Kinetic Energy and Uncertainty Principle
The minimum kinetic energy of a proton confined in a uranium nucleus with a radius of 7.43 femtometers is calculated using the uncertainty principle. The correct formula is K_{min} ≥ (ħ²)/(2ml²), where ħ = 1.0546 x 10^-34 J·s, m = 1.6726 x 10^-27 kg, and l = 14.86 x 10^-15 m. A common error identified in the discussion is the miscalculation of powers of ten, leading to an incorrect result of 1.5056 x 10^-14 J instead of the expected value around 1 x 10^-11 J. The factor of two in the denominator of the equation must be carefully considered to avoid errors.
  • Understanding of the Heisenberg Uncertainty Principle
  • Familiarity with Gaussian wave packets
  • Knowledge of basic quantum mechanics
  • Proficiency in unit conversions and dimensional analysis
  • Review the Heisenberg Uncertainty Principle and its implications in quantum mechanics
  • Study Gaussian wave packets and their applications in particle confinement
  • Learn about the relationship between momentum and kinetic energy in quantum systems
  • Practice unit conversions and powers of ten in physical calculations
Students studying quantum mechanics, physicists working with nuclear physics, and anyone interested in the applications of the uncertainty principle in particle confinement scenarios.
jimmypoopins
A proton is confined in a uranium nucleus of radius 7.43 fm. Determine the proton’s minimum kinetic energy K ≥ ∆K according to the uncertainty principle if the proton is well approximated by a Gaussian wave packet confined by the nuclear diameter.
K_{min}\geq\frac{\hbar^2}{2ml^2}
l=2*7.43fm=14.86*10^-15m
m=m_{p}=1.6726*10^-27kg
\hbar=1.0546*10^-34J*s
I think my problem is that i might be using incorrect equations or I'm messing up with units somewhere. I put in the values above into the first equation and got
K_{min}\geq\frac{\hbar^2}{2ml^2}=\frac{(1.0546*10^-34J*s)^2}{2*1.6726*10^-27kg*(14.86*10^-15m)^2}=1.5056*10^-14J
and my web homework program is telling me the answer is incorrect. can anyone lead me in the correct direction please?
The uncertainty principle says delta(x)*delta(p)>=hbar/2. Are you missing that factor of 2?
There's something wrong with the powers of ten. I make the result about 10^-11, not 10^-14. i.e. -68 + 27 + 30 = -11.
[Edited : OK, you could be in the right ballpark ...]
the equation was provided in my book and before i found it in the book i found the relationship between momentum and kinetic energy and put energy in for momentum in delta(x)delta(p)>=hbar/2 and solved for energy and got the same result
i think that's because the answer is one digit followed by a decimal with powers of ten, but some of the numbers have two digits in my equation and are multiplied by 2, etc.
you might be right though, if anyone wants to check my work more thoroughly... i quite often make simple mistakes with powers ot ten, unit conversions, etc.
Your formula for K_min does not contain that factor of two.
  • · Replies 30 ·
  • · Replies 24 ·
  • · Replies 22 ·
11K
