[itex]\int tan^{5}x dx[/itex] , Two Methods, are both correct?
  • Thread starter Thread starter Lebombo
7 replies · 2K views
Lebombo
Are both methods and final results correct?[itex]\int tan^{5}xdx[/itex]Method 1:
[itex]\int tan^{3}xtan^{2}xdx[/itex]
[itex]\int tanx^{3} (sec^{2}x - 1) dx[/itex]
[itex]\int tan^{3}xsec^{2}x dx - \int tanxtan^{2}x dx[/itex]
[itex]\int tan^{3}xsec^{2}x dx - \int tanxsec^{2}x dx + \int tanx[/itex]
[itex]\int u^{3}du - \int u du - \int \frac{1}{u} du[/itex]
[itex]\frac{1}{4}tan^{4}x - \frac{1}{2}tanx - ln|cosx| + C[/itex]
Method 2:
[itex]\int tan^{4}tanx[/itex]
[itex]\int (sec^{2}x - 1)^{2}tanxdx[/itex]
[itex]\int (sec^{4}x - 2sec^{2}x + 1)tanx dx[/itex]
[itex]\int (u^{2} - 2u +1) du[/itex]
[itex]\frac{1}{3}tan^{3}x - tan^{2}x + tanx + C[/itex]
Although Method 2 is much easier and a lot more straightforward, both methods look correct, despite having different answers.
I don't understand what you are doing.
Tip:
Make absolutely clear WHAT substitution you are using!
Here is how I would do it:
[tex]u=\tan(x)\to{du}=\sec^{2}(x)dx=(u^{2}+1)dx \to{dx}=\frac{du}{u^{2}+1}[/tex]
Thus, you are to evaluate the integral:
[tex]\int\frac{u^{5}}{u^{2}+1}du= \int\frac{u^{3}(u^{2}+1-1)}{u^{2}+1}du =\int{u^{3}}du-\int\frac{u^{3}}{u^{2}+1}du[/tex]
The last integral can be written as:
[tex]-\int\frac{u^{3}}{u^{2}+1}du=-\int{u}du+\int\frac{u}{u^{2}+1}du[/tex]
Thus, collecting together, you'll have:
[tex]\frac{1}{4}\tan^{4}(x)-\frac{1}{2}\tan^{2}(x)+\frac{1}{2}\ln(\tan^{2}(x)+1)[/tex]
where the latter term can be simplified to [itex]-\ln|\cos(x)|[/itex]
Thus, NEITHER of your expressions are correct, although the first comes closer.
Method 2 is also incorrect. Your u-substitution, ##u=\sec x## lost something in the translation. With this, you should get ##du = \sec x \tan x\, dx##, but you apparently used ##du = \tan x \, dx##.
Thank you Arildno,
Method 1:
[itex]\int tan^{3}xsec^{2}x dx - \int tanxsec^{2}x dx + \int tanx dx[/itex]
I did three separate substitutions.
For [itex]\int tan^{3}xsec^{2}x dx[/itex]
I let u = tanx, and [itex]du = sec^{2}x dx[/itex]
For [itex]\int tanxsec^{2}x dx[/itex]
For [itex]\int tanx dx[/itex],
I solved by writing as [itex]\int \frac{sinx}{cosx} dx[/itex]
and then letting u = cosx, so [itex]-du = sinx dx[/itex]
This produces:
[itex]\int u^{3} du - \int u du - \int \frac{1}{u} du[/itex]
Well, int udu goes to 1/2u^2, doesn't it?, rather than your 1/2u?
