Does the Average Speed Formula Work for Rolling Objects?
  • Thread starter Thread starter alex_boothby
The discussion centers on the application of the average speed formula to rolling objects, specifically a ball bearing rolling down a 5-degree slope. The user calculated translational kinetic energy (0.002520831) and rotational kinetic energy (0.001008332), totaling 0.003529163, which did not match the potential energy (0.014278472) expected from the system. The discrepancy was attributed to the use of average speed (distance/time) instead of instantaneous speed, which is necessary for accurate calculations in accelerating systems.
  • Understanding of kinetic energy concepts: translational and rotational
  • Familiarity with potential energy in gravitational fields
  • Knowledge of angular speed and its calculation using linear velocity and radius
  • Basic principles of motion, particularly for rolling objects
  • Study the differences between average speed and instantaneous speed in physics
  • Learn about energy conservation principles in rolling motion
  • Explore the effects of friction and slipping on rolling objects
  • Investigate the equations of motion for objects rolling down inclined planes
Physics students, educators, and anyone interested in understanding the dynamics of rolling objects and energy conservation principles in mechanics.
alex_boothby
when i add ke translational + ke roatational, i don't get potential which i should, although i was wondering if maybe it was due to slipping although i thought it would still be closer than i got
does this sound right?
ke trans(0.002520831)+ke rotational (0.001008332) = 0.003529163
and
pe=0.014278472
as you can see not very near it!
is this right or have i gone wrong?
the exp was rolling a ball bearing down a 5 degree slope and these calcs were from the 1m release mark. the radius is 0.00765m
thanks
to get the angular speed i used linear V/R (radius)
i got linear v by divinding distance by time.
and
pe=0.014278472
thanks
If you are rolling a ball down a slope, the linear v will NOT be d/t because the ball is accelerating. d/t is average speed not instantaneous speed, which is what you need for your equations.
-Dan
