Graduate Unifying Lagrangians in Electrodynamics: Fμν, Aμ Jμ, & Lorentz Force
The discussion focuses on unifying the Lagrangians in electrodynamics, specifically the field Lagrangian Lem = -1/4 Fμν Fμν - Aμ Jμ and the particle Lagrangian Lp = -m/γ - q Aμ vμ. The proposed unified Lagrangian is L+ = -m/γ - q Aμ vμ - 1/4 Fμν Fμν, which leads to the modified Lorentz force equation fμ = q Fμν vν + 1/4 ∂μ(Fαβ Fαβ). The discussion highlights the complexities involved in deriving equations of motion due to the ill-defined nature of point-particle mechanics in electromagnetic fields, referencing specific sections in a related paper for further clarification.
  • Understanding of Lagrangian mechanics
  • Familiarity with electromagnetic field theory
  • Knowledge of the Lorentz force equation
  • Proficiency in tensor calculus and notation
  • Study the derivation of the Euler-Lagrange equations in electrodynamics
  • Explore the implications of the Landau-Lifshitz approximation in particle dynamics
  • Investigate the continuum-theoretical case of the Lagrangian in electromagnetic fields
  • Review the radiation-reaction problem in classical electrodynamics
Physicists, particularly those specializing in theoretical physics, graduate students studying electrodynamics, and researchers interested in the unification of classical mechanics and electromagnetic theory.
DuckAmuck
How would you unify the two Lagrangians you see in electrodynamics?
Namely the field Lagrangian:
and the particle Lagrangian:
Lp = -m/γ - q Aμ vμ
The latter here gives you the Lorentz force equation.
fμ = q Fμν vν
It seems the terms - q Aμ vμ and - Aμ Jμ account for the same thing. So if you were to add in the kinetic term from Lem to Lp, you get:
L+ = -m/γ - q Aμ vμ -1/4 Fμν Fμν
The subsequent Lorentz force equation is:
This looks weird and makes me think I am missing something. What do you all think? Thanks in advance.
I don't understand your last paragraph. Obviously you consider point-particle mechanics of charged particles and the electromagnetic field as a dynamical system, which is more complicated (and in a sense still ill-defined after more than 100 years of struggle since Lorentz) than you might think. Formally it's as follows:
Your Lagrangian consists of 3 parts: the free matter Lagrangian (where "matter" here means a single particle)
$$L_0^{(\text{matter})}=-m \sqrt{\dot{y}_{\mu} \dot{y}^{\mu}},$$
where the dot means the derivative wrt. an arbitrary world-line parameter (which can in this form of the Lagrangian NOT be proper time); ##y^{\mu}(\lambda)## is the parametrization of the point-particle worldline.
Then the Lagrangian of the free electromagnetic field,
$$L_0^{(\text{field})}=\int_{\mathbb{R}^3} \mathrm{d}^3 x [-\frac{1}{4} F_{\mu \nu} F^{\mu \nu}],$$
where
$$F_{\mu \nu} =\partial_{\mu} A_{\nu} -\partial_{\nu} A_{\mu}.$$
Finally you have the interaction Lagrangian
$$L_{\text{int}}=-q A_{\mu}(y) \dot{y}^{\mu}.$$
This you can formally write also in the other form you have in mind
$$L_{\text{int}}=-\int \mathrm{d}^3 \vec{x} A_{\mu}(x) J^{\mu},$$
where for a point particle
$$J^{\mu}=q \int_{-\infty}^{\infty} \mathrm{d} \lambda \dot{y}^{\mu} \delta^{(4)}[x-y(\lambda)].$$
The equations of motion are very problematic since for the equation of motion of the particle you evaluate the field due to this particle at the space-time point of this same particle, which is ill-defined.
For a discussion of this, see Sects. 4.7 and 4.8 (the former is about the Lagrangian in the continuum-theoretical case, which is well-defined, the latter about point particles and the radiation-reaction problem) in
https://itp.uni-frankfurt.de/~hees/pf-faq/srt.pdf
For a discussion of the Landau-Lifshitz approximation of the LAD equation, see the paper by Nakleh quoted in my manuscript (which is still far from being in final form, particularly concerning this "poin-particle enigma").
The last paragraph is basically asking, how do I write the full Lagrangian of a massive charged particle in an electromagnetic field?
From what you've said, I gathered that it would be written like:
$$ L = -m\sqrt{\dot{y}_\mu \dot{y}^\mu} - q A_\mu (y) \dot{y}^\mu - \frac{1}{4} \int d^3 x F_{\mu\nu} F^{\mu\nu} $$
You can derive the Lorentz force from this, but the term containing the field tensor F seems like it would add an extra term to the force equation due to its dependence on position.
Evaluate the Euler-Lagrange equation:
$$ \frac{\partial L}{\partial \dot{y}^\nu} = -\frac{m}{\sqrt{\dot{y}_\mu \dot{y}^\mu}}\dot{y}_\nu - q A_\nu (y) $$
$$\frac{d}{d\tau} \frac{\partial L}{\partial \dot{y}^\nu} = - f_\nu - q A_{\nu,\mu} \dot{y}^\mu $$
$$ \frac{\partial L}{\partial y^\nu} = -q A_{\mu,\nu} \dot{y}^\mu - \frac{1}{4} \frac{\partial}{\partial y^\nu} \int d^3 x F_{\rho\sigma} F^{\rho\sigma} $$
Put together to get the Lorentz force:
$$ f_\nu = q F_{\nu\mu} \dot{y}^\mu + \frac{1}{4} \frac{\partial}{\partial y^\nu} \int d^3 x F_{\rho\sigma} F^{\rho\sigma} $$
I want to say the last term vanishes, but it seems like there could be a condition where it doesn't. For example, if the limits on the integral depend on y.
But the last term is 0, because nothing depends on ##y##!
Okay so the Lagrangian behavior is straightforward then. What about the Lagrangian density? Where rho is the mass density of a particle cloud.
$$ \mathcal{L} = -\rho(y) \sqrt{\dot{y}_\mu \dot{y}^\mu} - A_\mu J^\mu -\frac{1}{4} F_{\rho\sigma} F^{\rho\sigma}$$
$$ \frac{\partial \mathcal{L}}{\partial y^\nu} = -\partial_\nu \rho \sqrt{\dot{y}_\mu \dot{y}^\mu} -\partial_\nu (A_\mu J^\mu)- \frac{1}{4} \partial_\nu (F_{\rho\sigma} F^{\rho\sigma}) $$
$$ \frac{\partial \mathcal{L}}{\partial \dot{y}^\nu} = -\rho \frac{\dot{y}_\nu}{\sqrt{\dot{y}_\mu \dot{y}^\mu}} $$
Put together to get:
$$ \partial_\nu \rho \sqrt{\dot{y}_\mu \dot{y}^\mu} + \partial_\nu (A_\mu J^\mu) + \frac{1}{4} \partial_\nu (F_{\rho\sigma} F^{\rho\sigma}) = \frac{d}{d\tau} \left( \rho \frac{\dot{y}_\nu}{\sqrt{\dot{y}_\mu \dot{y}^\mu}} \right)$$
  • · Replies 26 ·
10K
