Undergrad What is the Lagrangian with constraint forces?
Choosing the correct constraint in mechanics problems is essential for deriving the Lagrangian. For systems like a pendulum or a block on an inclined plane, constraints are determined by the physical restrictions of the system, such as the relationship between coordinates. For example, in a block sliding down a frictionless incline, the constraint can be expressed as y = x tan(θ), linking the vertical and horizontal coordinates. This constraint ensures that the generalized coordinates are properly defined and not arbitrary. Understanding the nature of the constraints helps in accurately formulating the Lagrangian for the system.
Eh6794
TL;DR
I am confused about the constraint I choose for my mechanics problems.
Let's say I have an inclined plane, a ball rolling off of a half hemisphere or a pendulum and I need to find a tension, friction or normal force.
After I derive the lagrangian, I need to find a constraint, but how do I choose a constraint?
I have worked through a couple of problems with solutions, but it seems like I find the coordinate/variable in the direction of the force I want? Ex. pendulum tension would be L?
ii
Eh6794 said:
Summary:: I am confused about the constraint I choose for my mechanics problems.
ii
"After I derive the lagrangian, I need to find a constraint, but how do I choose a constraint?" Maybe |R| = cte?
That is, ##r = a## => ##r-a = 0##, it is a good holonomic constraint. And i don't know another constraint in this cases you cited. You find a constraint studying the restrictions of the system, let's say like this.
"I have worked through a couple of problems with solutions, but it seems like I find the coordinate/variable in the direction of the force I want? Ex. pendulum tension would be L?"
I do not understand. What do you mean?
You choose the constraint that, ahem, constrains your generalized coordinates not to be just anything. For example, in the case of a block sliding down a frictionless inclined plane you can choose generalized coordinates ##x## and ##y## along the vertical and the horizontal and write $$\mathcal L=\frac{1}{2}m\dot x^2+\frac{1}{2}m\dot y^2+mgy.$$The constraint is that the block must stay on the plane so if you pick a value for one coordinate, the other is strictly specified. Here the relevant constraint is ##y=x~\tan\theta## where ##\theta## is the angle of the incline relative to the horizontal. Then the Lagrangian becomes $$\mathcal L=\frac{1}{2}m\dot x^2+\frac{1}{2}m\dot x^2\tan^2\theta+mgx\tan\theta.$$
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
