aisha said:
how come my teacher says that y^2=x+1 is not a function is that fair?
Isnt that a trick question how are u supposed to know whether to rearrange it or not? Normally it would be written y= not y^2=
Whether it's fair or not actually depends on what your teacher told you in lectures, and/or what's written in your textbook.
Typically in math classes if it's written like:
[tex]y=\sqrt{x}[/tex]
It's taken to be a function because the
assumption or
convention is that we only take the positive value of the square root. However, sometimes that
convention isn't made clear. Also, this isn't always the
convention if you came up with this relationship from a word problem! So it can be a source of real confusion for someone starting out in mathematics.
On the other hand, if the relationship is given as:
[tex]y^2=x[/tex]
Then in order to rearrange this in terms of [itex]y=\sqrt{x}[/itex] we need to take the square root of both sides. Whenever we take the square root of both sides we need to keep in mind that there are both positive and negative roots. So we need to write the result of taking the square root of both sides as:
[tex]y=\pm \sqrt{x}[/tex]
This is different from [itex]y=\sqrt{x}[/itex].
Is this fair? Well, sure it's fair. In one case you were given a conventional square root
function which is taken by convention to be positive . In the other case you manipulated the relationship after it was given to you, and when you did that you need to consider the consequences.
However, I honestly believe that math instructors could explain this a little better sometimes rather than springing it on everyone like a bad joke.
I honestly believe math instructors don't often explain this stuff well in the early going. They kind of let the students discover these things along the way which isn't necessarily the best pedagogy IMHO. Explaining conventions early on is always a good idea I think.
So this whole topic isn't so much about the rules of mathematics as it is about the style of pedagogy. I mean, mathematics is hard enough for most people to learn. Confusing the issue by assuming conventions or not making them clear in the early going doesn't help matters much. I have a really big bone to pick with a lot of math professors on the issue of pedagogic methodologies to be quite honest.
