Klein-Gordon in QFT: Wave Functions & Spins
  • Context: Undergrad
  • Thread starter Thread starter Silviu
    Klein-gordon Qft
The discussion centers on the Klein-Gordon equation (KG) in Quantum Field Theory (QFT), specifically regarding the behavior of wave functions and particle creation. The KG equation describes spin-0 particles and allows for the creation of particles from the vacuum state, represented as ##\hat{\phi}(x)|0>=|x>##. As time evolves, the wave function of a created particle transitions from a delta function to a free wave, indicating its propagation. Additionally, the interaction of creation operators reveals complexities in particle statistics, particularly for Fermions, which cannot occupy the same quantum state, affecting the probability of creating multiple particles at the same position.
  • Understanding of Quantum Field Theory (QFT)
  • Familiarity with the Klein-Gordon equation
  • Knowledge of particle statistics, particularly Fermions and Bosons
  • Basic concepts of wave functions and their evolution
  • Study the implications of the Klein-Gordon equation on particle creation and annihilation
  • Explore the differences between Fermionic and Bosonic statistics in QFT
  • Learn about the mathematical formulation of operators in Quantum Field Theory
  • Investigate the propagation of wave functions in non-interacting quantum systems
This discussion is beneficial for theoretical physicists, graduate students in quantum mechanics, and researchers focusing on Quantum Field Theory and particle physics.
Silviu
Hello! So in the Klein-Gordon equation you have a field ##\phi## which becomes an operator in QFT and when you apply it on the vacuum state ##|0>## you get a particle at position x: ##\hat{\phi}(x)|0>=|x>##. So if you look at this particle (in a non interaction theory) the wave function of this particle is a delta function (as you know it's exact position where it was created)? Also if you let the system evolve for a long amount of time, will the wavefunction of this particle turn into a free wave, as there is no potential, so it is basically a free particle? And if you apply the KG operator at the same initial position as before, you don't have 2 particles at position x, you have 1 particle localized at x and the other one (the first one) spread in space, is this right? Also the particle created is a spin 0 particle? Thank you!
I'll address the spin question first. The Klein-Gordon equation applies to any massive particle (and reverts to the wave equation for zero mass). It is agnostic about spin. Spin 1/2 particles which satisfy the Dirac equation also satisfy the Klein-Gordon equation.
As to the field satisfying the Klein-Gordon equation, it is rather a class of fields which can be partitioned into creators and annihilators of particles but not necessarily of particles localized at the origin or at any point.
In the mathematical construction of the field theory the textbooks will typically begin by interpreting the field as a field of operators acting at all points of space exciting the local field from the vacuum mode. But you should understand that this field of operators is not effecting an actualized operation. They rather act sort of like a position vector giving relative connection so that one may describe a given quantum actuality in terms of its difference from the vacuum actuality. Further these operators are utilized in combination and in superposition to decompose the physical actions which are actualized... e.g. the propagation of a physical field which can decomposed into a superposition of series of coupled creation-annihilation actions.
However, within all of that you can construct a creation operator for a particle localized as the origin and said particle should then over time propagate outward as dictated by the KG equation (and we can express this by the equivalence of the initial creation operator to the action of a later non-localized creation operator which creates from the vacuum that same spread out particle).
And then, yes a subsequent application of the creation operator may effect a situation with two particles however there's more to the story than just the KG equation and even the spin. There is a determination of the particle's statistics which the KG equation does not specify. The statistics of the particle field will slightly modify your description. For example if we assume the particle is a Fermion, no two of which can occupy the same quantum state, then attempting to create a second one at the origin will not yield a 100% 2 particle mode. The earlier particle may still have a finite probability of being at the origin thus, its wave function has a component which is not compatible with creating the 2nd particle. You will get a reduced amplitude indicating a less than 100% chance the result is a 2 particle system.
It's a bit hard to speak in this way though because again, you don't apply creators in isolation and so the interpretation is subject to inconsistency from the start.
  • · Replies 49 ·
  • · Replies 23 ·
