Is the Probability Axiom Valid for Mutually Exclusive Events?
7 replies · 3K views · last reply
Mathman23
Hi
I have this here probability axiom which I'm not sure what I have understood correctly.
Let [tex]B_1 \ldots B_n[/tex] be independent events
Then [tex]P(B_1 \mathrm{U} \ldots \mathrm{U} \ B_n) = 1[/tex] which is the same as
[tex]P(B_1) + P(B_2) + \ldots + P(B_n) = 1[/tex]
I would like to show that this only is valid if [tex]1 \leq k \leq n[/tex] such that
P(B_k) = 1.
Proof:
If [tex]1 \leq k \leq n[/tex], then [tex]P(E) = 1[/tex](where E is the probability space).
Thereby it follows that [tex]P(B_1 U \ldots U \ B_n) = P(B_1) + P(B_2) + \ldots + P(B_n) = 1[/tex]
This can be written as the [tex]\sum_{n=1} ^{k} P(B_{n+1}) = P(B_{k}) =1[/tex]
Am I on the right track here?
Best Regards
Fred
I'm very confused by what you've written.
So I will just state some facts:
[tex]P(B_1 U \ldots U \ B_n) = P(B_1) + P(B_2) + \ldots + P(B_n)[/tex]
is true when the [itex]B_i[/itex] are disjoint -- this equation is usually false when they are independent.
If E is the event consisting of all possible outcomes, then P(E) = 1.
In fact, P(A) cannot be greater than 1 for any event A.
Hi Herkyl and thank You for Your answer,
I have looked at it again and come to the conclusion that the proof should have said:
Let B_1 \ldots B_n be independent events. Show that
P(B_1 \mathrm{U} \ldots \mathrm{U} B_n)= 1, if and only if there exists a number 1 \leq k \leq n, such that P(B_k) = 1.
Proof:
Am I on the right path here now?
Your theorem is false. "Heads" and "Tails" are independent events, neither P("Heads") nor P("Tails") is 1, but P("Heads" U "Tails") = 1
No, heads and tails are not independent. P(Heads and Tails) is certainly unequal to P(Heads)*P(Tails).
Hello can I change my original theorem to make it true?
If Yes, how?
Sincerely Fred
Okay, I guess I confused "independent" with "mutually exclusive".
If you have two independent events B, B', then:
[tex]P(B\cup B')[/tex]
[tex]= P((B\cap B'^C) \sqcup (B\cap B') \sqcup (B' \cap B^C))[/tex]
[tex]= P(B\cap B'^C) + P(B\cap B') + P(B' \cap B^C)[/tex]
[tex]= P(B)P(B'^C) + P(B)P(B') + P(B')P(B^C)[/tex]
[tex]= P(B)(1 - P(B')) + P(B)P(B') + P(B')(1 - P(B))[/tex]
[tex]= 1 - [P(B) - 1][P(B') - 1][/tex]
If [itex]P(B\cup B') = 1[/itex], then [P(B)-1][P(B') - 1] = 0, so either P(B) = 1 or P(B') = 1.
Mathman23 said:
Hi
If [itex]B_1, B_2, \ldots, B_n[/itex] are mutually exclusive then
[itex]P(B_1 and B_2 and... and B_n)= P(B_1)+ P(B_2)+ \ldots + P(B_n)[/itex]
follows from the definition of "mutually exclusive".
If, in addition, they exhaust all mutually exclusive events, then
[itex]P(B_1 and B_2 and... and B_n)= 1[/itex]
P(B_k) = 1.
Proof:
? How does that follow from the above? If P(Bk)= 1 then it follows that P(Bi)= 0 for any i not equal to k and so
[itex]\sum_{n=1} ^{k} P(B_{n+1}) = P(B_{k}) =1[/itex][/quote] follows trivially. But you are claiming the converse: if the sum of probabilities is 1 then the probability for each i except one is 1- and that is not, in general, true.
Best Regards
Fred
