Is the subset of C([0,1]) with f(1/2) = 0 a subspace?
  • Thread starter Thread starter Alex6200
    Function Subspace
The subset W = {f ∈ C([0, 1]): f(1/2) = 0} is confirmed to be a subspace of C([0, 1]). This conclusion is reached by demonstrating that for any functions f and g in W, their sum (f + g) also satisfies the condition (f + g)(1/2) = 0, and that for any scalar a, the function (af) also satisfies (af)(1/2) = 0. The proof is formalized by showing that both conditions for a subspace are met, thus establishing W as a valid subspace.
  • Understanding of continuous functions on a closed interval, specifically C([0, 1])
  • Knowledge of vector space properties and definitions
  • Familiarity with linear combinations of functions
  • Ability to construct formal mathematical proofs
  • Study the properties of vector spaces and subspaces in linear algebra
  • Learn about the implications of linear combinations in function spaces
  • Explore the concept of intersections of subspaces and their properties
  • Practice writing formal proofs in mathematics, focusing on clarity and logical structure
Students and educators in mathematics, particularly those focusing on linear algebra and functional analysis, as well as anyone interested in understanding the properties of function spaces and subspace criteria.
Alex6200
Subspace of a Function?!?
{f \in C([0, 1]): f(1/2) = 0}
Is this subset of C([0,1]) a subspace?
C[0,1] be the set of all functions that are continuous on [0, 1].
(f + g)(x) = f(x) + g(x)
(af)(x) = a*f(x)
Okay, so if f is in the subspace of C than any linear combination of functions in the set should also be in the set. I understand that f is just the set of all functions for which f(1/2) = 0, but how am I supposed to answer the question formally?
Intuitively I understand that you might have two functions in the set, like:
f(x) = x - 1/2
g(x) = x2 - 1/4
And I know that:
(f + g)(x) = x2 + x - 3/4
(f + g)(1/2) = 1/4 + 2/4 - 3/4
(f + g)(1/2) = 0
Showing that it is a subspace if I just use those two functions. But how do I generalize my results to include any functions that could be in the set?
Take any two functions f and g that are continuous on [0, 1]. It's given that f(1/2) = 0 = g(1/2). What about their sum? What willl (f + g)(1/2) be? What will a*f(1/2) be for any scalar a?
I definitely understand the logic of what you're saying. If f(1/2) and g(1/2) are both 0, then (f + g)(1/2) will also be zero.
But I don't know how to say it formally.
Let's give the subset a name:
W = {f \in C([0, 1]): f(1/2) = 0}
If f and g are in W, what does that mean, and what can you say about (f + g)?
If f is in W, what can you say about (af), where a is a constant?
The way I did it was:
W = {(f in C[0, 1]): f(1/2) = 0}
f(x) and g(x) are in the subset W
if W is a subspace then h(1/2) = 0 for h(x) = a*f(x) + b*g(x)
h(1/2) = a*f(1/2) + b*g(1/2)
h(1/2) = a*0 + b*0
h(1/2) = 0
So W is a subspace.
Does that seem about right?
That's nearly textbook perfect. All you missed is
[if W is a subspace then h(1/2) = 0 for h(x) = a*f(x) + b*g(x)
This is true, except that's not what you want to prove. What you should have written is the converse: If h(1/2)=0 for h(x) = a*f(x) + b*g(x), then W is a subspace.
Thanks. Can I ask if I did another question correctly?
The question asks:
Show that if S and T are subspaces of a vector space V, then S \cap T is also a subspace.
My Solution thus far
S \cap T \subset S and S is a subspace, so S \cap T is also a subspace.
That almost seems too easy though, but it seems obvious that if a set is a subspace, then any part of that set must also be a subspace.
The trouble is that not everything that belongs to a vector space (or subspace) is a subspace of that vector space (subspace). For example, R^2 with the usual rules for vector addition and scalar multiplication is a vector space, and the line x = 1 is in that space, but that line is not a subspace.
You have to show that if u and v are elements of S \bigcap T, then u + v is in S \bigcap T, and so is au, where a is any scalar (which is one way to show that 0 is in S \bigcap T).
Okay, here's how I approached the problem.
u is in S \cap T
v is in S \cap T
a, b are scalars
If S \cap T is a subspace, then au + bv is in S \cap T.
If au + bv is in S \cap T, then au + bv is in both S and T.
au + bv is in S because S is a subspace and au + bv is in T because T is a subspace.
There S \cap T is a subspace.
u is in S \cap T
v is in S \cap T
a, b are scalars
You got your if statements backwards. While
Is true, what you did is prove au+bv is in both S and T, so what you should write is
S \cap T is a subspace only if au + bv is in S \cap T.
au + bv is in S \cap T, only ifau + bv is in both S and T.
u is in S \cap T
v is in S \cap T
a, b are scalars
To concur with Office_Shredder, but saying it a little differently, don't start off by saying "If <what you're trying to prove>". Instead, that should go at the end of your logical progression.
IOW,
if u in S \cap T, v in S \cap T, a, b are scalars, where S and T are subspaces of a vector space then <your argument here> ==> S \cap T is a subspace.
Do you get what I'm saying?
Yeah. This is like my 2nd or 3rd proof so admittedly I'm a little rusty on how to formally write out the proofs.
