Klein-Gordon Equation: Solving 2nd Order Time Derivative
The discussion centers on the challenges posed by the second-order time derivative in the Klein-Gordon (KG) equation, particularly regarding the interpretation of probability densities. It is established that the negative energy solutions associated with the KG equation complicate its use as a direct relativistic substitute for the Schrödinger equation. The resolution lies in quantum field theory (QFT), which reinterprets negative-frequency modes as antiparticle states, thus allowing for a consistent probabilistic framework. The conversation emphasizes the necessity of transitioning from traditional quantum mechanics to QFT for a coherent understanding of relativistic particles.
  • Understanding of the Klein-Gordon equation and its formulation
  • Familiarity with quantum mechanics and the Schrödinger equation
  • Knowledge of quantum field theory principles
  • Basic grasp of Lagrangian mechanics and Noether's theorem
  • Study the implications of negative energy solutions in quantum field theory
  • Learn about the Feynman-Stückelberg trick and its application in QFT
  • Explore the derivation of conserved currents in the context of the Klein-Gordon equation
  • Investigate the transition from non-relativistic quantum mechanics to relativistic quantum field theory
Physicists, particularly those specializing in quantum mechanics and quantum field theory, as well as students and researchers seeking to understand the limitations of the Klein-Gordon equation in describing relativistic particles.
koustav
TL;DR
Second order time derivative
What problem actually arises when we take the second order time derivative in KG equation
We'd need a bit more detail, to which problems you are referring to. Sometimes it's claimed that the "problem" with "negative energy solutions" of the time-independent Klein-Gordon equations arises because of the 2nd-order time derivative, and then old-fashioned books make an argument that for this reason one wants the 1st-order Dirac equation. The modern answer to all these problems is, of course, quantum field theory and the reinterpretation of negative-frequency modes as antiparticle states with positive energy (just writing a creation instead of an annihilation operator in the mode-decomposition of the field operator, aka Feynman-Stückelberg trick).
The textbook simply mentions that the probability density is not positive definite because of the second order time derivative.so how actually the second derivative creates a problem for probabilistic interpretation
The problem is to try to use KG equation as an immediate relativistic substitute for the Schrödinger equation. In classical QM you know that the wave function that describes a particle must be a solution of the equation
$$\left(i\hbar \frac{\partial}{\partial t} + \frac{\hbar^2}{2m}\frac{\partial^2}{\partial x^2}\right)\psi=0$$
and then, the probability of the particle to be in some region is given by
$$\int |\psi|^2 dx$$
If you want to describe a relativistic particle just by using KG equation, i.e. that now the wave function must be a solution of
$$\left(\hbar^2\frac{\partial^2}{\partial t^2} - c^2\hbar^2\frac{\partial^2}{\partial x^2} + m^2 c^4\right)\psi=0$$
then you have problems because the probabilities become negative.
So constructing a relativistic QM is not as easy as that, you need to change some fundaments. And that's why one needs Quantum Field Theory.
Which textbook?
The problem is that there are many textbooks around, staring with the old-fashioned idea that you could formulate relativistic quantum theory in a similar way in terms of a wave function as Schrödinger did for the non-relativistic case. The problem with that is that it simply doesn't work out, and that in fact one needs quantum field theory to formulate relativistic quantum theory. That is, because at relativistic energies in scattering processes you can always destroy and create particles, and that's why one most conveniently uses quantum-field theory which is the most simple way to describe such annihilation and creation processes. So to get positive probabilities you need relativistic QFT, and then you can describe also "Klein-Gordon particles" (e.g, scalar or pseudoscalar particles like the pions) without problems with "negative probabilities".
How are the probabilities computted? If it is ##\int |\psi|^2 dx## again, then it is always non-negative.
I don't know the proof that that interpretation doesn't work, but there is a consistency check for the non-relativistic Schrödinger equation (and the Dirac equation) that fails for the Klein Gordon equation.
In the case of the Schrödinger equation, we can derive it from a Lagrangian density
##\mathcal{L} = i \hbar \psi^* \dfrac{d\psi}{dt} - \frac{\hbar^2}{2m} (\nabla \psi^* \cdot \nabla \psi)##
The Lagrangian equations of motion give rise to Schrödinger's equation. For this Lagrangian, we can also see that it is invariant under a change of phase:
##\psi \rightarrow e^{i \phi} \psi##
##\psi^* \rightarrow e^{-i\phi} \psi^*##.
Noether's theorem about such symmetries implies the existence of a conserved current:
##\dfrac{d\rho}{dt} + \nabla \cdot j = 0##
where ##\rho = \psi^* \psi## and ##j = \frac{i \hbar}{2m} (\psi^* \nabla \psi - \psi \nabla \psi^*)##
So ##\rho## can consistently be interpreted as a probability density (If it is normalized to integrate to 1) and ##j## can be consistently interpreted as a probability current.
If you do the same thing with the Klein-Gordon equation, you get a conserved current again, but a different one:
##\mathcal{L} = \dfrac{d\psi^*}{dt} \dfrac{d\psi*}{dt} - \nabla \psi^* \cdot \nabla \psi##
The corresponding density and current is given by:
##\rho = \psi^* \dfrac{d\psi}{dt} - \dfrac{d\psi^*}{dt} \psi##
##j = \psi^* \nabla \psi - (\nabla \psi^*)\psi##
So ##\psi^* \psi## does not play a role in the conserved current of the Klein Gordon theory.
But then it's not conserved in time, which is inconsistent because the sum of all probabilities ##\int_{-\infty}^{\infty} |\psi|^2 dx## should be equal to 1, at any time.
Yes, my question was about that part, where he wrote that he probabilities are negative.
Another way to put my point about the Klein Gordon equation is this:
You have two choices, and neither works: If you interpret ##\rho = \psi^* \psi## as a probability density, then that doesn't work because the total probability isn't conserved for Klein-Gordon. If you interpret ##\rho = \psi^* \frac{d\psi}{dt} - \frac{d\psi^*}{dt} \psi## as a probability density, then it is in fact conserved, but it can be negative.
I guess you can consistently interpret ##\rho = \psi^* \frac{d\psi}{dt} - \frac{d\psi^*}{dt} \psi## as a charge density, with both positive and negative charges...
Sigh. Once more: There is NO consistent interpretation of the KG Gordon (nor any other relativistic) wave function in terms of a single-particle picture. That's why you don't get a consistent definition of a probability distribution as in the non-relativsitic (Schrödinger or Pauli) case. All these quibbles go away when quantizing the relativistic fields and doing quantum field theory. Skipt the textbooks called "relativistic QT" and start with QFT from the beginning. Though more formal, it's at the end much simpler than all the handwaving arguments making the single-particle picture at the end to a many-body picture as it was done by Dirac for his bispinor field, leading to a very murky representation of QED, called the "hole theory". It's indeed equivalent to the modern QFT version, but much more complicated to understand and handle in practice!
Oh yes, completely true, my fault. Of course, the definition of probability density must change. Anyway, I think @stevendaryl has already answered your question.
You have two choices, and neither works: If you interpret ##\rho = \psi^* \psi## as a probability density, then that doesn't work because the total probability isn't conserved for Klein-Gordon. If you interpret ##\rho = \psi^* \frac{d\psi}{dt} - \frac{d\psi^*}{dt}## as a probability density, then it is in fact conserved, but it can be negative.
I guess you can consistently interpret ##\rho = \psi^* \frac{d\psi}{dt} - \frac{d\psi^*}{dt}## as a charge density, with both positive and negative charges...
The invariance of the Lagrangian of the Klein-Gordon equation for the complex scalar field leads, via Noether's, theorem to the conserved current
$$j_{\mu}=\mathrm{i} (\psi^* \partial_{\mu} \psi-\psi \partial_{\mu} \psi^*),$$
which implies that
$$Q=\int_{\mathbb{R}^3} \mathrm{d}^3 x j^0=\text{const}.$$
Of course, you cannot interpret this as a probability density, because it's not positive definite, but you can "gauge" the symmetry under multiplication with a phase factor by making the phase space-time dependent and introduce a gauge field. In this way you get the coupling of the KG field to the electromagnetic field. Then indeed the above current is (up to a factor ##q##) interpreted as the electric charge and current densities. Adding a "kinetic term" for the gauge field and quantizing both the KG and the gauge field leads to scalar electrodynamics.
  • · Replies 45 ·
