Landau, volume 1, chapter 1, problem 4: Lagrangian of a somewhat complex system
  • Thread starter Thread starter Rick16
The discussion clarifies how to derive the kinetic energy term from the squared displacement expression in Landau's Mechanics, volume 1, chapter 1, problem 4. Landau writes the squared displacement for mass m₁ as dl₁² = a² dθ² + a² sin²θ dφ², and the kinetic energy as T = ½ m₁ a² (θ̇² + sin²θ φ̇²). The key step is recognizing that velocity squared equals the time derivative of displacement squared, allowing substitution of dθ²/dt² = θ̇² and dφ²/dt² = φ̇². Neglecting infinitesimal cross terms is justified in the differential limit, confirming Landau’s compact expression is a direct route to the kinetic energy term from the metric form of displacement.
  • Understanding of Lagrangian mechanics and generalized coordinates
  • Familiarity with differential geometry concepts such as line elements and metric tensors
  • Proficiency in time derivatives and chain rule in calculus
  • Knowledge of Landau and Lifshitz’s "Mechanics" textbook notation and style
  • Study the derivation of kinetic energy from metric tensors in generalized coordinates
  • Explore the use of infinitesimal displacement vectors and their squares in classical mechanics
  • Review Landau and Lifshitz’s treatment of angular coordinates and spherical metrics
  • Practice converting differential line elements into velocity expressions for complex systems
Physics students and researchers working on classical mechanics problems involving generalized coordinates, especially those studying Landau and Lifshitz’s "Mechanics". This discussion benefits anyone needing to understand the connection between displacement metrics and kinetic energy expressions in Lagrangian formulations.
Rick16
TL;DR: find the Lagrangian of a somewhat complex system
This problem has been addressed before under https://www.physicsforums.com/threads/trouble-understanding-coordinates-for-the-lagrangian.1006528/ I also copied the following problem statement with Landau's very sketchy solution from this old post, because I don't have the English edition of the text.
The old thread only addressed the question of how to determine the coordinates of the masses. My problem is how to get the kinetic energy term from the displacement term. For one mass ##m_1## Landau writes the (square of its) displacement as ##dl_1^2=a^2d\theta^2+a^2sin^2\theta d\phi^2##. His kinetic energy term for this mass is ##\frac{1}{2}m_1a^2(\dot{\theta}^2+\dot{\phi}^2sin^2\theta)##. I don't know how he gets to this expression from his displacement term.
It seems easier not to lump together the displacement term into one expression right away, but to write the horizontal and vertical coordinates separately. I could then write (for ##m_1##): ##dy=ad\theta## and ##dx=asin\theta d\phi##. Then I take the derivatives ##\dot{y}=a\dot{\theta}## and ##\dot{x}=a\dot{\theta}cos\theta d\phi + a sin\theta \dot{\phi}##. If I now neglect the term ##a\dot{\theta}cos\theta d\phi## because of the infinitesimally small angle ##d\phi## I get Landau's result. Is it legitimate to do it like this? In any case, I don't understand why Landau immediately wrote the square of the displacement and what he did next. Is there a direct and easy way to get from the square of the displacement to the kinetic energy term?
I just thought about something. I am new to Landau and I am not familiar with his style. When he writes the displacement as ##dl_1^2 =a^2 d\theta^2 + a^2 sin^2 \theta d\phi^2##, perhaps this is not meant to be an intermediate step towards the final solution, but just a helpful statement?
@Rick16 This (square of the) displacement can be used to obtain the kinetic energy ##T = mv^2/2## because ##T## contains the square of the speed:
v^2 = \left(\frac{\text{d}l}{\text{d}t}\right)^2 = \frac{(\text{d}l)^2}{(\text{d}t)^2} \rm{.}
Then if, as is in your case, ##\text{d}l^2## contains a term like ##a^2\text{d}\theta^2##, you use above equation to compute
\frac{a^2\text{d}\theta^2}{(\text{d}t)^2} = a^2 \left(\frac{\text{d}\theta}{\text{d}t}\right)^2 = a^2 \dot{\theta}^2 \rm{,}
and the same goes for the other terms in your displacement ##\text{d}l^2##. So you see that finding the displacement can help you quickly write down the kinetic energy, because you may just replace things like ##\text{d}\theta^2## and ##\text{d}\phi^2## by ##\dot{\theta}^2## and ##\dot{\phi}^2##, etc., and now you know why.
This is very helpful, thanks a lot.
  • · Replies 21 ·
