Dash-IQ
- 106
- 1
When a wire has current I in a magnetic field B, there is the Lorentz force is it considered a conservative force or not? Please do explain as to why it is.
The Lorentz force, which acts on a wire carrying current I in a magnetic field B, is not a conservative force. This conclusion arises from the fact that the Lorentz force depends on the velocity of charged particles, meaning that the work done is path-dependent. The discussion highlights that while the electric field can be conservative under static conditions, the magnetic field's properties, as defined by Maxwell's equations, indicate it is inherently non-conservative. Therefore, the Lorentz force cannot be classified as conservative since it does not meet the necessary criteria of being independent of the path taken.
PREREQUISITESF = q(E + v x B)Physicists, electrical engineers, and students studying electromagnetism who seek to understand the nature of forces acting on charged particles and the implications of these forces in various physical scenarios.
UltrafastPED said:The force on the wire is given here: http://en.wikipedia.org/wiki/Lorentz_force#Force_on_a_current-carrying_wire
If the electric field is static then it's curl is zero - and the electric field is conservative.
But when we consider the magnetic field Maxwell's equations tell us that it's divergence is always zero -so if it's curl were also zero we would have B=0. Thus the magnetic field is not conservative, and the exact situation shouldn't matter.
Dash-IQ said:When a wire has current I in a magnetic field B, there is the Lorentz force is it considered a conservative force or not? Please do explain as to why it is.
Robert_G said:now for the Lorentz force, this force actually has something to do with the velocity of the charged particles. Different velocity means Different force, that plane will never be introduced. So it's not conservative.
DrStupid said:Lorentz force is conservative because the work done between two points is independent from the path.
Dash-IQ said:Hm, what about the statements of the rest?
UltrafastPED said:Read #2 again. What is your conclusion?
DrStupid said:I conclude that we need to distinguish between Lorentz force and magnetic field. As Lorentz force has no force field the corresponding formalisms does not apply. Thus there is only one condition left: conservative forces conserve mechanical energy.
BruceW said:But what happens when we integrate this force, over the path of the particle? What happens to the term due to the magnetic field?
That is wrong.Robert_G said:If the force is only depends on the position, or in other words.
\mathbf{F}=\mathbf{f(\mathbf{r})},
then, is conservative. because, only if the force only depends on \mathbf{r}, A plane with the equal potential energy can be introduced.
The Coulomb force has zero divergence and curl.UltrafastPED said:The force on the wire is given here: http://en.wikipedia.org/wiki/Lorentz_force#Force_on_a_current-carrying_wire
why is that wrong? It is a different definition of conservative force. But I've seen more than one definition used. For example, on the wikipedia page, they seem to use at least two different definitions.Meir Achuz said:That is wrong.
BruceW said:why is that wrong?
It is the two onlys that make that statement wrong. The equation given is for a conservative force, but there are many other examples of conservative forces. One example, among many, is the force in my previous post.Robert_G said:No, It's not, there is an easy way to see if a force is conservative, or not. If the force is only depends on the position, or in other word.
Dissipative forces like {\bf F}=-k({\bf v\cdot r)r} are not conservative.Khashishi said:All fundamental forces are conservative. The Lorentz force is just the electromagnetic force, which is conservative.
ah right. The force field would also need to have zero curl, to be able to write it as a gradient of a potential energy.DrStupid said:Counterexample: F = [x-z,y,0]
