What is the relationship between entropy and pressure in thermodynamics?
The discussion focuses on deriving the relationship between entropy (S) and pressure (P) in thermodynamics, specifically calculating the partial derivative \((\frac{\partial H}{\partial P})_T\) in terms of pressure, volume (V), temperature (T), thermal expansion coefficient (\(\beta\)), isothermal compressibility (\(\kappa\)), and specific heat at constant pressure (\(c_p\)). The user employs various thermodynamic identities and differentials, including \(dS\) and \(dG\), to manipulate the equations. The final expression derived is \((\frac{\partial H}{\partial P})_T = -(\frac{\partial H}{\partial S})_P (\frac{\partial S}{\partial H})_P (\frac{\partial H}{\partial T})(\frac{\partial T}{\partial P})\), indicating a complex interdependence of these variables.
  • Understanding of thermodynamic identities and equations
  • Familiarity with partial derivatives in thermodynamics
  • Knowledge of specific heat, thermal expansion, and compressibility
  • Proficiency in manipulating differential forms in thermodynamic contexts
  • Study the derivation of Maxwell's relations in thermodynamics
  • Learn about the implications of the Clapeyron equation
  • Explore the concept of thermodynamic potentials and their applications
  • Investigate the relationships between specific heat capacities and phase transitions
This discussion is beneficial for thermodynamics students, researchers in physical chemistry, and professionals working in fields involving heat transfer and material properties.
happyparticle
Derive ##(\frac{\partial H}{\partial P})_t## in term of ##P,V,T, \beta, \kappa, c_p##
Let H = H(T,P)
##ds = (\frac{\partial S}{\partial H})_p dH + (\frac{\partial S}{ \partial P})_H dP##
##dH = (\frac{\partial H}{\partial T})_p dT + (\frac{\partial H}{ \partial P})_T dP##
Hi,
Starting from dS in term of H and P, I'm trying to find ##(\frac{\partial H}{\partial P})_t## in term of ##P,V,T, \beta, \kappa, c_p##.
Here what I did so far.
##ds = (\frac{\partial S}{\partial H})_p [ (\frac{\partial H}{\partial T})_p dT + (\frac{\partial H}{ \partial P})_T dP] + (\frac{\partial S}{ \partial P})_H dP##
##\frac{\partial S}{\partial P} = (\frac{\partial S}{\partial H})_p (\frac{\partial H}{\partial T}) (\frac{\partial T}{\partial P}) + (\frac{\partial H}{\partial P})_T (\frac{\partial S}{\partial H})_P + (\frac{\partial S}{\partial P})_H##
##(\frac{\partial S^2}{\partial T \partial P}) = (\frac{\partial S}{\partial H})_p (\frac{\partial H}{\partial T}) (\frac{\partial T}{\partial P}) + (\frac{\partial H}{\partial P})_T (\frac{\partial S}{\partial H})_P + \frac{d}{dP}(\frac{\partial S}{\partial P})_H##
##(\frac{\partial H}{\partial P})_T = -(\frac{\partial H}{\partial S})_P (\frac{\partial S}{\partial H})_P (\frac{\partial H}{\partial T})(\frac{\partial T}{\partial P})##
From there, I'm stuck. I don't see how I can get ##P,V,T, \beta, \kappa, c_p##
Thank you
Start with the exact differential dG=-SdT+VdP, which means that $$\left(\frac{\partial S}{\partial P}\right)_T=-\left(\frac{\partial V}{\partial T}\right)_P$$
I have to start with ds in term of dh and dp.
I just saw in the original post, those P should be in index.
I finally found something using ##Tds = dh - vdp##
