K values with acid and base reactions
5 replies · 3K views
MathewsMD
Given an aqueous solution (I'm omitting the subscripts):
## NH_3 + H_2O ←→ NH_4^+ + OH^- K_b ##Then we can also say:
## NH_3 + H^+ ←→ NH_4^+ K_b ## as well since they're equivalent reactions, right? They both have the same Kb value as a result, right?
So then, ## K_b = \frac {[NH_4^+][OH^-]}{[NH_3]} = \frac{[NH_4^+]}{[NH_3][H^+]} ##
I would just like to clarify, is this true? It looks like ##[OH^-] = \frac{1}{[H^+]}##
Is this true? Does it take into account the constant "concentration" of the water in this case?
Chestermiller said:
[tex][h^+][oh^-]=10^{-14}[/tex]
Ok. So are the two K expressions not equivalent? I just don't understand why since they're representing the same reaction, are they not?
There are actually two interacting reactions involved. One is NH3 + H2O, and the other one is OH+H going to H2O. If you're only interested in finding the OH concentration, and the original solution is pH=7, then you can solve for the new OH concentration using the first equilibrium constant. However, if you also want to find the new H+ concentration, you need to use the second equilibrium constant (OH+H). Your second reaction expression is not in a form that you can use to solve directly and uniquely for the product concentrations (and, of course, the K has to be modified).
Chet
Chet
Oh okay! Thank you! So would I just divide Kb by Kw to get the second reaction I specified?
