Is there any general formula for strings?
12 replies · 2K views
Physicsissuef
For example:
what is the formula of this string -1,3,-5,7,-9,...?
Thanks.
Defennder said:
Why is this called a string?
A "string" is any list of symbols so that qualifies as a string, although most of us might prefere the more precise term "numerical sequence".
For example:
Thanks.
Remove the negative signs: 1, 3, 5, 7, 9, ... Can you find a simple formula for that? (How do you normally write odd numbers?)
Now remember that (-1)n alternates sign.
(2n-1), and the final (-1)n(2n-1). Thanks for the help.
And what about this string:
2,5,9,14,20...
a2-a1=3
a3-a2=4
a4-a3=5
a5-a4=6
an-an-1=n+1
Let me reiterate Defennder's point: this is not really "Abstract Algebra" nor "Linear Algebra". It looks pretty much like "pre-calculus problems".
You have calculated the "first difference". Now what is the "second difference"? That is, what is 4- 3, 5- 4, 6- 5? Do you see that all "third differences" are 0? Do you know "Newton's divided difference formula"? In this particular case, the difference between the values of n is 1 so we have
[tex]f(n)= f(0)+ \Delta f(0) n+ \frac{\Delta^2 f(0)}{2}n(n-1)+ ...[/tex]
(and here the "..." is 0 because all higher differences are 0.)
Sorry, I didn't know where to put this topic. And no, I didn't learn about Newton's divided difference formula. What is second and third difference? How to calculate second and third difference?
Edit: Ok, I understand the second and third difference. Just what I need to substitute for?
Write it like this:
[tex]\begin{array}{ccccc}n & f(n) & \Delta f(n) & \Delta^2 f(n) & \Delta^3 f(n) \\ 0 & 0 & 2 & 1 & 0 \\1 & 2 & 3 & 1 & 0 \\ 2 & 5 & 4 & 1 & 0\\ 3 & 9 & 5 & 1 \\ 4 & 14 & 6 \\ 5 & 20 \end{array}[/tex]
The first column are the "n" values. The second column are the sequence values: f(1)= 2, f(2)= 5, f(3)= 9, f(4)= 14, and f(5)= 20, as you gave. The third column are the "first difference" values also as you gave: the difference between two consecutive values in the second column. The third column is the "second differences": the difference between two consecutive values in the second column. Because those are consecutive integers, 2, 3, 4, 5, the "third differences", the difference between two consecutive values in the third column, is always 1. All further diffences, then, will be 0 and can be ignored.
I put in the top row, n= 0, by working backwards: if 3-a= 2, then a= 2; if 2- a= 2, then a= 0.
Now, as I said before, Newton's divided difference formula says
Looking at the chart, f(0)= 0, [itex]\Delta f(0)= 2[/itex], and [itex]\Delta^2 f(0)= 1[/itex]
Therefore,
[tex]f(n)= 0+ 2n+ \frac{1}{2}n(n-1)[/tex]
Simplify that and check its values for n= 1, 2, 3, 4, and 5.
Ok, now I completely understand. Thanks for the post. Can I use this formula to find other strings or this is special case?
