Is this even solvable? Kinematics.
  • Thread starter Thread starter tophat
    even Kinematics
3 replies · 2K views
tophat
A ball is thrown vertically upward from ground level with an initial velocity V0. The ball rises to a height, h, then lands on the roof of a building of height 1/2h. The entire motion requires 10s. Find the height, h, and the initial velocity, V0.
Kinematics.
I can't come up with anything, I'm using a final velocity of 0 m/s when running everything through and none of the values are making sense. I just need to know if it's actually solvable for real values. I'm in a hurry for work right now, but I will check back later.
I'm using: t2: 10s
t0= 0s
v1= 0 m/s (turning point)
a = -g
y1= h
y2= 1/2h
v2= 0 m/s (stop)
y0 = 0 m
I think using that as your final velocity is your main problem so far. Yes, the final velocity will be zero once the ball hits the building and stops, but you can't use that value because the process of the object stopping isn't free-fall motion. You have to use the value of the velocity just before it lands as the final velocity.
You've just jotted down some trivial equations so far; you haven't actually written the proper kinematic equations involving distance as a function of time.
Yes, there is a numerical solution for V0 and h, and there is a fair amount of algebra and logical deduction involved in obtaining it.
[tex]s(t)=v_0t-1/2gt^2, s(t)_{\text{max}}=h=f(v_0,g),[/tex] solve [tex]s(t)=\frac{h}{2}[/tex] for t, and then plugin t=10s, get the larger answer
