Klein-Gordon equation and factorization
The discussion centers on the factorization of the Klein-Gordon equation for a Dirac field of a neutrino, specifically the expression \(\partial_{t}^{2} + \vec{k}^{2} = (-i \partial_{t} + k)(i \partial_{t} + k)\). Participants explore the implications of changing the order of factors in this factorization, leading to different equations. The consensus is that the order of operations is crucial, as it affects the resulting equations, particularly when considering the relativistic limit where \(k \gg m\). The Klein-Gordon operator acting on a plane wave returns \(m^2\) times the plane wave, reinforcing the importance of maintaining the correct order in factorization.
  • Understanding of the Klein-Gordon equation and its applications in quantum field theory.
  • Familiarity with Dirac fields and their mathematical representation.
  • Knowledge of relativistic limits and energy-momentum relations.
  • Basic proficiency in operator algebra, particularly in the context of quantum mechanics.
  • Study the derivation and implications of the Klein-Gordon equation in quantum field theory.
  • Learn about the d'Alembert operator and its role in wave equations.
  • Explore the concept of factorization in differential operators and its significance in physics.
  • Investigate the relativistic limit and its effects on particle behavior and equations of motion.
Physicists, particularly those specializing in quantum mechanics and field theory, as well as students seeking to deepen their understanding of the Klein-Gordon equation and its applications in particle physics.
parton
Hi!
I read a text were some kind of "Schroedinger-equation" for a neutrino field is being derived. But there is a particular step I do not understand.
Consider a Dirac field \psi(t, \vec{x}) of a neutrino, satisfying the Klein-Gordon equation:
\left( \partial_{t}^{2} + \vec{k}^{2} + m^{2} \right) \psi_{\vec{k}}(t) = 0
where the field was expanded in plane waves \psi(t,\vec{x}) = \psi_{0} e^{i (\vec{k} \cdot \vec{x} - E \cdot t)} and the spatial derivatives were already computed.
Furthermore, we assume the high relativistic limes where k = \vert \vec{k} \vert \gg m
Now we can linearzie the equation above using
\partial_{t}^{2} + \vec{k}^{2} = (-i \partial_{t} + k) (i \partial_{t} + k)
Applying only the 2nd factor onto the field \psi(t,\vec{x})
will lead to
\left \lbrace (-\partial_{t} + k) (E + k) + m^{2} \right \rbrace \psi(t,\vec{x}) = 0
Now the following approximaton of the energy-momentum relation is used:
E = \sqrt{\vec{k}^{2} + m^{2}} \simeq k
If we use this approximation in the equation above, we have
\left \lbrace (-\partial_{t} + k) (2 k) + m^{2} \right \rbrace \psi(t,\vec{x}) = 0
which is actually the equation I need.
But my problem is, what happens if I exchange the order in the factorization above:
\partial_{t}^{2} + \vec{k}^{2} = (i \partial_{t} + k) (-i \partial_{t} + k)
Going through the same steps as above I end up with
\left \lbrace (\partial_{t} + k) (k - k) + m^{2} \right \rbrace \psi(t,\vec{x}) = 0
so finally I have
m^{2} \psi(t,\vec{x}) = 0
which does not make sense.
So my question is why is it possible to make the linarization
and why do I have to pay attention to the order of the factors?
I hope somebody could help me.
I didn't read carefully enough to spot where you made the mistake, but I'll tell you the answer; the Klein-Gordan operator acting on a plane wave returns m^2 times the plane wave, even in the relativistic limit. Therefore, no matter what order you do things, you should expect a cancellation between two big numbers (k^2 + m^2) and (-k^2) such that you get the small number m^2.
Thanks for your answer.
I think you mean the d'Alembert operator (the Klein-Gordan operator applied on a free field should return 0).
The equation
m^{2} \psi(t,x) = 0
makes no sense. But I just recognized that if the relativistic limit corresponds to the massless limit, this equation would make sense if we set m=0.
And the other equation (if we exchange the order of the operators) would be
(-\partial_{t} + k) \psi(t,\vec{x}) = 0
So if the mass is vanishing in the high relativistic limit there is no contradiction anymore and the order of the operators does not matter.
But nevertheless I am confused. As long as I do not neglect the mass the order is important and depending on it, I find two different equations.
Maybe the "derivation" of the equation
should be considered as some kind of heuristic reasoning to find this "Schroedinger"-equation.
If we write it in the form
\partial_{t} \psi(t, \vec{x}) = \left( k + \dfrac{m^{2}}{2k} \right) \psi(t,\vec{x})
we see that the RHS is just the expansion of the energy in the relativistic limit:
E = \sqrt{k^{2} + m^{2}} \simeq k + \dfrac{m^{2}}{2k}
But this is confusing me, because above I used another approximation:
E \simeq k
So if originally E ~ k is used and therefore, higher order terms
\mathcal{O} \left(\dfrac{m^{2}}{2k} \right)
are neglected why are this higher order terms not neglected in the "Schroedinger" equation too?
Code:
Isn't the basic issue here that, whilst it may be reasonable to approximate k ≈ E when calculating the factor (E + k), doing this is much less so when calculating
(-i\partial_{t} + k) = (k - E)
For example, it is often reasonable to say that 1,000,000 + 1,000,001 ≈ 2,000,000, but much less so to suggest that 1,000,001 - 1,000,000 ≈ 0.
If, instead, we use the approximation
E - k \simeq \dfrac{m^{2}}{2k}
then the equation becomes
\left \lbrace (i\partial_{t} + k) (\dfrac{-m^{2}}{2k}) + m^{2} \right \rbrace \psi(t,\vec{x}) = 0
which (unless I've got something wrong here) reduces to
(-i\partial_{t} + k)\ \psi(t,\vec{x}) = 0
and doesn't really help here. Actually, I don't really see why the same result should follow regardless of which factor we decide to operate with on the wavefunction first.
(Also, haven't you left out an i that should be before the ∂t in some of your equations?)
Yes, you are right.
I am just confused by the decomposition
If the order is important then how do I know how to decompose the d'Alembert operator in the right way?
How do I know that i should write
and not
Or should I argue that I am intersted in the "difference" between energy and momentum and therefore, need to consider
  • · Replies 0 ·
