keepit
- 94
is the speed of light any faster in low density space than in high density space?
keepit said:is the speed of light any faster in low density space than in high density space?
Agerhell said:In vacuum the velocity of light is lower in a region of strong gravity. If you send an electromagnetic signal through the solar system it will travel slower close to Jupiter, the Sun etc. However, the frequency of an atomic watch will also slow down in the gravitational field by exactly the same amount so locally the velocity of light will be perceived as invariant.
The extreme case is the Schwarzschild radius of a black hole where both the rate of time and the velocity of light, according to general relativity, will become infinitely slow.
PAllen said:Light in a strong gravity well will appear slower to an observer further away. However, the observer in the strong gravity measuring the speed of light over any short distance will measure it as c. The definition of a semi-Riemannian manifold means that sufficiently locally light, will have speed c, at all times, and all places (there is flat Minkowski tangent plane). I don't think we are really disagreeing here.
This is different from the effect of matter on lightspeed, which occurs for local measurements.
Agerhell said:No, we do not really disagree. The different ways in which light interacts with matter, thus affecting lightspeed is of course not a relativity issue. The velocity of light in a spherically symmetric gravitational field varies, if I am not misinformed?, with the factor:
[itex]\sqrt{1-\frac{2GM}{rc^2}}[/itex],
but time slows down with the same factor, so using a local clock the velocity is always c. I am not exactly sure how one would correctly add up the slowdown of the light due to the Earth, the Sun and so forth, perhaps someone could inform me?
If you send an electromagnetic signal to some far off place away from the sun and even the milky way, such as the andromeda galaxy, then the velocity of light in the space between the galaxies where there are no significant masses nearby, even though always equal to c locally, should be higher than in our solar system.
Does anyone have any estimate on how high the velocity of light would be under such circumstances, compared to here?
PAllen said:We agree on the observation that a local measurement of lightspeed in a vacuum is always c. You attach signficance to a coordinate speed of light that I don't feel has any fundamental significance. At any point, if I set set up Fermi-Normal coordinates, coordinate speed is c. Why should your choice of coordinates have more fundamental meaning than mine?
PAllen said:It is true that if you measure 'ruler distance' divided by 1/2 round trip time over significant distances in curved space time you can end up with speeds either greater than c or less than c. This is a real physical prediction, however I think it has never been measured. (Non light based distance measures of sufficient length in regions of sufficient gravity have not been achieved, I think).
When one talks about light speed variation over great distances, in practice, one is talking about choice coordinate conventions which could just as easily be made differently.
Agerhell said:If, for instance, the sun had been a really compact object like a black hole but with the same mass as now then, at some small radial distance (A) from the sun, the velocity of light would be only half of the velocity of light at the radial distance from the Sun to the Earth, due to the gravity of the Sun. Local measurement would measure the same c in both cases, but the velocity of light, if Sun is used as a reference point, will still be only half as high at A. I am not saying that the velocity of light at a certain gravitational potential has a more fundamental meaning than that at another potential, but still If you want to calculate how long time it takes to send a signal through the solar system, and do it correctly, you should consider that light travels sligthly faster at the radial distance of Pluto than at that of Mercury... At least that is what I think... Let us use whatever coordinates Nasa uses to calculate the ephemerides, the position and velocity of the bodies of the solar system. A cartesian coordinate system based on the barycentre of the solar system?
I think it has been measured, originally buy a guy named Shapiro, thus it is sometimes called the "Shapiro effect". When sending light from the Earth to Venus and Venus is on the other side of the Sun but the three is almost on a line, it takes longer to send signals than if the Sun had not been so close to the path of light.
Well I assume that the variation of the speed of light within spherically symmetric (probaly also other shaped) gravitational potentials is a real physical effect and not something one could make go away with a clever choise of coordinate system...
PAllen said:I agree if you use spherically symmetric coordinates in which planetary orbits take a particular simple shape, you see radial variation in light speed. However I can use other coordinates that distribute deviation from flatness completely differently.
PAllen said:2) I can choose a preferred radial line out from the sun, and measure distances and times from this line such the speed of light near this preferred radius is constant, for arbitrary precision, for some distance from this preferred radius for some time from a starting time. (This follows from the fact that a line has no curvature, and that I can make the metric essentially flat for a thin 4-tube around a chosen spacelike path - the initial radius at some 'synchronization time'). Now I will conclude that the speed of light does not vary radially. Instead it varies over time and also with distance from this initially chosen radial line (in a rather complicated way). Admittedly, this would be a strange coordinate system, but according to GR, equally valid to the standard one. And its interpretation of variation of light speed over spacetime is just as valid.
