Lagrangian Mechanics, bead on a hoop
The discussion focuses on solving a problem in Lagrangian mechanics involving a bead on a hoop. The primary equations used include the Euler-Lagrange equation, $$\frac{dL}{dq_i}-\frac{d}{dt}\frac{dL}{d\dot{q_i}}=0$$, and the Lagrangian $$L=\frac{1}{2}mv^2-U$$. Participants identified a sign error in the initial solution and discussed finding equilibrium positions, leading to the conclusion that equilibrium exists when $$R\omega^2 \geq g$$. The discussion also covered the stability of equilibrium points, particularly at $$\theta = 0$$ and $$\theta = \pi$$, with emphasis on the need for further expansion to analyze stability accurately.
  • Understanding of Lagrangian mechanics and the Euler-Lagrange equation
  • Familiarity with concepts of equilibrium and stability in dynamical systems
  • Knowledge of Taylor series expansion for approximating functions
  • Basic understanding of oscillatory motion and differential equations
  • Study the derivation and application of the Euler-Lagrange equation in various mechanical systems
  • Learn about stability analysis of equilibrium points in nonlinear systems
  • Explore Taylor series expansions and their role in approximating functions in physics
  • Investigate the dynamics of oscillatory systems and the conditions for stable and unstable equilibria
Students and professionals in physics, particularly those studying classical mechanics, as well as educators looking for insights into teaching Lagrangian dynamics and stability analysis.
dumbperson
This is the problem:
http://i.imgur.com/OJyzfhz.png?1
$$ L=\frac{1}{2}mv^2-U(potential energy)$$
This is my attempt at question A):
http://i.imgur.com/IeJVGm3.jpgDoes this look right? If not, am I atleast in the right direction. If I am right, how do I tackle B? I have no clue how to even begin on B.
Thanks
Your solution of A is generally correct, but there is a sign error in it.
To find the equilibrium positions, use the main property of equilibrium: everything stays constant. That means that all the dynamical variables are constant, and their derivatives are zero.
Alright, thanks. I see I need a minus sign before the first term of my final answer. I'll try B with your tip!
at C, do you think they want me to do a taylor expansion around theta_equilibrium?
Yes, the idea is that you should end up with ## \ddot \theta + \omega ^2 \theta = 0 ##, where ##\omega## is to be determined from the expansion.
I actually have no idea where/how to do the expansion. Shouldn't I do it on x(theta), y(theta) and z(theta) ?
Alsol, this is how I did B):
Eq. of motion is
$$\frac{g}{R}\sin{\theta}+\ddot{\theta}-\omega^2\sin{\theta}\cos{\theta}=0$$
the 2nd derivative is zero at equilibrium so i get
$$\theta_{eq} = arccos(\frac{g}{R\omega^2})$$
You do it in the equation of motion you obtained.
Does it exist for all values of ##\omega##?
What about ## \sin \theta = 0 ##?
It exists for
$$R\omega^2\geq g $$
Expansion of sine around my theta_eq??
$$\sin(\theta)=\sqrt{1-(\frac{g}{R\omega^2})^2}+\frac{g}{R\omega^2}\cdot (\theta -\arccos(\frac{g}{R\omega^2})-0.5\sqrt{1-(\frac{g}{R\omega^2})^2}\cdot (\theta -\arccos(\frac{g}{R\omega^2})^2+.. $$
I'm not really sure about what you meant with ''what about sin(theta)=0 ?'' . Sorry
My question was whether ## \sin \theta = 0 ## also gives equilibrium points.
Your expansion is correct, but you do not need terms that are above linear in ##\theta##.
Oh, ofcourse! I forgot sin(theta). theta = 0 is an equilibrium point too.(well and pi but I guess that's not very reasonable here)
So I just have to expand sin(theta)cos(theta) now and then write it out?
Also, how do you type in tex inside your normal sentences? The way I do it ([ tex] [/ tex]) , my text comes on a new line.
you can use itex instead. (sorry for jumping in on this thread). Don't be too quick to dismiss theta=Pi. What do questions b) and c) actually ask you for?
Do not guess. Your task is to find out whether ##\theta = \pi ## is a stable equilibrium.
Yes - about each equilibrium. Note that in all cases except ## \theta_{e} = 0 ##, you will have to change your variable to ## \theta^* = \theta - \theta_{e} ##, so that the resultant equation have the canonical form ##\ddot {\theta ^*} + k^2 \theta ^* = 0 ##.
I think I have it now. I did the expansion around theta_eq=pi, and the differential equation was the one of an exponential function(so not stable).
Around theta_eq=arccos(g/(Rω^2)), I found
$$k^2=\frac{3g^2}{R^2\omega^2}-\omega^2$$
At ## \theta = 0 ##, the linearized equation is ## \ddot \theta + (\frac g R - \omega^2) \theta = 0 ##. Clearly, the nature of its solution depends critically on ##(\frac g R - \omega^2)##, and three cases are possible. You should analyze all of them.
Same for ## \theta = \pi ##.
I do not think it is correct. I obtain a similar expression, yet a different one.
Thanks again! forgot about that. Still get that with theta_eq=pi, it is unstable in every case. I also see I made a mistake with determining k in my previous post, I got a K now that makes it stable for the allowed \omega (minus the end point).
I got this one now:
$$k^2=\omega^2(1-(\frac{g}{R\omega})^2),$$
dumbperson said:
I got this one now:
This is not self-consistent dimensionally. ##(\frac{g}{R\omega})^2## has the dimension of frequency squared, while 1, from which it is subtracted, is dimensionless.
By the way, how did you analyze the case ##\theta_e = 0## and ## R\omega^2 = g ##?
The omega within the square should also be squared, that's my answer(just forgot to write the square here)
Woops
The motion is linear(theta=b*t+c) , so not stable. Is this correct?
Good. That is the solution I get as well.
dumbperson said:
I had that the motion will then be quadratic in time(0.5at²), not stable. Is this correct?
You obtained this equation from the power series expansion. That the first member of the expansion turns out to be zero does not really mean that a small oscillation regime is impossible. You should just continue the expansion and get the first member that isn't zero.
If you mean what I think you mean, I expanded it further and the first nonzero term is a cubic one?
$$0.5\theta^3\frac{g}{R}+\ddot{\theta}=0 $$
but isn't this term super small that we ignore it?
We ignore it when there are bigger terms. But in this case there are not, and if we ignore this, we reach the wrong conclusion that this equilibrium point is not stable. While it is now seen (I hope) that it is stable.
Thank you very very much for all the help
