Is the Work-Energy Theorem Applicable to Satellite Orbital Movement?
The discussion revolves around the application of the Work-Energy Theorem to a problem involving a satellite in circular orbit around the Earth. The original poster presents a scenario where they are tasked with calculating the total mechanical energy of the satellite and the work required to move it to a new orbit. There is a focus on understanding the differences in results when using the Work-Energy Theorem versus the conservation of energy approach.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants explore the differences between using the Work-Energy Theorem and the conservation of energy equation. Questions arise regarding the inclusion of potential energy and the implications of gravitational forces in these calculations. Some participants express confusion about whether potential energy should be considered part of the total energy in the context of the Work-Energy Theorem.
The discussion is ongoing, with participants providing insights and clarifications regarding the application of the Work-Energy Theorem. There is an exploration of the relationship between work done by conservative forces and potential energy, as well as the conditions under which energy conservation applies. Multiple interpretations of the problem are being examined, but no consensus has been reached yet.
Participants note the importance of understanding the definitions of energy, particularly in relation to potential energy and work done by conservative forces. There is also mention of the implications of using non-conservative forces in energy conservation discussions.
jwu
A satellite of mass M is in a circular orbit of radius R around the earth.
(a) what is its total mechanical energy (where Ugrav is considered zero as R approaches infinity)?
(b) How much work wouldbe required to move the satellite into a new orbit, with radius 2R?
(a)
mv²/R=GMm/R² →→ mv²=GMm/R →→ K=1/2mv²=GMm/(2R),
therefore, E=K+U=GMm/(2R)+(-GMm/R)=-GMm/(2R)
(b)
Here's where I got stuck :
This is the correct answer on the book:
From the equation Ki+Ui+W=Kf+Uf,
W=(Kf+Uf)-(Ki+Ui)
=Ef-Ei
=-GMm/(2(2R))-(-GMm/(2R))
=GMm/(4R)
Here's what I did, instead of using the equation above, Ki+Ui+W=Kf+Uf, I used the WORK-ENERGY THEOREM. But it came out the different answer.
W=Kf-Ki=GMm/(4R)-GMm/(2R)=-GMm/(4R) , the same magnitude but different sign.
What's wrong with using WORK-ENERGY THEOREM?
As above.
Hi jwu! :smile:
Have I understood this correctly …
instead of using W = Kf - Ki + Uf - Ui,
you just used the "work-energy theorem", W = Kf - Ki ?​
ok, for the work-energy theorem, you have to include the work done by all the forces, and that includes the force of gravity, so you would have Wrocket + Wgravity = Kf - Ki … the same as the book's answer.
The only trick is that the book has replaced Wgravity by -PE.
You see, PE is just another name for (minus) work done by a conservative force (such as gravity) … you can either use work done, or you can use (minus) PE. :wink:
(btw, you have to be careful about what you regard as "energy" …
from the PF Library on potential energy …
Is potential energy energy?
There is confusion over whether "energy" includes "potential energy".
On the one hand, in the work-energy equation, potential energy is part of the work done.
On the other hand, in the conservation-of-energy equation (and conservation of course only applies to conservative forces), potential energy is part of the energy.)​
think of it:
if the distance increases how the P.E., K.E., and T.E varies?
tiny-tim said:
Hi jwu! :smile:
So basically you mean the work-energy theorem and the conservation of energy equation are interchangable at some point?
For conserved forces (such as gravity), yes.
But for most applied forces (such as rockets, bits of string, etc), no … conservation of energy can't apply to them because, with them, energy isn't conserved. :wink:
  • · Replies 30 ·
