đť‘— - đťś” method alternating current circuit help
The discussion revolves around calculating current and phase angle in an alternating current circuit using the đť‘— - đťś” method. Participants are examining the relationships between real and imaginary components in complex numbers related to circuit analysis.
  • Participants share their calculated values for current and phase angle, questioning the accuracy of the phase angle being exactly 90 degrees. There is discussion about the significance of the magnitude of real and imaginary components in relation to the phase angle.
Multiple participants have confirmed similar results for the current's magnitude and angle, while also expressing caution regarding the phase angle's approximation. Suggestions for tools to assist with complex number calculations have been offered, indicating a productive direction in the discussion.
There is an ongoing examination of the implications of the relative sizes of the real and imaginary components in the context of the calculations being performed.
magnuol
I'm supposed to calculate the current and the phase angle.
Can someone please tell me if this is the correct solution?
I'm supposed to calculate the current and the phase angle. Can someone please tell me if this is the correct solution?
242572
242573
242574
I got the same answer as you. I did not follow every step of your work. While the angle does round to 90 degree, I think it's important to know that it can never equal 90, and will be slightly less.
You got the same answer regarding the value of the current as well?
Your current magnitude and angle are both correct.
Does it seem accurate that the order of the real component (a) is 10^(-7) when the imaginary component (b) is that much bigger?
Yes. That's why the phase angle is so close to 90°.
Yes, I got the same magnitude and angle for current I
For whatever it's worth, I got the same real and imaginary parts for the current as @magnuol .
Hey @magnuol if this is something you will be working with, then you could benefit from finding a way to work out the complex number calculations - either a nice scientific calculator, or some software. Both Python and R are freely available programming environments, and both can handle complex number calculations (check out http://www.johnmyleswhite.com/notebook/2009/12/18/using-complex-numbers-in-r/ for some examples in R). Also, https://www.wolframalpha.com/ can handle those calculations as well.
  • · Replies 39 ·
