Kinematics: UAM question help finding final velocity?
The discussion centers on using the Uniformly Accelerated Motion (UAM) equation Vavg = x/t to determine the final velocity (Vf) of a cart rolling down an incline. The values provided include initial position (Xi = 0m), final position (Xf = 2.27m), initial velocity (Vi = 0 m/s), time (t = 3.46s), and the need to find Vf without directly calculating acceleration. The final velocity was calculated to be Vf = 1.31 m/s using the relationship derived from the equation Xf - Xi = (1/2)(Vi + Vf)t, confirming that the average velocity can serve as an intermediate step in this context.
  • Understanding of Uniformly Accelerated Motion (UAM) equations
  • Basic algebra for rearranging equations
  • Knowledge of kinematic concepts such as initial and final velocity
  • Familiarity with motion along an incline
  • Study the derivation of the UAM equations for better comprehension
  • Learn how to graph velocity versus time for uniformly accelerated motion
  • Explore the implications of constant acceleration on motion down an incline
  • Practice solving similar problems involving kinematics and inclined planes
This discussion is beneficial for physics students, educators, and anyone seeking to understand the application of kinematic equations in real-world scenarios, particularly in the context of motion on inclined planes.
ebuwsu
Can you use the UAM equation Vavg = x/t to solve for final velocity of a cart at the bottom of a ramp only using known x and time values before/without calculating for acceleration?
These are my values:
Xi = 0m
Xf = 2.27m
Vi = 0 m/s
Vf = ?
A = ? (can only use x and t values for this question)
t = 3.46s
It was explained that it could be used as an intermediate step to find final velocity, but then what equation do you use? I also don't quite understand how because the equation uses average velocity, so when I write it out and solve for Vf I am only solving for average final velocity, right?
Vavg = x/t = 1/2(Vi + Vf) = x/t
x
ebuwsu said:
Homework Statement:: Can you use the UAM equation Vavg = x/t to solve for final velocity of a cart at the bottom of a ramp only using known x and time values before/without calculating for acceleration?
Xi = 0m
Xf = 2.27m
Vi = 0 m/s
Vf = ?
t = 3.46s
It was explained that it could be used as an intermediate step to find final velocity, but then what equation do you use? I also don't quite understand how because the equation uses average velocity, so when I write it out and solve for Vf I am only calculating for average final velocity, right?
Relevant Equations:: Vavg = x/t = 1/2(Vi + Vf) = x/t
When you solve for the final velocity, that is not the average final velocity, it is the instantaneous final velocity after 3.46 seconds at x= 3.27 m. X is measured along the incline. What do you mean by average final velocity??
Thank you for the clarification. I apologize I'm very new to physics, so I'm sure my statement is worded confusingly 😟
The ultimate goal of the homework question is to determine whether or not I can use the average velocity UAM equation to solve for Vf with the known values. The explanation I was given in class was that you can use this equation as an intermediate step in conjunction with another UAM equation, but I don't understand how. What do I solve for in the average velocity equation that I can use in another equation to solve for Vf?
Hopefully, this makes more sense. I appreciate the help so late at night. I am stuck.
ebuwsu said:
Can you use the UAM equation Vavg = x/t to solve for final velocity of a cart ...
For a straight ramp, the acceleration is constant. If you draw a velocity time graph, what relationship do you see between initial velocity, average velocity and final velocity?
Yes you can as long as you know Xi, Xf, Vi and t. Starting from the relevant equation you posted, $$X_f-X_i=\frac{1}{2}(V_i+V_f)t$$ do a little bit of algebra to find ##V_f## in terms of the other quantities and then substitute the numbers. You don't need to mess with the average velocity ##V_{ave}=\frac{1}{2}(V_i+V_f).##
It’s an incline ramp. Sorry I should’ve specified that!
2.27 - 0 = 1/2(0 + Vf)3.46
2.27 = 1/2Vf3.46
2.27 = 1.73Vf
2.27/1.73 = 1.73Vf /1.73
Vf = 1.31 m/s
Okay gotcha! So therefore this is my final velocity in the context of a cart rolling down an incline ramp and I can use the equation to find Vf. I think it just confused me that I was told it was supposed to be an intermediate step used along with a whole other equation.
2.27 = 1/2Vf3.46
2.27 = 1.73Vf
Vf = 1.31 m/s
You can use the equation as you did to find the final velocity in cases where the acceleration is constant. The information that the cart is going down a straight ramp establishes that.
Thank you for the clarification and verification!
  • · Replies 28 ·
  • · Replies 17 ·
