Undergrad Is there any way to get a geometrical description of QM
  • Thread starter Thread starter nashed
    Geometrical Qm
The discussion centers on the challenge of obtaining a geometrical description of quantum mechanics (QM) that aligns with our 3D perception of reality, as opposed to the abstract Hilbert space framework. Participants express skepticism about the feasibility of such a description, particularly in light of Bell inequalities, which suggest limitations in classical interpretations. While some argue that classical mechanics can provide a geometrical perspective, they acknowledge that QM often defies these classical analogies. Visual representations, like atomic orbitals, are mentioned as attempts to illustrate quantum phenomena, but they fall short of capturing the full complexity of QM. Ultimately, the consensus leans towards the idea that a comprehensive geometrical description of QM may not be possible in general.
nashed
This is maybe one of my greatest gripes with QM, I have never seen a geometrical description of it.
What I mean by geometrical, is a description of the given object in the 3D world we live in, not a description in Hilbert Space, is such a description even possible in principle? I've been studying about Bell inequalities and they seem to suggest that maybe not, but I figured I might as well ask.
Can you have such a description in classical mechanics?
In classical mechanics in the Newtonian formulation the "real" physical space in which the motion of material objects (such as me or the OP) is "seen" is mapped onto R^n (n=1,2 or 3) as an affine space.
dextercioby said:
In classical mechanics in the Newtonian formulation the "real" physical space in which the motion of material objects (sich as me or the OP) "seen" is mapped onto R^n (n=1,2 or 3) as an affine space.
But the description of the objects in the real space, say a particle, requires you to use a different space, for a particle it's ##\mathbb R^6##.
Yes, as you put velocities as well. I only referred to positions.
Thing is, velocity is closely related to position, and eve if it's not, you've got the Newtonian formulation which happens entirely in 3D space... I'm wondering if such a formulation is even theoretically possible for QM.
Symplectic Geometry?
https://www3.nd.edu/~eburkard/Talks/GSS%20Talk%20110413.pdf
I think the problem is the OP may not quite understand the modern conception of geometry.
Thanks
Bill
nashed said:
This is maybe one of my greatest gripes with QM, I have never seen a geometrical description of it. What I mean by geometrical, is a description of the given object in the 3D world we live in, not a description in Hilbert Space ...
You want a way to visualize electrons, protons etc? Classically they would be little spheres moving around under the influence of forces, like billiard balls, or planets. But in QM that picture is wrong (although not totally useless). Instead there's a wave function associated with the particle which is impossible to visualize entirely. But it can be attempted. The best examples are from chemistry. You've seen pictures of the atomic orbits of hydrogen atom, for instance? They look like spheres, barbells, etc. There are animations of such things. See this other current thread, https://www.physicsforums.com/threads/gluon-field-fluctuations.898565/, for pictures of "gluon fluctuation", a similar idea. This type of graphics represents QM functions visually (3-d). It's far from complete, leaves out essential info like (for instance) the complex nature of the wave. But it's probably about the best you can do.
Likes vanhees71
Doesn't the position basis do what the OP wants? The position of a particle is determined by the potential well in physical space.
Not sure I get the question, the most newb problems are defined and solved in real space, the complex numbers disappear when the complex conjugate it taken to get position, expectation value...even the integrals are defined with real space limits.
The uncertainty principle can be derived by using geometrical arguments, i.e. slit experiment.
Not for QM in general. Under conditions where the physics can be approximated classically, such a description can (usually) be given. But under conditions where a classical approximation breaks down, the ability to give a description of the kind you are talking about breaks down too. That is to be expected: QM was developed in large part because this classical type of description simply didn't work for certain phenomena.
I don't know if this helps (it's a bit more complicated than need be): http://www.techlib.com/science/bells_inequality.htm
  • · Replies 36 ·
  • · Replies 130 ·
10K
  • · Replies 80 ·
  • · Replies 43 ·
9K
  • · Replies 69 ·
  • · Replies 37 ·
14K
