Isomorphism of relatively prime groups
The discussion revolves around proving the isomorphism between the group Z(mn) and the direct product of the groups Z(m) and Z(n), given that m and n are relatively prime integers. Participants explore properties of these groups, particularly focusing on their structure and characteristics.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the properties of Z(mn), questioning whether it is abelian and cyclic. They explore the implications of the groups being generated by a single element and consider examples like Z2 x Z3 to understand the structure better.
The discussion is active, with participants sharing insights about group generation and structure. Some have suggested testing specific elements to determine if they can generate the entire group, while others are seeking clarification on definitions and properties of the groups involved.
Participants express uncertainty about the properties of Z(mn) and the nature of isomorphisms, indicating a need for foundational understanding of group theory concepts. There is mention of needing to define an isomorphism between Z6 and Z2 x Z3, which suggests a focus on specific examples to illustrate broader concepts.
PennState666
Allow m,n to be two relatively prime integers. You must prove that Z(sub mn) ≈ Z(sub m) x Z(sub n)
if two groups form an isomorphism they must be onto, 1-1, and preserve the operation.
since m and n are relatively prime, the gcd(m, n) = 1.
mhm, very stumped from the start.
What do you know about the group Z(sub mn)? What are some facts about it? Is it abelian, etc.?
Isomorphisms isn't my thing, I do not know many facts about Z(sub mn). I can say the contents of Z(sub mn) are {[0],[1], [2],... [mn]}. generated by a single element? I am not sure...Abelian? yes i believe so...
Yes, generated by a single element is the key. In other words, it's a cyclic group. (Side note: cyclic groups are always abelian, but you don't need that fact for this problem.)
So if Z(sub mn) is isomorphic to Z(sub m) x Z(sub n), then that group would also have to be cyclic, right? Can you show that Z(sub m) x Z(sub n) is cyclic?
mhmm i believe so, but i don't know where to start since I am dealing with a cross product...
If you had to guess at which element of ZmxZn generated the whole group, what would it be?
If you're not sure, try some small examples like Z2xZ3 or Z3xZ4 and see what you can come up with
What would the elements of Z2 x Z3 look like again?
Ordered pairs (a, b) such that a is from Z2, and b is from Z3.
Well, if A and B are any sets (whether or not they have a group structure), then what is the definition of A x B? This is called the Cartesian product of A and B. The elements are simply ordered pairs of the form [itex](a,b)[/itex], where [itex]a \in A[/itex] and [itex]b \in B[/itex].
And if A and B are groups, then there's a natural way to define a group operation on A x B.
Surely this is discussed in your textbook or lecture? There's no way you can proceed with this problem without first understanding what the group is.
yes of course I just wanted to be refreshed and reassured...
Z2 x Z3 = {([0],[0]), ([0],[1]), ([0],[2]), ([1],[0]), ([1],[1]), ([1],[2])}...
I cannot grasp how this could be generated by a single element though?
Look at the six elements. In order for the group to be generated by one element, clearly that element can't have a [0] in either of the two positions of the ordered pair. So that only leaves two candidates: either ([1],[1]) or ([1],[2]). Why not try each and see if it works? Just add it to itself over and over and see if you can generate the group.
the generator for the group Z(sub 2) x Z(sub 3) = <[1],[1]> and since the operation is addition, the generator for a group in the form Zn x Zm = <[1], [1]>. so Zn x Zm is cyclic and abelian.
OK, good. Note that <[1],[2]> also generates the group.
So Z2 x Z3 is cyclic, and I assume you observed that it has order 6. That looks promising, because Z6 is also cyclic with order 6.
Now you need to define an isomorphism [itex]\phi: Z_{6} \rightarrow Z_2 \times Z_3[/itex] between the groups. As a first step, I suggest choosing a generator [itex]g[/itex] for [itex]Z_6[/itex] and defining [itex]\phi(g)[/itex].
