- 4,870
- 1,534
- TL;DR
- I need to cut keyways in a new shaft to replace the broken old shaft. It's easier for me to cut straight keyways into the shaft than a woodruff.
I have a broken 1.25 inch diameter shaft. One end has a large pulley attached I'm guessing around 16 inches in diameter with a pair of setscrews and a straight key to hold it to the shaft. The key is a square 5/16 inch key.
The other end of the shaft has a hub with a keyway cut into it the entire length of the bore. This is where the woodruff key is used also with a pair of setscrews. The width of this key is also 5/16 inch. This hub is attached to a sprocket with two bolts used as shear bolts. The sprocket is able the freewheel on the shaft in the event that the bolts shear. The hub is near the end of the shaft. It is easier for me to cut a straight keyway in rather than a keyway for a woodruff key so that is what I'd like to do. Opinions?
