (x-e,x+e) is contained in (x-d,x+d) or vice versa.
