Is there any easier way to attack this problem?(perfectly elastic collision)
The discussion focuses on solving a perfectly elastic collision problem involving two spheres with masses of 0.1 kg and 0.05 kg, respectively. The initial height of the left sphere is calculated using the formula h = l(1 - cosθ), resulting in a height of 0.14 m. The velocities before and after the collision are derived using conservation of mechanical energy and momentum equations, yielding final velocities of 0.552 m/s for the left sphere and 2.21 m/s for the right sphere. The maximum angles after the collision are determined to be approximately 8.28 degrees for the left sphere and 42.3 degrees for the right sphere.
  • Understanding of conservation of mechanical energy
  • Familiarity with momentum conservation principles
  • Knowledge of trigonometric functions and their applications in physics
  • Ability to manipulate equations involving mass, velocity, and height
  • Study the derivation of conservation of mechanical energy in elastic collisions
  • Learn about momentum conservation in two-dimensional collisions
  • Explore the application of trigonometric functions in physics problems
  • Investigate the effects of varying mass ratios on collision outcomes
Students studying physics, particularly those focusing on mechanics and collision theory, as well as educators seeking to enhance their teaching methods in these topics.
XwakeriderX
(see attachment)
The work the did gives the correct answer but i do not understand where a lot of that stuff came from! My first question about the work is how they derived 1/2[(m_1)((v_i)_1)^2] =m_1gh
Below is the solution
length of the string l =1.5 m
angle =25 degrees
height h_1 =h_2 =h =l(1-cosθ) =0.14 m
mass of the left side sphere m_1 =100 gm =0.1 kg
mass of the right side sphere m_2 =50 gm =0.05 kg
when left side ball is at height h (mass m_1) ,apply conservation of mechanical energy ,we get
velocity of the left side ball (v_i)_1,just before the collision (v_i)_1=sq.root (2gh) =1.657 m/s
after the collision:
b)
(v_f)_1 =[m_1-m_2/m_1+m_2](v_i)_1
substitute the given data in above equation we get,
velocity of the left side ball after the collision =(v_f)_1 =0.552 m/s
(v_f)_2 =[(2m_1)/m_1+m_2](v_i)_1
velocity of the right side ball after the collision =(v_f)_2 =2.21 m/s
c)
after the collision ,the height of m_1 is
( h_f)_1 =l(1-cosθ) =[[(v_f)_1]^2]/2g
(1-cosθ) =[[(v_f)_1]^2]/2gl
cosθ =1-[[(v_f)_1]^2]/2gl
maximum angle for left side ball ,θ =8.26 deg≈ 8.28 deg
after the collision ,the height of m_2 is
( h_f)_2 =[[(v_f)_2]^2]/2g
cosθ =1-[[(v_f)_2]^2]/2gl
maximum angle for right side ball ,θ =42.25 deg≈ 42.3 deg
How about instead of worrying about how someone else solved the problem, you start from first principles yourself to solve the problem? In sequence:
1. What is the energy of each ball just before they're released?
2. What is the energy of each ball just before they collide?
3. What is the momentum of each ball just before they collide?
4. What is the total momentum of the system before they collide? (express as a formula)
5. What is the total momentum of the system after they collide? (express as a formula)
6. What is the total energy of the system after they collide?
7. What is the momentum and energy of each ball just after they collide?
8. What is the energy of each ball when they are at the top of the swing after the collison?
By finding expressions for everything in order and applying the conservation laws, you will determine the angles for which you are asked.
Okay ill try that thanks!
