Kinetic friction of a wood block
The discussion focuses on the physics problem involving a 1.4 kg wood block launched up a 22-degree inclined wooden ramp with an initial speed of 14 m/s and a coefficient of kinetic friction (Uk) of 0.20. Participants analyze the forces acting on the block, including normal force, weight, and kinetic friction, and derive equations to calculate the vertical height reached and the speed upon sliding back down. Key corrections include ensuring proper division by mass to find acceleration and clarifying the initial speed's role in calculations.
  • Understanding of Newton's laws of motion
  • Familiarity with kinematic equations
  • Knowledge of forces on inclined planes
  • Basic concepts of friction and its coefficients
  • Review Newton's second law and its application in inclined plane problems
  • Learn how to derive and apply kinematic equations for motion along an incline
  • Study the effects of friction on motion, particularly in wood-on-wood scenarios
  • Explore methods to convert distances along an incline to vertical heights
Students studying physics, educators teaching mechanics, and anyone interested in understanding motion on inclined planes and the effects of friction.
spin360
So the problem states:
A 1.4 kg wood block is launched up a wooden ramp that is inclined at a 22 deg angle. The block's initial speed is 14 m/s. Use Uk = 0.20 for the coefficient of kinetic friction for wood on wood.
U = mu...
(a) What vertical height does the block reach above its starting point?
(b) What speed does it have when it slides back down to its starting point?
Okay so this is how I started it...
I drew a force diagram of the object on an inclined ramp at 22 deg. Set the x-axis parallel with the object.. so basically at the same angle. 3 forces.. normal, weight, and kinetic friction.
E = summation
M = mass
A = accel
N = normal
Mg = mass * gravity
fk = kinetic friction
E(Fy) = MAy = 0
N - Mg*cos(22) = 0
N = 12.73
E(Fx) = MAx
-fk - Mg*sin(22) = MAx
-Uk*N - Mg*sin(22) = MAx
-0.20*12.73 - 5.14 = MAx
Ax = -7.686 m/s^2
Vf = Vi + a*t
t = 1.95s
Plug that into the x kinematic equation...
xf = xi + vi*t + (1/2)*a*t^2
= 0 + 15*sin(22)*1.95 + (1/2)*(-7.68)(1.95^2)
= 12.507 m
The answer is wrong.. if someone could disect my work and figure out what I'm doing wrong that'd be awesome, thanks!
U = mu...
E = summation
M = mass
A = accel
N = normal
Mg = mass * gravity
E(Fy) = MAy = 0
N - Mg*cos(22) = 0
N = 12.73
E(Fx) = MAx
Ax = -7.686 m/s^2
Vf = Vi + a*t
t = 1.95s
= 12.507 m
You didn't actually divide by the M in the final step to get your acceleration.
Can you elaborate on how you found t? Using your value for a, I don't get the same answer that you did. Maybe you made a typo?
In addition to what hage567 points out:
= 12.507 m
Where do the 15 and the sin(22) come from? The initial speed is 14 m/s parallel to the incline. Once you find the distance up the incline using this formula, you'll have to convert it to height.
= 12.507 m
Don't forget that the kinematic equations will give you the distance ALONG the incline, not the height that the block was displaced in the vertical direction.
I'm not understanding the 15*sin(22) part. For one thing, the initial velocity is 14 m/s.
EDIT: I'm too slow.
Ahh good catch. Okay then I get -5.49 m/s^2 for the accel and 2.73 for t. I plugged that into the y formula and get -5.12 which is obviously not right :frown:
Okay... so then would just be y = 14*2.73 + (1/2)(-5.49)(2.73^2)?
Actually yeah that's wrong too
I got 17.76 m for the "distance" not sure how to convert to height?
haha nevermind i got it... 17.76*sin(22) = 6.65m for the height thanks guys!
