Kinematic car overtake problem: Don’t know what to do...
The discussion revolves around solving a kinematic problem involving two cars, where one car accelerates while the other maintains a constant speed. The user has calculated initial distances for both cars but struggles to formulate the equations needed for further analysis. Participants suggest using SUVAT equations and creating velocity-time graphs to visualize the problem, emphasizing that displacement is represented by the area under the graph. The user expresses frustration with their course materials and seeks clearer explanations to understand the concepts better. Ultimately, they are guided to correct their graphing approach to accurately reflect the acceleration of car A.
Syw
Car A traveling at a speed of 54 km/h is overtaken by car B traveling at a speed of 72 km/h. after 10 s car A begins to accelerate with an acceleration of 2.0 m/s^2 and continues until he overtakes B. How long has passed between these overtakes?
This is what I've done so far:
54 km/h = m/s
72 km/h = m/s
a = 2,0 m/s^2
A = d_1 = v * t = 15 * 10 = 150 m
B = d_2 = v * t = 20 * 10 = 200 m
d_3 = d_1 - d_2 = 200 - 150 = 50 m
Don‘t know how to continue to solve the problem.
What would be the equation for the position of car A as it is accelerating?
How would you define this d3 you have calculated? What does it represent?
After 10 seconds, car A has driven 150 m and car B 200 m. The difference is 50 meters.
ok, so what happens next? Can you write equations for where each car is time t later?
This is why I’m here. I don’t know how to solve the problem and need help. Been struggling with this problem for a while now. Been googling, watching YouTube videos trying to figure it stuff out. Unfortunately, my teacher is basically not present to help and is bad at explaining. My course book is even worse. I feel like I don’t understand what I’m doing, which I desperately want to. I want someone to explain it to me like I’m a dummie basically.
Are you familiar with the standard equations for constant acceleration, known as the SUVAT equations?
https://en.wikipedia.org/wiki/Equations_of_motion#Uniform_acceleration
Hmm, I can’t find anything about that in my course book, so no.
Well, those equations are what you need here.
Use the ones after "In elementary physics the same formulae are frequently written in different notation as:"
This is not a simple problem where you can just plug some numbers into a single equation. It requires you to think about the physical problem and formulation the equations (plural) that are needed.
Have you been successfully solving simpler kinematic problems? If not, this one is probably too difficult at this stage.
If you want to keep going with the problem, then I suggest you do a velocity against time graph for each car. Did you know that displacement is the area under a velocity/time graph? That might give you an insight into what equations to use and why.
Car B isn't accelerating. So how long will it take car A to reach the same speed as car B, and how far ahead will car B at that point?
If car A keeps accelerating, how long will it take to catch up on car B?
In most problems, if the first half is solved correctly you can get close to half the total marks available, so giving up totally gets 0, but starting correctly is will still be worthwhile.
Hmm, that’s weird in that case, cause I’m in a beginner physics course and it just started, so I haven’t learned a lot yet. It’s strange if I a got a homework this hard like you said then. I’ve just been taught some basic formulas, so felt so lost when this problem came up. I do want to understand it though. Do you have a YouTube video you could recommend that explains this well?
You sometimes get hard questions first up. Can you draw the two graphs of velocity against time?
It is strange that you did not find equations for constant acceleration in your book! Can you say the book's name?
If you are an university student you can use "Fundamentals of Physics(Textbook by David Halliday)". You need to study 2nd chapter of the book called motion along a straight line befor answering this question.
You cannot answer the question without knowing related equations.
The basic equations for 1-D kinematics contain an equation that relates position and time when the acceleration is constant. Can you identify this equation? If so, another approach is to make a table of times, positions and velocities to guide your thinking. A spreadsheet works wonders in this regard and can also be used to draw the graphs mentioned by @PeroK in post #13.
Likes Syw and MatinSAR
I did a v-t-graph. But I get lost on what to do when it’s starts to accelerate at 10 seconds. This is what I’ve done so far. Any suggestions on how I can move forward?
At t = 10 s car A acquires an acceleration of 2 ##\frac{\text{m/s}}{\text{s}}.## This means that every second that goes by, 2 m/s are added to the speed that is already there. Some folks call acceleration "the speed of the speed" because it tells us how fast the speed is changing just like speed tells us how fast the position is changing.
Does this help with what to do next?
Yes, makes sense. It’s just that I don’t know how to tilt the line to get the proper answer in my graph. The reason I’m doing it is because I think I’ll understand it better once I can see it visually.
Like I said, make a table. At t = 11 s the speed has increased to what value? Draw a dot at that value on the graph. At t = 12 s the speed has increased by 2 m/s from the value it had at 11 s. Put another dot on your graph at that new value. Keep going this way. After putting down a few values in your table and your graph, use a ruler to connect the dots.
Okay, so this is what I did and I got the answer 15 s. I’m not fully sure if the answer is right so do you know if I’ve done everything correctly?
You did a velocity vs time graph and found the car that accelerates has the same speed as the other car after 15 s. Does that mean they are at the same place?
One important piece of information is that when you draw a v vs. t graph, the area under the curve is the displacement of the moving object. Look at your graph.
From t = 0 to t = 10 s
The area under the A curve is that of a rectangle of height 15 m/s and width 10 s.
The displacement of car A from 0 to 10 s is (15 m/s)×(10 s) = 150 m. You called that d_1 in post #1.
The area under the B curve is that of a rectangle of height 20 m/s and width 10 s.
The displacement of car B from 0 to 10 s is (20 m/s)×(10 s) = 200 m. You called that d_2 in post #1.
The difference in distance between the two cars is the difference of the areas between the two rectangles and you called that d_3. So far so good.
For car A to catch up with car B the areas under each curve must be equal. Now look at the graph from 10 to 15 seconds. The additional displacement of car B is a rectangle while the additional displacement of car A is a triangle.
What fraction of B's displacement is A's displacement?
Can you extrapolate at what time t_f the area under the triangle from 10 s to t_f will be equal to the area under the rectangle over the same time interval?
Hi @Syw. The graph in your Post #20 attachment (here) shows car A accelerating from
15m/s at t=10s
to
20m/s at t=15s.
This is an acceleration of
##\frac {\Delta v}{\Delta t} = \frac {20m/s – 15m/s}{20s - 15s} = \frac {5m/s}{5s} = 1 m/s^2##
But A’s acceleration is supposed to be ##2 m/s^2##. So the graph is incorrect.
  • · Replies 20 ·
