Understanding Kinetic Energy and Momentum Conservation in Colliding Masses
The discussion focuses on the principles of kinetic energy and momentum conservation during collisions between two masses, m1 and m2. It establishes that for momentum to be conserved, if m1 moves towards m2 and recoils with velocity -v, then m2 must move with velocity v' defined by the equation v' = 2m1v / m2. The conversation highlights that while kinetic energy is not conserved in all collisions, in this scenario, the total kinetic energy after the collision exceeds that before, particularly when m2 is stationary and has a significantly larger mass.
  • Understanding of basic mechanics principles, specifically conservation of momentum.
  • Familiarity with kinetic energy calculations, including the formula KE = 0.5mv².
  • Knowledge of elastic and inelastic collisions in physics.
  • Concept of mass ratios and their impact on collision outcomes.
  • Study the differences between elastic and inelastic collisions in detail.
  • Explore the implications of mass ratios in collision scenarios.
  • Learn about conservation laws in different physical systems.
  • Investigate real-world applications of momentum and kinetic energy in engineering and physics.
This discussion is beneficial for physics students, educators in theoretical mechanics, and anyone interested in the principles of momentum and energy conservation during collisions.
Yosty22
In my theoretical mechanics class, we went over some very basic conservation laws (namely momentum) and talked about colliding masses.
Say you have 2 masses, m1 and m2. m1 is moving to the right (towards m2) with velocity v. m2 is stationary. After the two masses collide, m1 recoils with velocity -v (same speed, just the direction changed). In order for momentum to be conserved, mass m2 must move to the right after the collision with speed v'. In terms of v, m1, and m2, v' can be described as:
v' = 2m1v / m2.
This is all well and good, but some classmates and I were thinking about the kinetic energy here. If m1 is moving to begin with, it has some initial kinetic energy equal to .5m1v2. However, since it recoils at the same exact speed (just different direction), it's kinetic energy is the same after the collision as it was before. However, m2 must move to the right after the collision for momentum to be conserved, so after the collision, m2 also has kinetic energy equal to .5m2v2. That is, the kinetic energy after the collision is greater than the kinetic energy before. (I know kinetic energy doesn't always have to be conserved, but why would the total kinetic energy be greater after this collision?)
Your observation is correct. If colliding with a stationary object, a mass with initial velocity v can only have final velocity -v if the collision is elastic *and* the object it collides with has infinite mass (or rather, the velocity will go to -v as the mass ratio goes to 0). In this limit, the heavy mass can absorb the additional momentum without changing its kinetic energy significantly.
If the objects have the same mass and the collision is elastic, the originally moving object will be at rest after the collision.
