Undergrad Linear Subspace with Neutral Element in Brazilian Portuguese and Spanish
  • Thread starter Thread starter LCSphysicist
    Linear Subspace
The discussion revolves around the linear subspace defined by W = {f(t) | f(0) = 2f(1)} and the challenge of proving the existence of a neutral element within this space. Participants emphasize the need to identify the zero function, which serves as the neutral element, and clarify that it must be a function itself. The conversation highlights the importance of understanding the properties of subspaces, specifically closure under scalar multiplication and vector addition. It is noted that the context of the larger vector space is crucial for determining the characteristics of the subspace W. Overall, the discussion seeks to deepen understanding of linear algebra concepts related to function spaces.
LCSphysicist
The answer say yes, but i don't know how to prove the neutral element.
What would be the zero?
i have no idea :|, the answer is literally "yes", just it.
You mention the word subspace. Of what vector space is this a subspace? What is the zero in the larger vector space? Can you conclude something about the zero of the subspace as well?
What does ##f(t)## stand for? A certain number at a point ##t##, or what does it mean?
My guess is that it is the usual abuse of notation.
I know. I just want to get the OP think about it. The question is trivial once it is understood, so it is all about understanding, not answering.
Likes member 587159
Oh i forgot, subspace of the P(R) space of the real polynomials. You know:
The conjunt of reals Polynomials n deegre or smaller more the nule polynomial.
Yes, indeed is a trivial question, actually it's in a book introductory to linear algebra, but i still don't understand how to prove this item.
In order to prove this property, you only have to show that zero is in that space. Now what is zero in this context?
Another property is to show that if ##f(t) \in W## and ##\lambda \in \mathbb{R}##, then ##\lambda \cdot f(t)## must be in ##W##. If you had shown this, then what if ##\lambda =0##?
What's a conjunt? What does nule mean? I'm trying to figure out what that sentence was intended to mean.
Likes Delta2
I assume the OP may be a native Spanish spraker. "Conjunto" is Spanish for "Set" and "Nulo" is Spanish for null. And for others, I assume, per abuse of notation, f(t) is a function. I assume the 0 vector here would be the 0 function/polynomial.
Likes Delta2
Ah, now it makes more sense.
Yes, the first mistake was not including this in the original post: ##\{f(t)\in ? | f(0) = 2f(1)\} ##. Given that, the properties of a subspace are inherited from the superspace. You can easily list the required properties one-by-one saying that each one is satisfied. The only thing left is to show that the subspace is closed under the operations of addition and of multiplication by a real.
It's always helpful to say what space you are dealing with. If it's a vector space V that contains the functions f in the expression
then this should be written
{f ∈ V | f(0) = 2f(1)}
and V ought to be defined in terms of what functions it contains (domain, codomain, properties) and what is the field F of scalars (the reals or the complexes).
(Note that I rewrote your "f(t)" as just "f", because f means the function itself that is a vector in V, but f(t) means the value of that function after it has been evaluated at some input t.)
But to decide whether your set is a subspace of V, the things to check is whether a) the sum f + g of two vectors f and g in your set also belongs to the set, and b) whether the product αf of an f in your set by a scalar α ∈ F is also in your set.
Likes Delta2
If you are dealing with a vector space whose elements are functions, the zero vector ( neutral element) must be a function. What function is it?
Perhaps you aren't remembering that there can be constant functions. For example, the function f(x) = 3 is a constant function. It is a function even though its value isn't different for different values of x.
Question: Would the nature of the answer change if the superspace of ##W## were instead just the space of continuous functions, or maybe just another vector space consisting of real-valued functions defined at ##x=0## and ##x=1##?
No. As long as the superspaces have the same "operations".
Likes Eclair_de_XII
A subspace of a vector space has two properties:
It is "closed under scalar multiplication" and "closed under vector addition".
Here the subset is the set of all functions, f, such that f(0)= 2f(1).
"Closed under scalar multiplication". If a is any number then does af satisfy af(0)= 2af(1)?
"Closed under vector addition". If f satisfies f(0)= 2f(`1) and g satisfies g(0)= 2g(1) does f+ g satisfy f(0)+ g(0)= 2(f(1)+ g(1))?
Likes roam, Delta2 and atyy
The problem in this question is, actually, it say more nothing, just it. So we can't give a answer with just this informations, right?
Voce acertou, mas eu sou brasileiro XD
You're right, but i am brazillian XD
sorry by my "portuenglish"
Likes Delta2
No, it is very easy to answer the questions I asked before and that is sufficient to answer the question.
Likes atyy
Yes. I also speak Spanish and this is true.
But read above where he said he's Brazilian.
Spanish and Portuguese share a lot of words. Brazilian Portuguese is a dialect of Portuguese.
Likes Delta2
  • · Replies 19 ·
