Lagrangian for the Kepler Problem
  • Context: Graduate
  • Thread starter Thread starter Philosophaie
    Kepler Lagrangian
7 replies · 7K views
Philosophaie
In a two-body solution ( Kepler Problem) how do you find the Lagrangian, L, if the position vector is:
[tex]x = (v_x * t + x_0, v_y * t + y_0, v_z * t + z_0)[/tex]
Action from Wikipedia is:
[tex]S = \int_{t_1}^{t_2} L * dt[/tex]
That is certainly not true for all t, as this would mean linear motion (no acceleration).
The Lagrangian can be found similar to all other Lagrangians for a particle moving in a potential, the potential is GMm/r where ##r=|x|##.
If the central mass is large enough, the Lagrangian is
$$\mathscr{L} = \frac{1}{2}m(\dot{r}+ r \dot{\theta})^{2} - U(r)$$
Plugging it into the Euler-Lagrange equation:
$$\frac{\partial \mathscr{L}}{\partial q} = \frac{d}{dt}\frac{\partial \mathscr{L}}{\partial \dot{q}}$$
For the radial component, we have ##m \ddot{r} = mr \dot{\theta}^{2}-U'(r)##. The ##\theta## component gives us ##0##, because ##\frac{\partial \mathscr{L}}{\partial \theta} = 0 = \frac{d}{dt}(mr^2 \dot{\theta})##, we can call ##mr^2 \dot{\theta} = L##
At this point, you can pretty much solve the equations of motion with respect to time to get the position.
I hope that wasn't too convoluted of an answer.
Edit: Here's a link you might be interested in reading: http://ocw.mit.edu/courses/physics/8-01sc-physics-i-classical-mechanics-fall-2010/central-force-motion/central-force-motion-and-the-kepler-problem/MIT8_01SC_coursenotes28.pdf
I found a solution for Classical Mechanics
http://www.wolframalpha.com/input/?i=kepler+problem
The Kinetic Energy came out to be [tex]\frac {1}{2} (\frac{dx}{dt})^2[/tex]
The Potential Energy came out to be [tex]\frac {\lambda}{\frac {dx}{dt}}[/tex]
Not sure what lambda is. Can someone explain?
None of that is correct. First, Kepler's problem is usually set in at least 2 dimensions. Second, the potential energy does not depend on velocity; it depends on displacement.
I've got no idea what you're doing.
Look, the Lagrangian IS the kinetic minus the potential. ##\mathscr{L} = KE - U##
In the Kepler Problem, where ##M >> m## $$\mathscr{L} = \frac{1}{2}m(\dot{r}+ r \dot{\theta})^{2} - \frac{GMm}{r}$$
As Voko says, this can be reduced to a one dimensional problem by playing noting that ---->
$$\frac{\partial \mathscr{L}}{\partial \theta} = 0 = \frac{d}{dt}(mr^2 \dot{\theta})$$ where we can set ##mr^2 \dot{\theta} = L## and play with the equations from here.
What EXACTLY are you trying to figure out? State your question CLEARLY, because I don't have a clue what you're asking for.
The potential is spherically symmetric and thus angular momentum is conserved. The trajectory of the planet thus is in a plane perpendicular to the angular momentum and thus in a plane.
The kinetic energy is
[tex]T=\frac{m}{2} \dot{\vec{x}}^2.[/tex]
Using polar coordinates in the plane perpendicular to angular momentum
[tex]\vec{x}=r \begin{pmatrix} \cos \varphi \\ \sin \varphi \end{pmatrix},[/tex]
you get
[tex]T=\frac{m}{2} (\dot{r}^2+ r^2 \dot{\varphi}^2).[/tex]
The Lagrangian thus is
[tex]L=T-V=\frac{m}{2} (\dot{r}^2+ r^2 \dot{\varphi}^2 )+ \frac{G mM}{r}.[/tex]
Now you see that [itex]\varphi[/itex] is cyclic and thus
[tex]J=\frac{\partial L}{\partial \dot{\varphi}}=m r^2 \dot{\varphi}=\text{const}.[/tex]
This is the conservation of angular momentum in this special frame of reference.
Rewriting the equation of motion for [itex]r[/itex] using this first integral as a function of [itex]\varphi[/itex] and doing the substitution [itex]s=1/r[/itex] you get an easy to solve differential equation, leading to ellipses, parabolas, or hyperbolas as trajectories.
The case [itex]J=0[/itex] has to be discussed separately.
Thanx
