Kirchhoff Law Problem: Find Current and Potential Difference | Solution Included
The discussion revolves around applying Kirchhoff's laws to analyze a circuit, specifically focusing on finding the current and potential difference between points in the circuit. Participants are exploring the relationships between voltage, current, and resistance in the context of circuit analysis.
  • Participants discuss assigning potentials to points in the circuit and calculating voltage drops. There are questions about which reference points to use for potential differences and how to approach the analysis with multiple voltage sources.
Some participants have offered guidance on how to assign reference voltages and calculate potential differences. There is an ongoing exploration of different approaches to analyzing the circuit, with no explicit consensus reached on a single method.
Participants are navigating assumptions about voltage sources and the implications of negative voltage values in their calculations. There are mentions of specific circuit configurations that may influence the analysis.
WeiLoong
https://fbcdn-photos-c-a.akamaihd.net/hphotos-ak-xft1/v/t1.0-0/s480x480/12802893_10205707400875867_4855727067132215897_n.jpg?oh=b486598e6f2016a814eb52bf48870334&oe=57648CD9&__gda__=1464637082_3cae40328f43f09eaa2cf9cf5b2f0b0f
Kirchhoff Law
1. Find the current in the circuit
2. Find the potential diferent between X and Y
1 by using the kirchhoff law. V=IR
I=0.025
question 2 I=0.025
but how to find Vx and Vy?
Vx =IR
I =0.025 but which R is supposed to use?
Your current direction is correct. One way to solve this problem would be by assigning potentials and calculating voltage drops. Assume potential of point W to be 0V. That way, +ve terminal of 20V source will be at 20V. Then calculate drop across 40 ohm resistor. Point x will be at 20-V40Ω potential. Go on with this along the loop and find potential of point y. Difference between them is your Vxy.
Thanks! I got it
https://scontent-kul1-1.xx.fbcdn.net/hphotos-xlt1/v/t1.0-9/12814145_10205707617681287_7591958914593573074_n.jpg?oh=b9163aaa1c77737cb533a124e4292d6a&oe=574F8189
By using kirchhoff law i get all the current
the question ask to find the PD between A and B, the question is the voltage drop i should begin in which point? Because there is 2 sources
You can start by either assuming A at 3V or assuming B at 0V. Since you know i1, assuming B at 0V will be easier.
But point A is supplied by 2 battery of 3V.If i use voltage drop, I only need to look at the top loop?
You need to find the currents using the two loops (which will include both the sources) and then by assuming a suitable reference( VB=0V), you can find Vab like you did in the last problem.
if i assume Vb =0
-6(I2)+3V=Va?
WeiLoong said:
if i assume Vb =0
-6(I2)+3V=Va?
-6I1+3V=Va..
Ops mistake haaha. thank you , have a good day!
https://scontent-kul1-1.xx.fbcdn.net/hphotos-xft1/v/t1.0-9/12814383_10205707793045671_2997254212403029818_n.jpg?oh=0a9ed6d9fbec4f8eed32f88ffdfba9b1&oe=57574AC1
If Vx is 0 , what is the V in point Y
-12(I1)-8(I2)=Vy
which i will gef -12V in Y, is this possible for me to get 12V in negative value?
-12(I1)-8(I2)=Vy
Yes. In fact you don't even need to know the current for that. Moving from x to y along the bottom wire, you can see a voltage drop of 12V.
  • · Replies 23 ·
