Is the Power Tower Method the Key to Solving Nonlinear ODEs?
  • Context: Graduate
  • Thread starter Thread starter TylerH
    Nonlinear Ode
8 replies · 3K views
TylerH
[tex]y^2=y' \Rightarrow y=\frac{y'}{y} \Rightarrow \int y dx = ln \left( y \right) \Rightarrow y=e^{\int y dx}=e^{\int e^{\int y dx} dx}=e^{\int e^{\int e^{\int y dx} dx} dx}=\cdots[/tex]
Is that correct?
Which is the same as y= -1/(x+C) so that [itex]\int ydx= -ln(x+C)+ C_2[/itex] so that
[itex]e^{\int ydx}=C_2 \frac{1}{x+ C}= \frac{-1}{x+ C}= y[/itex]
so, yes, your chain of exponentials is correct- but a very complicated way of writing a very simple function.
This reminds me of a problem in a math contest I once saw. Solve:
[tex]x^{x^{x^{x^\ldots}}} = 2[/tex]
The answer is [itex]\sqrt{2}[/itex].
hunt_mat said:
Why not just say:
[tex] \frac{y'}{y^{2}}=1\Rightarrow -\frac{1}{y}=x+C[/tex]
Yeah, I found the real solution. But, it's the fact that something so contrived is equal to something so simple that makes it awesome.
That was the first thing that came to mind. Btw, you [STRIKE]would[/STRIKE] could solve that "infinite power tower" using (4) here: http://mathworld.wolfram.com/LambertW-Function.html.
If
[tex]x^{x^{x^{x^\ldots}}}= 2[/tex]
then
[tex]x^{\left(x^{x^{x^\ldots}}\right)}= x^2=2[/tex]
More generally, if
[tex]x^{x^{x^{x^\ldots}}}= a> 0[/tex]
then [itex]x=\sqrt{a}[/itex].
HallsofIvy said:
If
then
More generally, if
almost:
[itex]x=\sqrt[a]{a}[/itex]
HallsofIvy said:
If
then
More generally, if
Actually, it should be [itex]a^{1/a}[/itex], no?
But this is true only if there is a solution. When I substitute [itex]\sqrt{2}[/itex] for x and iterate it, it does indeed converge to 2. But when I try it for cube root of 3, it doesn't converge to 3. It converges, but to 2.47805. What's more, when I ask Mathematica for [itex]-\frac{\text{ProductLog}[-\text{Log}[z]]}{\text{Log}[z]}[/itex], which is supposed to give the infinite power tower of z (see http://mathworld.wolfram.com/PowerTower.html), it does in fact come to 2.47805. MathWorld says it converges only up to [itex]e^{1/e}[/itex]. The interesting thing is, [itex]2.47805^{1/2.47805}[/itex] equals the cube root of 3.
