Kinetic Energy Poll Ball Question
11 replies · 5K views · last reply
lilbunnyf
Two identical billiard balls are at rest on a frictionless, level surface, touching each other at one common point. A third, identical ball, the cue ball, is approaching along the common tangent with a constant speed of 20m/s. Assuming a completely elastic collision, with no spin on any balls, and making(reasonable) assumptions about symetry, calculate the velocity of the cue ball after the collision. The graph is as shown below
(the masses of the 3 balls are the same, but the value is unknown)
o------->8
20m/s
I think two equations could be used in this question, one is
Pt = (20m/s)M = Pt`= (v1 m/s)M + (v2 m/s)M + (v3 m/s)M
the other one is The Conservation of Energy
Ek= Ek`
(M(20M/S)^2)/2 = (M(v1 m/s)^2)/2 + (M(v2 m/s)^2)/2 + (M(v3 m/s)^2)/2
The only thing i can do is assume that ball1 and ball2 have the same speed after the collision
so that i got 2 equations
no.1 20M= 2(V1)M + (Vc)M, where V1 is the velocity of ball1 and ball2,Vc is the value we r looking for
no.2 (20^2)M/2 = 2M(V1^2)/2 + (Vc^2)M/2
and by substituting 20M-2V1=Vc in no.1 into no.2, I got V1 = 13.33, which will result in Vc= - 6.67m/s
but the answer in the book says Vc=-4m/s ... Did i do something wrong with my equations? Helps/Suggestions are really appreciated, Thanks in advanced!
[QUOTE=lilbunnyf;1998392]1.
Ek= Ek`
QUOTE]
V1, V2 and V3 are not in the same direction. Take the camponents of V2 and V3 in the direction and perpendicular to the direction of cue ball.
Ek= Ek`
QUOTE]
V2 and V3 are in opposite direction since they are perpendicular to V1? Btw why would they be perpendicular?
No he's not saying they're perpendicular, he's saying that v2 and v3 are vectors with some general directions (after the collisions) that you don't know, and therefore you're going to have to break up these vectors into *components* parallel to, and perpendicular to, the cue ball's initial direction.
But even after breaking them up into components, you don't know the angles. How do you solve this question?
I get vc = vb1cosθ1 + vb2cosθ2 + vc' and 0 = vb1sinθ1 + vb2sinθ2 where vb1 and vb2 are the billiard balls and vc is cue ball
Welcome to Physics Forums.
Are you currently working on this problem yourself? This question was originally posted about 3 years ago.
At any rate, you don't have to use vb1, θ1, vb2, θ2 to express the velocities. It may be easier instead to use vb1x, vb1y, vb2x, vb2y.
Yes, I am working on this problem...but I did break them into components just labeled differently.
x-component : vc = vb1cosθ1 + vb2cosθ2 + vc OR vc = vb1x + vb2x + vc'
y-component : 0 = vb1sinθ1 + vb2sinθ2 OR 0 = vb1y + vby2
But I still don't know vb1x and vb2x.
In the instant that all three balls are touching, their centers form an equilateral triangle. In what direction will the impulses delivered to each stationary ball by the cue ball be delivered?
Why is it that common tangent the cue ball is approaching along? I envisaged the cue ball approaching roughly parallel to the two stationary balls, off-set by half a radius?
I see it thus:
Thanks for all your input, but how do I setup the equations here?
Conservation of momentum in the horizontal direction, conservation of energy overall. You should be able to deduce the angle at which the balls depart the collision.
