Is the Space Hose a Viable Solution for the N-Prize Challenge?
  • Thread starter Thread starter gutemine
    Hose Space
The discussion centers around a proposed low-cost Space Tower concept called the Space Hose, which utilizes a lightweight hose made from PE foil to generate lift through frictional forces from flowing air. The idea aims to address the N-prize challenge of launching a 9.99-gram satellite into orbit for nine days while adhering to a strict budget. Participants debate the feasibility of maintaining a satellite at 100 km altitude, with concerns about achieving the necessary orbital velocity and the structural integrity of the hose under such conditions. The conversation also touches on the definition of orbit and the challenges of stability and pressure at high altitudes. Overall, the concept raises intriguing questions about innovative approaches to space launch technology, despite significant technical hurdles.
  • #101
jarednjames said:
Anyway, I think this point has been hammered into the ground now and we should perhaps concentrate on the physics of the device?
I like this sentence :-)
Did you have already some progress on (re-)checking the structural strength needed ?
I already shared all the data and calculation I have on this subject - which doesn't look that bad in my understanding, but at the moment it is just patched together out of classical engineering formulas and some assumptions.
If PE foil combined with Dyneema can hold all possible stresses (pressure AND pull) put onto the structure because of it's strange diameter to length to thickness to weight ratio (hopefully my English teacher will never see this sentence) this would be already some kind of confirmation to proceed with this concept.
As the slides say - I hate to wait for carbon nano tubes !
On the other hand if the physics would not work to provide the lift force and handle the gas flow this would be still only half of the lunch.
So we would need urgently somebody also beeing able to put some light on the suggested gas dynamics - If nobody here can help out on this - what would you suggest ?
gutemine
  • #102
I have the dimensions from your slides, can you provide me with a link to the exact materials you plan to use (or provide me with some datasheets on them) so I can be sure I'm looking at the right stuff?
  • #103
For Dyneema Material you should start with the Manufacturer:
http://www.dyneema.com/en_US/public/dyneema/page/about/Material.htm
For getting the strength and weight numbers I checked the (German) Wiki:
http://de.wikipedia.org/wiki/Dyneema
But if you Google with Dyneema and strength the numbers should be easily verifyable.
Also the English Wiki on Dyneema contains links to some tearing test studies.
http://en.wikipedia.org/wiki/Ultra-high-molecular-weight_polyethylene
And this one is also a good source if you look for material data:
http://www.matbase.com/material/fibres/synthetic/dyneema/properties
For PE foil you can check the homepage of some of the manufacturers which are producing such PE foil hoses as cheap packaging material.
I got the strength values again from the (German) Wikipedia:
http://de.wikipedia.org/wiki/Polyethylen
or here:
http://www.matbase.com/material/polymers/commodity/hdpe/properties
Lots of PE foil manufacturers also give the tearing strength and weight numbers and for PE-HD the 20N/mm² for tearing strength we should be on the low side. For plain/cheap PE 10N/mm² is more realistic.
http://www.matbase.com/material/polymers/commodity/ldpe/properties
So in general the used numbers should be in line to what they advertise :-)
gutemine
  • #104
gutemine said:
Space is a location - not dependent on the speed !
So is your driveway, but it's a looooong way from pole position at the racetrack.
gutemine said:
I'm in space if I'm 70.000km away from Earth and don't have any speed at all. Then I' will spend the next hours/days to fall back to earth
It takes less than an hour. And much of that is in pretty thick atmo.
gutemine said:
- but I'm definitely in space!
Actually, no. You're surrounded by atmo.
gutemine said:
If you are in Paris it doesn't make a difference if you are on top of Eiffel tower, in a cab or a TGV entering Gare del'Est or sitting at the Seine and eating a baguette.
If you are in London (and have not even passed the Channel) you are definitely not in Paris !
Terrible analogy.
gutemine said:
This starts to become almost a fight comparable to geocentric vs. holocentric. If you are standing still compared to Earth and are 100km high above you still orbit the Sun at amazing speed, and together with the sun you orbit the milkieway at another pretty high speed.
Which I am still doing on the ground in my bed, asleep. You're really losing perspective now.
gutemine said:
If I would follow this argument landing on the moon would have been a waste of time and the real achievment would have been Apollo 8 which orbited the first time the moon (something the Russians achived before if I remember right)
No, That is quite an achievement. It is out of Earth's very deep gravity well.
gutemine said:
And orbit is also a lock-in as stiting on a tower - it costs fuel and time and needs acceleration to change height, direction,... try to make a polar orbit out of an equatorial - then you will know.
The amount of energy required to get from 0 to 100km with zero residual velocity is vanishingly small compared to teh amount of energy required to get anywhere beyond that that is not simply on top of a taller tower.
gutemine said:
If a space hose could offer a launch vehicle beeing able to bring you to space (as a loation !) for an infinitely time (if you stay on top) with a much smaller budget you think this is something nobody would care ?
Absolutely they would care.
I'm not trying to discourage you. I just think it requires some perspective.
gutemine said:
If you can read everywhere that the current space elevators and towers have a problem because of no material supporting them, and you then find a way where a continuous support reliefs this material problem - then this is useless, because somebody planns to build only a 100km prototype ?
Maybe I simply misunderstand your point and apologize if my reply sounds impolite, but I really have a porblem understanding why this part is so important for trying out something and get some proove of concept by competing in a Prize which will get nobody rich ?
I agree it would make a great protoype and a great achievement.
  • #105
Maybe we have a misunderstanding here - I'm pretty sure that 70.000km away from Earth I will not be surrounded by air.
Even in 100km pressure is down to something 100Pa which is already pretty low. At 350km height (where ISS hangs around) it is down to something about 1Pa. The quality of such a vacuum is already pretty good.
Regariding the falling time from 70.000km the law about freefall goes like this:
s=gt²/2 then t= squareroot from 2s/g
For 70.000 km this gives (yes, I know that g is not 9,81 anymore that far out) 3777sec - so I agree with the <1h and the frist part of the sentence (sorry fro not doing the math when I replied) but speed is:
v=squareroot from 2gh which gives for 70.000km 11721m/sec or 42189km/h on the ground- which means you will spend only a few seconds in what you could call an atmosphere - while you are probably burnt to ashes - so 'much of that' is a kind of heavy understatement.
But it looks like we have to break the gasdynamics elephant down a little bit for eating it:
Question 1:
Is the gasdynamics calculation of moving 1m³ from sea level to 100km right (using the known pressure and temperatures at these 2 points and the ideal gas law to calculate the Volume) so that it expandes that heavily as the slides suggest ?
pV/T = constant for 1m³ at 20 degree Celsius means 100000*1/293=341 the same for 100Pa at 100km and T is -90 Degree Celsius would need a V of 625m³ (!) to give the same number: 625*100/183=341
PS: If somebody wants to watch Paul's Interview on the N-prize:
gutemine
  • #106
Wait. When you say 70.000km you mean 70, right? Not 70,000? Why would we be talking about 70,000km altitude?
I don't think that's the case. I don't think you're accounting for terrminal velocity which will lengthen the lower half of the trip. There will be no terminal velocity for the first part of the trip, since the atmo is pretty thin. You'll fall pretty fast; it is only when you hit the thicker atmo that you'll slow down. I don't have any calcs to show but I think the bulk of the fall will be spent in the lower half of the 100km.
BTW, I also don't think there's much burning to a crisp happening. Spaceships use heat shields because they're slowing from 17,000mph, not from a few hundred mph.
Anyway, this is all beside the point. It is derailing you from your R&D for the space hose.
Carry on.
  • #107
My original Post was 70000km (and you even citated it with km). The number came up because of the 2x36000km of the space elevator with asteroid counterweight. If you are there without speed you are still in space (at least for the next 50 something minutes) but not in orbit.
And yes, the Paris example was a bad one - but it was just to illustrate that if you are at a place the speed is not the point (unless you want to know how long you will stay there).
Anyway, let's see if we can fix and clarify also the other questions.
Because I still have a huge problem understanding what would go on in such a long hose. All the typical formulas and examples are either isobar (which would be the hose laying on the ground, but then you don't have gas expansion due to decreasing pressure) or frictionless (expansion from a pressurized boiler to vacuum (to calculate maximum blowout speed)
If you mix up all these you endup with the concept I proposed, but I'm not sure if I mixed it right.
So probably looking at the ingredients/formulars before mixing them at all is not such a bad idea :-)
My real problem is that I'm already pretty late for the N-prize and unless the concept hasn't been verfied at least to some extent I would not send the application form and waste Paul's and your time.
On the other hand if it is feasible and the available/suggested materialy can do the job (not orders of magnitudes away in strenght or available length,...) I will definitely proceed - just for the fun of it (as Paul states in his interview on YouTube).
PS: Paul signs his e-mails as Chief Optimist - maybe I'm the CTO (Chief Technology Optimist) but then I need Pessimists to do a good job.
PPS: Space ships are entering the atmosphere tangentially - so the time to heat up is longer. If you go trough vertically probably no heat shield would be able to do this (better ask a meteor) and the negative acceleration would be a nightmare and probably break you also.
gutemine
  • #108
Just a thought, a firehose is made of a strong material and is subjected to high pressure water being pumped through it. They use two people to control it. If they let the hose go, it swings wildly around.
Why wouldn't this be the case with the space hose? Unless the hose is kept perfectly vertical any lateral movement would result in this wild swinging motion. The higher the flow velocity in the hose, the worse the problem.
  • #109
This works also with a garden hose and is the example how you usually explain to kids how rockets work - the momentum of the water leaving the hose creates a push back force on the nozzle and hose in reverse direction of the outflowing water (=backwards).
BUT If you put an steel plate 10cm upfront of the nozzel which is connected via steel wires to the nozzle and turn on the water the water and its momentum will be going circular from the hose and hence equal itself out. Then the firemen could hold the hose with a single hand (but it would be hard to put out the fire)
If you use a cone instead of a plate so that the water is reflected slightly backwards on the fir men - then besides that they get wet the hose will be pulled out of their fingers if the don't hold it properly.
Look at the 'design thoughts' slide - this is exactly what the diffusor on top should do - recovering some of the pressure of the outflowing air and changing its direction to blowing slightly downwards to get a pull on the hose instead of a push (and hold its own and the N-SAT weight too as an option). Even the famous bouncing ball in a fountain works that way by using the impact pressure to hold their own weight.
You can even use this pull force for erecting the hose and to stabilize the whole thing when upright. Such a downward blowing diffusor is the pneumatic replacement for the top counterweight suggested for a standard space elevator.
If the diffusor would be held vertical by a static pendulum mass underneath and the diffusor plate beeing not fixed (or a gyroscope - because the diffusor could be also a propeller mass rotating in the outflowing air and maybe even produce electricity). Then as soon as the hose bows to one side the diffusor plate will be lifted on this side and allows to blow out more gas on this side, which will then create a backword force moving it upright again until the momentum is balanced again.
The force which acts on a rocket is:
F=A*density*v²
Meaning if the hose would be very short then near the ground the force resulting out of the asumed possible flowspeed of 3,5m/s would be (if the blowdown area is equal to the hose area to prevent pressure/speed changes):
F=0,05*1,29*3.5²=0,79N - enough to balanace the weight of the suggested N-SAT
What scares me a little bit is that because of ideal gas law if the volume on the top should be is 625x higher and hence the density 625x lower (see one of my previous replies on this),
BUT because of continuity law this would mean that if the diameter of the hose is unchanged the air speed could be up to 625 times higher, meaning 3,5x625 which gives approximately 2200m/sec (30% of cosmic speed) ??
Because the force goes with the square of the speed this would mean that the theoretically available force on top from blowing downwards could be *625²/625=625x higher =493N - which would be sufficient to hold 50kg ?!
But changing the direction of the outflowing air to side/downwards also recovers some of the cinetic energy as pressure on the diffusor, so the exact calculation probably is not that simple
This is the reason why the slides say that at 100km the diffusor should blow down only slightly :-)
Put this probably would be question 3) - as soon as we have a decision on question 1) and because we also need to find out what 2) the friction does to the airflow.
gutemine
  • #110
Hi !
Just a small update:
With the re-calculation of the previous replies I found an error in the presentation on the first page:
The Line with the ideal gas formula between bottom and top should read:
Q on top =(100000*0,17/293)*183/100 = 106,18 m³/s
This means when blowing out trough the same diameter then on the bottom (0,05m²) would give only 2253,16m/sec theoretical blowout speed not the 5367m/sec on the slides.
This would be about 30% of the first cosmic speed needed for orbit which still seems to be pretty unrealistic. This means the Diameter of the Blowout nozzle would need to be changed by a factor of the squareoot of 3 or the blowing speed at the bottom changed to 10m/s to reach 7400m/sec in case this would be needed.
But the real speed gradient is still under discussion, I known :-)
Thanks for pointing out this error !
gutemine
  • #111
gutemine said:
well, the real problem with all orbit definitions is that they were not specified with any tower/elevator construct in mind. Some contain gravtiy and/or speed - some do not, etc.
If you build the classical 72.000km space tower with a counterweight asteroid at the end then only about 1 inch in the middle (which would not even need to be the mass center) would actually be in orbit if you hammer the definitions in stone - because only this inch would rotate exactly with the obital speed at 36000km of 7,something km/sec.
And that inch would be 35,786 km above the Earth's surface, right? With an orbital semi-major axis of 42,164 km?
gutemine said:
Space is a location - not dependent on the speed!
Bingo. It's a fact which you get, I get, NASA gets*, Rutan's SpaceShipOne got by winning the $10 Million http://en.wikipedia.org/wiki/Ansari_X_Prize" , and which the N-Prize organizers get as evidenced by their acceptance of your idea.
*13 of the flights (by eight pilots) met the USAF spaceflight criteria by exceeding the altitude of 50 miles (80.47 km, 264,000 ft), thus qualifying the pilots for astronaut status.
There is a huge difference between an orbit and a zero-g orbit. All aspects of a space tower, pos-g to neg-g areas will be in orbit, while only free-floating satellites are in zero-g orbit.
I haven't a clue as to why anyone, particularly a scientist, is incapable of fathoming this concept when so many scientists and engineers before him/her over the last 48 years of space travel have accepted it completely.
If anyone continues to harp on the issue, I suggest you ignore them.
In the meantime, press on! You're doing a great job. :)
  • #112
Just because it's in space, does not make it in orbit. That is the key difference. If the N-Prize said that they simply had to put something in space, then boom he's there. But the rules are specific in that it must orbit 9 times. Definitions aside, in simple terms that means the satellite must remain in space (unattached to the tower) long enough to complete 9 rotations of the Earth's axis with at least 100km altitude (from sea level).
I've tried to drop the orbit issue about three times now and focus on the maths, but people just keep bringing it up again...
  • #113
jarednjames said:
If the N-Prize said...
They have said. Repeatedly. Gutamine has contacted them. They have responded.
  • #114
mugaliens said:
Bingo. It's a fact which you get, I get, NASA gets*, Rutan's SpaceShipOne got by winning the $10 Million http://en.wikipedia.org/wiki/Ansari_X_Prize" , and which the N-Prize organizers get...
Um, you do recognize that the difference between the N and X prizes is at the X prize was to get into space and the N prize orbit, right? Thus this space hose idea would satisfy the X prize, but not the N prize.
...as evidenced by their acceptance of your idea.
Clearly, they were deceived: they were not told that the object is intended to be supported by the tower.
Dave keeps harping on it because it is a simple issue that several people are blindly ignoring. He feels the need to correct people when they are wrong, in keeping with the spirit of the forum.
  • #115
DaveC426913 said:
Update
You will be astonished as I am.
I have been in contact with the N-prize judge myself. Here is the transcript:
Q: Hello. Can you please define your use the the term 'orbit'.
For example, some who might wish to interpret your rules as liberally as possible might consider a satellite sitting on top of a 100km tall tower to be in "orbit" (since it will ultimately go around the Earth once every 24 hours). Would this qualify?
A: As long as it's at 100km without touching anything else, it would qualify. ... So, if you had a "tower" but could somehow hold the satellite there at the top without touching the tower itself, that would be OK.
Q: " without touching anything else": does that include, say, a column of air?
A: Ah, yes, could be. As for "touching" - I think that's OK. ... the air pressure at the "orbital" point would be very close to the external pressure at 100km anyway, so no problem.
Q: This tower does not move, which means the satellite will *not* orbit the Earth 9 times (one of the N-prize requirements) unless you very liberally allow Earth's own daily rotation to count. Does that still qualify?
A: As for "orbits" - the Earth's own rotation does count, so as long as it stays up for 9 days...
:eek:
It would appear that the N-prize judge is perfectly happy to allow this non-orbit to qualify, despite the requirement in the rules.
I'm not so sure I agree, Dave - you were trying to constrain your questions to the context of this thread and as a result there are some physical impossibilities represented there. The first answer you got is particularly nonsensical. It's possible that the person you were talking to doesn't understand the concept of an orbit very well (who runs this thing anyway?), but when push comes to shove, I'm sure the letter of the law will rule.
  • #116
Yes, and as per the posts on this very forum, it has been made clear. The satellite cannot touch the tower = orbital velocity required. So far no way to achieve this.
There is potential that the tower idea with the satellite supported on a column of air will be accepted into the competition, but nothing set in stone and it is subject to the approval of all other competitors (as the N-Prize representative pointed out, it's not just the judges who decide). I'm sure they'll have something to say about it.
Regardless, I think we should just help with the calculations and let this slide.
EDIT: russ, you may want to read the N-Prize posts directly from the organisation itself. They clear things up far better. (https://www.physicsforums.com/showthread.php?p=2885614#post2885614)
  • #118
russ_watters said:
Thanks, I didn't see that we had an N-Prize organizer here.
He arrived about six hours after I started bombarding him with my requests for clarification... :wink:
  • #119
Hiding behind a name like N-Prize, he could have fooled anyone :biggrin:
  • #120
Honestly Dave, you're a minute ahead of me on every bloody post! :cry:
  • #121
I am getting treatment. :wink:
  • #122
Well, as already explained we have disussed this extensively - and Paul has cleared that he has some freedom to decide and/or accept or reject.But he also promised not to use it as a complete showstopper - whci hsi very wise in my opinion and shows also the entire spirit of the N-proze to simply try the impossible.
Originally I asked him if a geostationary orbit of 100km height would be acceptable - because of the rules to have 9 orbits this would mean 9 days in such a strange case. And please don't comment again that a geostationary orbit at 100km is not possible - we all know - but it was a quwstion and it was answered with a yes. The 9 orbits were choosen by Paul to prevent lucky single shots to qualify for the price with extremely eliptic and hence not stable orbits (because after a few the path going trought atmosphere would kill the SAT). If you want more details on this read the N-prize thread at halfbakery.com
Normally a 100km orbiting SAT will take approximately 90 minute to circle Earth - which would mean 9 orbits would be done within 14,5 hours. If the orbit would be geostationary it takes MUCH longer. Staying there für 9 days with a tower/hose or whatsoever would be something comparable to a stable orbiting SAT, because then it is not a luckily erected tower which fell immediately to the ground after his top made the 100km for 10 seconds :-)
This is why you would need to build a real space (>100km) tower to get into the competition. Which the Space hose concept theoretically would allow (remember - so far nobody proved me totally wrong).
So in my understanding Paul is accepting that such a lomg standing tower time is to some extent compensating the lack of orbital speed.
Hence Paul promised to accept it for the competition if I send him the papers. For actually winning according to the rules I still see a 50% chance that even an orbital speed blowout of such a small SAT could be feasable, because as I said - gasdynamics should actually make the air on the top blow out really fast (as my prevous reply said - if you blow on bottom with 10m/sec ideal gas law would make a nice 7,8 km/sec out of this on the top.
But this would be only under ideal cisrcumstances (which is not the case because the Space hose is acutally using the friction to generate the lift). Normally in a pipe with friction you get a continuous pressure loss, but in such an open hose gasdynamics is a little bit more complex - gas gets accelerated without any diameter change (because of the lower hydrostatic pressure), after 50km you would be theoretically already hypersonic, etc.
On the other hand I made the math with a blowout pressure of 200Pa where surrounding pressure is 100Pa - you can do quite some strange things there like using the bouncing ball in a fountain approach similar to a normal SAT using centrifugal forces, etc. So let's simply see where this journey will lead us - and how far to space we can get.
All these things would need to be discussed and verfied, and it looks like we still have a long way to go.
So all your input is welcome, but don't spend ALL your energy and time on the rules - they are important if you really want the money but they are there for heating up innovation - not for cooling it down. Abnd I don't really care for the money - it is more about the fun solving such a strange puzzle - in a strange and unusual way.
PS: Remember, we are still working hard on question 1)
PPS: And don't argument with me about my approach to let the community debug the concept with me together - I do also quite some open source software development - and there my approach has prooven to be extremely efficient - if the software at least does to some extent what it should do - no matter if you still see the tape and rubber bands. So if you find a bug - I'll simply try to fix it.
gutemine
  • #123
Me too :-)
  • #124
gutemine said:
Me too :-)
:eek:
That's not here...?
  • #125
They can say whatever they want over at N-prize, but here you will have to use correct terminology.
Stop calling it an "orbit" and everything will work out just fine. I suggest using the word "suspended" (at 100km).
  • #126
No, this is somehwere ...else - and definately not on physics or mechanical engineering - but on innovation ;-)
gutemine is actually a character from the Asterix comics book (I think in English she is called Impedimenta, or in French Bonemine). She's the wive of the boss in an ancient french village which is constantly and successfully in battle with the surrounding romans.
I agree on the orbit piece - it just confuses the romans :-)
PS: I called the whole thing Space Hose because of the 100km height - which should be OK in my understanding (even when only the last inch would be in space according to the NASA definition, but there is no point in not making it longer). Maybe I will call it suborbital Space Hose to be in line with the suborbital space flight wining the X-prize.
gutemine
  • #127
Ah Impedimenta, yes. I remember her.
Always had a thing for Panacea myself... :!)
  • #128
Obelix has the same problem - so you are excused.
But Buzz is definitely the better Character for illustrating this concept - may the Toys (and Pixair) forgive me.
  • #129
It's obvious that this theory has some flaw in it. All the "space elevator" concepts out there depend on one thing, a rigid wire which is held in orbit by a large mass. This large mass is critical because it holds the string taught.
Let's assume for a second that your idea works and you get the thing airborne and completely upright (this alone is very unlikely for reasons that I will describe later). So now you have a tube which is slightly fluttering around in the air (because remember you chose TURBULENT airflow. This is why your wild wacky inflatable tube man flutters in the air instead of standing straight like you would like him to, it's because of the turbulent flow. If wild wacky inflatable tube man were using a high viscosity fluid such as water, he would not dance because of the LAMINAR reynolds number). But i'll be nice. Let's assume that you figure out a way to get the thing stable and upright, I donno you inject some laminarizing particles... or something... But anyway it's straight, it's upright and it's stable.
So now you look up at the top of your glorious hose and you realize it's curving... but how can this be? There's such a mighty air pressure! It's for the same reason that poster #4 said. You must impart SIDEWAYS velocity. Vertical velocity just doesn't cut it. Imagine you attach a string to a frisbee and throw it, that string is going to twist with the frisbee. That's because the tension and centrfugal force, and the sideways strength of the fibers in the string just cannot overcome the change in angular velocity. If you had a big steel rod and you spun it, it would STILL BEND (a little bit, but imagine that big steel rod is 80,000 ft long and you get the idea).
Ok so let's assume that you get the thing upright, stable, and you somehow reinforce it so that it's not bending under its own weight (I have no idea how you're going to do this, but let's assume you get it to not bend). So now you're like OMG I just erected a huge tube, what a glorious monument to my awesomeness! So then you try to blow a small satellite up your tube. You stick it in the bottom and start blowing. You notice that as soon as it's about 100 ft above the ground that your perfectly straight tube begins to bend again, but in a V bend (because we assumed that your tube was erect under its own weight). So now ur like ok I'll just increase the air pressure (at which point I guarantee you will blow a hole in whatever material you are using, even CNT's).
The core problem with your space hose is connected to the conservation of angular momentum. You cannot simply send an object into a state of higher angular momentum without robbing that angular momentum from something else. That's what the big rock at the top of the space elevator does. We have to capture an asteroid with a lot of angular momentum so that we can slowly impart its momentum to the satellites we send up there. The elevator cable doesn't work like a normal elevator cable, it must strain SIDEWAYS. The upward force is TRIVIAL compared to the sideways force that must be imparted by the cable on the satellite. This is why the vast majority of a rocket's flight is on its side and not upright.
  • #130
Despite z06_pit's heavy sarcasm, he has a point.
He's touched on something that's been bothering me too. Even with the space elevator, by the time you reach GEO, you are moving at a substantial velocity around the Earth (orbital velocity, in fact). This transverse velocity does not come free. As he says, it must be imparted upon the rising payload.
In the space hose, you don't have that rigid structure's ability to impart transverse velocity on its payload. You'll have to account for that.
  • #131
I have to say, Z06_Plt post is one of the best in this thread. I think the sarcasm is somewhat heavy, but necessary in so far as it reinforces the critical points which cannot be avoided and really do need addressing at this early stage. Solving one problem at a time may seem like a good idea, but without forward planning it can mean you end up back tracking and having to perform multiple redesigns (which can be costly and time consuming).
  • #132
I don't have a problem with sarcasm and critics - I desperately need it to to make it work.
But let me try to adress the feedback we got:
Actually properly fllying in the typical steroid with a large mass and rendevouz it with the tether is quite a complex thing and there have been already papers written on this and lots of compuer simulation done - really scaring, because it is like catching a huge baseball with a thin string - if the ball introduces to much stress because he needs to be accelerated by the hose you get a terrible effect, if it is too fast the stress in the tether to slow it down could blow the whole thing. And our current technology is not that great in flying asteroids BTW.
So the whole counterweight thing is not such a great solution as it actually looks at the first glance (it just makes you scream louder for carbon nanotubes, and hope that they will be also flexible) Remember I looked first into the problems of the existing concepts before creating my own.
Actually the slides on the space hose contain at least some thoughts about the velocity bowing problem:
The good thing for the Space hose is that 100km is only very very much less then 36000km - and because centripedal force F=mv²/r you the difference is even MUCH smaller. Actually you don't have orbital speed either (which would be a nightmare due du the ² and a diameter is 720x smaller (72000km vs. 100km). So you have to instantly drop quite a number of zeros in your worries.
The real speed difference top to bottom is in the slides - it is 26km/h or a moderate 7,27m/sec (which is about 2x the blowing speed - and I already commented multiply that something like 10m/sec is much more likely if you need extra weight for strengthening and want to have optimal blowout speed).
But anyway, this means that it will take approximately 2min to move the top 1km (1% of height). Hence you are right - if erected straight up it will fall - pretty fast.
On the other hand you are absolutely right, if the hose hose has same angular speed there should be no real problem out of the speed difference, and even some bowing. If you erect the hose in a day as suggested (but let's take the 8h that the air would travel trough when you blow into with 3,5m/sec - which is not correct because due to gas expansion by decreasing pressure the air will be much faster). Then you would have 8h to accelerate the top of the hose to 7,2m/sec - Which gives you 7,2/8/3600=0,00025m/s² if we assume continuous acceleration. With the air blown out on the top in 8h (rememmber we talk about a minimum of 618m³/h on the bottom, which is 625x618m³ at the top) you can easily produce this very weak acceleration to give to the entire hose (the 283kg) the proper angular speed. And yes, it will curve during erection, and probably even stay that way - that is the great thing about a hose - it can do this - as long as it is strengthened to hold the remaining pull forces.
But you are right - you could see the entire hose as a 100km long wall effect. If you take a wind tunnerl and hang a diametric wool string into it which is lose enough it will form something very similar to the parabolic velocity curve the gas is showing when flowing laminar. But it will be ONLY pull forces in the entire wool string.
Now let's try to find out how big this pull force could be. I'm a bad guy and hate integrals (to get the exact number). So let's be lazy and put the entire mass of the hose (283kg) at 100km height:
radius=6478000m (6378km Earth radius + 100km hose)
speed=2*6478000/24/3600=471m/sec (the famous 0,4km/s that you can save when starting your rocket east at the equator - reducing orbital speed difference from 7,8km/s to 7,4km/s)
F=283*471²/6478000=9,7N - now I'm really scared :-)
The hose at 250mm diameter and 0,004mm thickness has 250*pi*0,004=3,14mm²
At 20N/mm² tearing strength this means the hose can hold about 63N This is NOT much, but already could hold this centripedal force without the planned Dyneema string strengthening. BTW this is the reason why industrial PE foil is sold in 12/25/50micrometer thickness - because then if plastic bags are made out of the hose your grocery pruchases are save - because 63N is not really what you get when doing family shopping (=6kg). I simply have choosen the 0,4 so that the 100km is a neat roll of foil, and that I can easily add strengthening without blowing the friction lift concept by needing a thunderstorm to hold it upright. A hose up to maybe 1ton, can be held with a moderate airflow in my understanding which would produce pressures which are handable by the suggested materials.
And regaring the wiggeling because of turbulent flow. You are right, but a hose with a reasonable pressure surpluss is also the perfect damping device, especially when it is smooth and long. Because both the hose and the air are not heavy and hydrostatic pressure is balanced from outside I'm not sure if this would be that bad as you suggest. The air petrol station toy is not only wiggeling because of turbulence, it is because of the desing to reduce the diameter so that airflow increases, presure goes down until the outside pressure is bigger and the hose bows sidewards, then the pressure increase due to the closed hose puts it upright again. So it is designed as a kind of penumatic pendulum.
Try the same with a fixed diameter hose and a diffusor on top for generating pull forces. And even a fully turbulent airflow in a hose has a thin laminar piece at the walls of the hose (because of the lower frequency there). Hence the turbulences are not really scaring me - it is the increasing flow speed (if it is not compensated by diameter adaption, diffusors,..) which theoretically goes beyond the speed of sound. But nobody commented on this so far.
gutemine
  • #133
On the other hand, let's keep in mind that the satellite only weighs 9g (yes, nine grams). That's a pretty negligible amount of mass to toss about.
The N-prize rules are simple deliberately. Scaling challenges are pointedly outside the scope of this project.
  • #134
If the relationship N-SAT size to hose diameter is less then something like 10 there should not be a real problem - it will simply move to the center of the flow where the highest speed occures. And even when it would touch the walls, the force of a tangential impact is small and a hose under surpressure is almost perfect elastic. It would maybe mage some strange drumm sound while beeing blown upwards. Or we make it intentionally tach the wall with a kind of parachute with holes.
But the blowup behaviour of the SAT and the impact of turbulent flow is something relatively easy to test. You would only need to buy a few hundred meter of foil and try it out, Because of the weight of such a hose beeing in the 10kg range a simple model plain propeller and engine could already do all the blowing needed.
Somebody volunteering to try it out ?
But be aware you would need at least a very simple stabilizing diffusor on top or you will fail erecting it when going beyond a few meters.
I think the N-prize rules are pretty clever - they remove some problems and create new ones - but just building a small Saturn V or a small Space Shuttle would be boring, woudln't it ?
So I think the lack of scalability is the opportunity of the whole thing. Even for the space hose -10" diameter is peanuts, but more then enough for such an N-SAT. And actually it is exactly this very strange lift/weight/power/strength ratio which seem to make such a hose concept feasible - in the first run targetted at this purpose. Finally if it works at that scale you can try to make a real lift device for more sensemaking purposes. And yes, Paul did this intentionally to force the people on new ground, instead of trying to dig the same old holes all over again.
gutemine
  • #135
Capturing an asteroid is difficult and nearly impossible. Let's face it, if a huge asteroid comes that close to Earth that we can capture it, we are not going to be like "oh it's a friendly asteroid that we can use to build a space elevator". It's going to be like "My fellow Americans, we are honestly f****d. I am ordering that we nuke the thing out of our path and ask questions later". So I am by no means advocating the asteroid idea.
But to be honest you really don't need an asteroid, you just need a large mass at the top of your hose. Spiders don't build a web to support their own mass all at once, they don't just projectile crap out a web. They build it one strand at a time, get each strand to hold its own weight and then aggregate the strands to hold the spider's weight. I believe that the solution is going to come from a similar way of thinking. Granted, we are talking about each string as a multi-million dollar satellite launch, but it's an exponential growth model we're dealing with. (I'll explain more about this a little later)
Your hose idea is good except for the fact that you are lacking a way to impart angular momentum. You can get the vertical momentum with the air stream, there is no problem with that. You're going to be dealing with a pipe friction loss bigger than a naked fat lady on a metal playground slide, but granted, it's entirely feasible. And to be honest, it's a lot simpler than a robotic-laser-powered-crawler thing that they're putting all their eggs in currently. So all you need is a way to get angular momentum.
Let's say you launch a rocket. This rocket has a string tied to it, quite literally. It's made out of some high tech material, CNT's, Kevlar/cupronikel fibres, aggregated nanofibres, whatever (I recommend Nylon, you'll see why if you do some research). But regardless, it's a string tied to a rocket, nothing theoretical there. Launch the rocket into geosynchronous orbit and release the string. This string has a small weight on the end of it (emphasis on small, it's just big enough to pull the string taught and overcome air currents in the atmosphere). You throw the string out and send the rocket home. So now you have a string able to hold its own weight, in space, with a weight attached. You do this about 10 times, tying the strings together each time. (Yes I know that the orbits of the strings are going to degrade rapidly due to air friction from the lower atmosphere portion of the string. But this can be solved with a small, temporary thruster on the end of the string)
Now you launch your hose. Tie it onto the strings and now you have a means to transport small amounts of mass into space. But now let's say you don't use air... let's say you use methane and air. And you have a small nozzle at the top of your hose. Now what do you have? You have a rocket which is able to impart angular momentum on the string and whatever you send up. Then you fire another rocket up there towing your BIG hose. Now you have rocket engine up there to keep the big hose taught, and you have a means to transport small satellites and other cargo through the big hose.
Cut the small weights (from the very beginning) loose and you're in business.
I find the sarcasm/mocking makes my posts/papers easier to read. And, contrary to popular belief I actually like gutemine's approach on this, he's got some solid theoretical backing. Perhaps some of my ideas can help you hone your theory down to something usable. Because let's face it, do you really want to win the X (or N or whatever) prize on a technicality? A technicality is not going to help anyone. If you can manage to get something into GEO orbit with this thing, that's worth a hundred times more than just getting some little thing suspended at 100km.
  • #136
As the slides say, rockets are boring, but they work.
Unfortunately there is no such string which the rocket could pull - it would first tear from the acceleration and then from its own weight. The whole idea of the hose is to do everything slow and under control. Erecting it in a day, blow with jogging speed (maybe bicycle speed, remember friction goes with v²). Using ultra light material to keep the forces and masses low.
As I said at the halfbakery. If you have to build something in the desert - then use SAND!
We live at the bottom of an ocean of air - so it is the logic construction material!
I just followed this logic to the extreme.
Continuously supporting the weight is actually the only real new thing within the whole concept.
Instead of using a wing to create lift you simply use friction - as the slides say, the whole thing is a dumb circular flag blown from the inside - which should make it work also in vacuum.
PS: The entire problem with ballons running our of steam beyond 30-40km simply annoyed me - you get 1/3 of the 100km almost for free, and then the driver kicks you out of the bus and you have to wait for a rocket ? So I decided to start my own bus/hose :-) And this is also the reason why I dislike the ballon+rocket or even hose/tower+rocket conecepts. If I have air blowing out on the top Bernoulli and de Laval should be everything you need to even get the lacking orbital speed (again for an N-SAT - not for a space shuttle)
PPS: My background actually is poor on such things (I have other hobbies too), but I'm using it as good as a can. And as I already said - the math and pyhsics behind this is not something which should not look familiar when you had a good physics teacher at high school. And so far we did a good job in debugging the concept and analyze its problems or try to get an idea how big they really are. If you solve all small problems usually the big ones are gone too is one of my favoirite sayings. And as the original post says - N-prize is also about the entertaining value - so I don't have a problem if we have fun together.
gutemine
  • #137
Rocket acceleration is less than 3g at all times.
Breaking under its own weight is a different story entirely. However, if you use nylon, this problem gets a lot simpler.
Niel Armstrong said:
Oh **** this circular flag doesn't blow on the moon! I better stick a rigid wire in there for support.
Granted, Col Armstrong is referring to different situation than yours, but I just thought that it was funny, considering your choice of words.
What you described is different than a circular flag, there are many reasons why it is different than a circular flag. The most prominent of which is the fact that a "flag" is generally horizontal, and a "tube" is generally vertical. The second most prominent of which is the fact that when you extend this tube such a distance, the frictional losses prevent air from reaching the other end without manual pumping. This pumping changes the problem from that of friction to that of pressure/structural rigidity.
  • #138
A flag is also fighting gravity - hence the wording is not that bad :-)
Even Dyneema which is already pretty strong at a reasonable price/strenght ratio is able to hold already 300-400km of its own weight. But if you attach it to a hose which is able to hold the weight you can even avoid this problem to some extent.
If you would have a rocket with enough fuel to stay stationary in 100km height above ground you could already now hang a Dyneema string down and let climb everything which the rocket is able to hold as extra weight.
And there are rockets pulling cables - ask the US army - they call this an anti tank weapon and use the wire for steering it. But this concept runs out of usability beyond a (few) km or something.
Actually the picture of the Space Elevator climber challenge with the helicopter holding a 1km steel cable was also a big inspiration for me.
Regarding the friction force. The formula I used is designed for a horizontal PIPE. And the pressure loss it reports is only 0,6bar over 100km. Well, the problem ist that the formula is not designed for this, but theoretically if you would blow into such a pipe with 0,6 bar at this relatively low speed (3,5m/sec is a soft breeze if you do some sailing) the whole pressure should be eaten up on the end and you would blow out at 1 bar (which you would do when the end is open in any case).
If you now would use a hose instead of a pipe nothing really changes, if the hose is blown trough at the ground, except that you suddenly blow out in almost vacuum (100Pa) and instead of transferring all the friction force to the ground where the pipe was laying it will pull the hose upwards - against its own weight. I just tried to find what would be needed to reach an equilibrium of these 2 forces.
if you put the pipe/hose upright you simply have to add hydrostatic pressure (at least Mr. Bernoulli saiys so), Which for air is not a real problem, because the air outside does the same and hence the pressure should be always balanced. But I'm not even sure in what way this friction force would be transferred to the hose - blowing with extra speed (almost 300m/s as the slide suggest), or with the 0,6bar surpressure (bad but a Dyneema wrapped hose could still hold this) plus the suggested 3,5m/s ? But it is an open hose not a pipe, so normally there should be no surpressure except from the diffusor ?
BUT what is even more strange is that when you move 1m³ from bottom to top it will dramatically expand (would be 1000x in case temperature would be the same, but temperature on ground is 20 degree and in 100km it is -90 degree of celsius, hence expansion is only 625x). Friction is dependent on dynamic viscosity (dependant on temperature and density of the gas) and on the speed of flow². So friction in general is likely to go up because v² should win. Which would mean the upper part of the hose should eben get more friction and pull (unless you change the diameter). And the friction is even worser, if pressure drop occures due to it, it should create additional speed increase (Bernoulli - remember). But if you get so much speed from expansion already you don't need to feed it all at the ground in my understanding, and there should be an equlibrium of blowing an friction.
But it is even more confusing, after 100x expansion at about 50km height (there you have approximately 1000Pa pressure outside) the flow would reach the speed of sound without friction. And after this if you reduce the pressure further (which the atmosphere does for you) the speed would go further up, and because of the sonic border the hose would not even know that it is open or not. This is scaring, I intentionaly wrote in the slides the crazy question about a fixed diamter de Laval Nozzle :-)
On the other hand if friction really works and the speed stays in a sensemaking range, worst case would be that the friction converts to heat, which means further expansion and chimney effect in the hose giving also upwards flow.
Do you understand now that it is NOT that easy to say after a few kilometer it doesn't matter if the hose is open or upright, it will be like blowing into a kind of huge tank which at the end is only a crazy way of heating the whole device ?
So the real probably will be somewhere in between - air flow and supressure and expansion and friction, and ...
Because expansion and continuity law are still on our side, and as long there is flow you have friction - which always creates a force on the wall/hose which should be able to keep its weight if properly desinged ?
And remeber the whole thing is 100km long, so ALL speed and pressure gradients are extremely moderate (that's why I suggested a finite element calculation with 100m pieces in a spreadsheat to get some more accurate results on the speed and pressure gradient), this is not really the typical supersonic wind tunnel with extreme forces. I just decided some basic parameters like diameter and thickness and did some math - if we would have a proper model of the flow inside you would need to iterate it for finding the optimal parameters which could also include diameter changes to control the velocity - but then you would be in trouble when erecting the hose, etc.
Actually the whole thing is much more complex then it looks at first glance so saying yes or no is not that easy then I thought.
Which brings me back to my confusion and the reason why I have put it on slides and asked open and honestly for help !
gutemine
  • #139
Hi !
Just a small update so that you don't think I have forgotten you or got completely lost:
I have spent the last few days to build a spreadsheet which calculates the standard atmosphere from 0 to 100km in 1km pieces, and then applied the formulas of the slides to these pieces to better understand what happens in the hose.
Then yesterday (during my morning shower!) I actually found out why I had so big problems getting sensemaking results:
It was a typical border value problem. Actually I always tried to calculate from bottom to top, but it is much easier to do it top to bottom, because there you simply define the maximum blowout speed (for example speed of sound to prevent the hose going supersonic) and the needed surpressure required to hold the payload and provide sufficient pull power to keep the hose stable.
Then you calculate the pressure loss of the resulting flow 1km down, add it to the atmospheric pressure there and the requested surpressure and get with ideal gas law a new density there, and hence a new flow speed because of continuity law. This means a new Reynolds number and a new viscosity and Lambda which means you have all the starting values for the next 1km and so on.
The pressure and blowing speed at the bottom are then a simple result of this iteration down and not the other way around. Because you can change pressure and blowing speed at the bottom in a relatively wide range depending what pump/fan you use this is not really a problem, and much better then choosing them and then get weird results at the top and within the hose.
Then you calculate the speed of sound at all these points to check that nowhere the air flow is faster. When you then have the flow and pressure gradient of the entire hose you can calculate the tension forces in the hose and can check if the PE foil and/or Dyneema strength can hold it.
If you blow out at the speed of sound this also becomes a kind of event horizon, meaning the hose doesn't care/know what the diffusor afterwards does, if you add a de Laval nozzle to blow out supersonic, turn the air flow downwards to generate lift, etc.
Then you are done and have a Spreadsheet where you can start playing with different blowout speeds, diffusor pressures, different foil thickness, hose diameters,... to find the optimal hose.
I will polish the spreadsheet a little bit more so that everybody can use it and then probably tomorrow you can play with it. There are some quite interesting findings already from what I tried out.
So actually the formulas and the math was not that bad (and there was no real critics from you on this either), but the USAGE was simple a little bit dumb and I should have tried it the way I suggested already earlier instead of trying to enter 100km in a single formula which allows to get an idea if it would work, but produces only consfusion on how.
Thanks for your patience with me!
gutemine
  • #140
Cool. I'd be interested in your first take on fan speed/pressure.
  • #141
Well, the first key finding was that actually the blow speed at the bottom is lower (which is logic if you limit the head to 270m/sec which is approximately the speed of sound at -90 degree of Celsius), but you need a slightly higher surpressure to keep the whole thing stable (approximately 500-1000 Pa). This helped a lot to sort out the do I feed flow speed or surpressure at the bottom question which I never could sort out when I tried to calculate from there (predicting these 2 variables at the top is much easier and logically).
Funny is that the top contributes most of the pull forces even without the diffusor, which is good for extra stability. I already assumed this (because of the v² of the friction forces, but I didn't have any idea to what extent)
I'll see if I can warp it up and add some comments and colors for the changabel fields until this evening than you can play with it yourself.
Having such a 'virtual Space Hose' where all the parameters are changeable is pretty funny, and it even gives interesting results like pressure waves on top if the surpressure is too low, or how low you can bring the hose tensions down before it fails to stay errect (approximately 100N/mm² - which is not so far away from plain PE)
As I already mentioned I'm doing also some open source software development as another hobby so as soon as I found the formulas on how to calculate the Standard Atmosphere model from the definitions it was not so diffucult to build a Spreadsheet out of it.
http://www.pdas.com/coesa.ht
Then I found another Webpage where you can calculate air viscosity for all temperatures:
http://www.lmnoeng.com/Flow/GasViscosity.htm
It took me almost 1 hour to get all 100 viscosities for the model, but I was too lazy to try to reverse engineer the math for this too :-)
From these two raw inputs you have everything needed for the pressure loss calculation at all heights, and then the fun started when putting it together.
gutemine
  • #142
One more question on the wind - I found a nice picture on this (see attachment)
Would this mean that a hose with pull from top would actually form more or less such a bent curve ?
Because I would like to include also the pull force calculation into the excel, and for this I need a better understanding of the distribution of the wind force on the lower end of the hose.
gutemine
  • #143
Damned - I still have problems with my Excel and the discrete calculation steps because now I have a circular reference.
If I go 1km down this means that the pressure on the bottom should be the one at the top + pressure loss from friction + hydrostatic pressure of the 1km of gas.
The problem is that hydrostatic pressure is dependant on the density, which is resulting from the pressure from bottom to top (if I asume that temperature is always aproximately outside temperature of the standard atmosphere) = circular reference. Now I understand why the books are saying this is a differetial equation with an integral which is only numericially solveable - if at all :-(
And if I try to overcome this by simply taking the previous density as I did until now the result is underestimating pressure, which makes the numbers look good, but then the model is invalid beyond the top few kilometers of the hose, because only there density and hence hydrostatic pressure is low enough to allow such a simplification. So calculating top to bottom was a good idea, but gives wrong results at the bottom because of the discretisation. This is also the reason why going from bottom to top produced too high numbers on top.
But problems are there to be solved, and input is welcome ;-)
gutemine
  • #144
Is the "space hose" thread over?
11K
