Laplace equation in a square with mixed boundary conditions
The discussion focuses on solving the Laplace equation in a square with mixed boundary conditions, specifically where the left edge is maintained at temperature T=C2, the bottom edge at T=C1, and the top and right edges are insulated. Participants suggest breaking the problem into simpler components and utilizing the Heaviside step function to address the mixed boundary conditions. A proposed weak solution is T(x,y) = {C2 for x < y, C1 for x > y}. The use of separation of variables and Fourier series is discussed as a viable method for finding the solution.
  • Understanding of Laplace's equation and its applications in steady-state heat distribution
  • Familiarity with boundary conditions, particularly mixed boundary conditions
  • Knowledge of Fourier series and eigenfunctions in solving partial differential equations
  • Experience with the Heaviside step function and its role in piecewise functions
  • Study the application of the Heaviside step function in solving mixed boundary value problems
  • Learn about separation of variables in the context of Laplace's equation
  • Explore Fourier series and their use in solving partial differential equations
  • Investigate numerical methods for approximating solutions to Laplace's equation with complex boundary conditions
Mathematicians, physicists, and engineers working on heat transfer problems, particularly those dealing with mixed boundary conditions in two-dimensional domains.
samuelandjw
The length of the side of the square is a. The boundary conditions are the following:
(1) the left edge is kept at temperature T=C2
(2) the bottom edge is kept at temperature T=C1
(3) the top and right edges are perfectly insulated, that is \dfrac{\partial T}{\partial x}=0,\dfrac{\partial T}{\partial y}=0
Solve for T(x,y) in steady state.
The situation is described by the Laplace equation. It would be a bit difficult to directly solve for this problem since this is a mixed BC problem. I want to break it down into several (for example, two) problems that are easier to solve. So far I don't have any idea how to break it down, since the mixed BC makes it difficult to break down the problem. Does anybody have any suggestion?
Thanks.
What is the value of T(0,0) ( at the left bottom corner) ?
At the left edge T(0,y)=C2
At the bottom edge T(x,0)=C1
Hence T(0,0)=C2=C1 ?
Not really. IMHO, the value on the corner is not particularly important. And, C1 is not equal to C2.
Of course, I supposed that C1 and C2 are not equal.
My remark was about the wording of conditions (1) and (2) : These conditions are NOT for all the edge length : The corner must be excluded.
It is important to see that the solution will include the Heaviside step function.
Isn't it ?
Isn't it ?
Certainly
<br /> T(x,y) = \left\{ \begin{array}{r@{\quad}l}<br /> C_2 &amp; x &lt; y \\<br /> C_1 &amp; x &gt; y \\<br /> \end{array}\right.<br />
is a weak solution of Laplace's equation which satisfies the boundary conditions.
Is there a reason why you can't use separation of variables?
Actually, no: if F(x,y) is the solution of Laplace's equation in a unit square subject to F(x,0) = 1, F(0,y) = 0, \partial F/\partial x(1,y) = 0 and \partial F/\partial y(x,1) = 0 then the solution of the OP's problem is
<br /> T(x,y) = C_1F(x/a,y/a) + C_2F(y/a,x/a)<br />.
And to find F(x,y), let k_n = \frac{2n + 1}{2}\pi for n \geq 0 and use the eigenfunctions
<br /> f_n(x,y) = \sin(k_n x)Y_n(y)<br />
where
<br /> Y_n(y) = \cosh(k_ny) - \tanh(k_n)\sinh(k_ny).<br />
I think you can write the y-component solution as \cosh(k_n(a-y))
I think my real problem is:
when the boundary condition on the bottom edge is T(x,0)=f(x), BC on left edge is T(0,y)=0, BC on right and top edges are perfect insulation (suppose we don't care about the values on the four corners), is it correct to obtain the Fourier coefficients using b_n\cosh(k_n(a))=\int_0^a\sin(k_nx)f(x)dx, with k_n=(n+0.5)\pi.
The thing that bothers me is that the integration interval is not a multiple of the period of the basis function \sin(k_nx).
But mine has the advantage that Y(0) = 1 (although I could write it as \cosh(k_n(y-a))/\cosh(k_na))
with
k_n=(n+0.5)\pi
If you're integrating between 0 and a then k_n = (n+0.5)\pi/a and you're missing a factor of \int_0^a \sin^2(k_nx)\,\mathrm{d}x on the left hand side of the first equation, but yes.
Integrating
<br /> I = \int_0^a \sin(k_nx)\sin(k_mx)\,\mathrm{d}x<br />
by parts twice (differentiating the k_n part each time) gives
I = \frac{k_n^2}{k_m^2}I
so that I = 0 unless n = m, when
<br /> \int_0^a \sin^2(k_nx)\,\mathrm{d}x = <br /> \int_0^a \frac12(1 - \cos(2k_nx))\,\mathrm{d}x = <br /> \left[\frac12 x - \frac{1}{4k_n} \sin(2k_nx)\right]_0^a = \frac{a}{2}<br />
since 2k_n = (2n+1)\pi/a.
Just a general point: if X_k&#039;&#039; = -k^2X_k, k &gt; 0, then
<br /> \int_a^b X&#039;&#039;_k X_l\,\mathrm{d}x = [X_lX_k&#039;]_a^b - \int_a^b X_k&#039;X_l&#039;\,\mathrm{d}x <br /> = [X_lX_k&#039; - X_kX_l&#039;]_a^b + \int_a^b X_kX_l&#039;&#039;\,\mathrm{d}x<br />
so that
<br /> (l^2 - k^2) \int_a^b X_kX_l\,\mathrm{d}x = [X_lX_k&#039; - X_kX_l&#039;]_a^b<br />
so if k \neq k
<br /> \int_a^b X_kX_l\,\mathrm{d}x = \frac{[X_lX_k&#039; - X_kX_l&#039;]_a^b}{(l^2 - k^2)}<br />
Now if we require that, for all k, AX_k(a) + BX_k&#039;(a) = 0 with A^2 + B^2 \neq 0 and CX_k(b) + DX_k&#039;(b) = 0 with C^2 + D^2 \neq 0 then X_lX_k&#039; - X_kX_l&#039; vanishes at x = a and x = b and the functions X_k will be orthogonal with respect to the inner product
<br /> \int_a^b f(x)g(x)\,\mathrm{d}x.<br />
Calculating the determinant of a 2x2 matrix shows that if X_k \neq 0 then k must be chosen so that
<br /> (AC + BDk^2)\sin(k(b-a)) + (AD + BC)k\cos(k(b-a)) = 0<br />
Thanks.
The function u(x,y)= C2 for all x and y satisfies U(0)= C2 and u_x(1)+ u_y(1)= 0+ 0= 0. Let v= T- u Then nabla v= \nabla T= 0 while v(0, y)= C2- C2= 0 and v_x(1, y)= T_x(1, y)= 0[/tex].<br /> <br /> So let v(x,y)= \sum_{n=0}^\infty A_n(y) sin(n\pi x/a). The differential equation reduces to \sum_{n=0}^\infty A&amp;#039;&amp;#039;_n sin(n\pi x/a)- (n\pi/a)\sum_{n= 0}^\infty sin(n\pi x/a)= 0 which is the same as \sum_{n=0}^\infty (A&amp;#039;&amp;#039;_n- (n\pi/a)Asin(n\pi x/a) which is equivalent to A&amp;#039;&amp;#039;_n- (n\pi/a)A= 0 for all n. Once you have found the Fourier series for v, add u= C2 to get T(x, y).
Here are some additional thoughts on this problem:
For the specified boundary conditions,
T(x,y)= \frac{C1+C2}{2}-\frac{(C1-C2)}{2}G(x,y)
with
G(x,0) = -1
G(0,y) = +1
G(x,2a) = -1
G(2a,y) = +1
The second pair of boundary conditions, by symmetry, automatically guarantee that the zero flux boundary conditions at x = a and y = a are satisfied. In addition to these conditions, the value of the function G is zero along all the diagonals:
G(ζ,ζ) = 0
G(ζ,-ζ) = 0
Chet
This is a continuation of my previous post. The solution for the function G(x,y) is the analog of the solution to a specific fluid mechanics potential flow problem, and can be expressed analytically in terms of a doubly-infinite sum over an array of point sources and point sinks.
Instead of a single square of side 2a, imagine an infinite array of such squares placed adjacent to one another in the x-y plane, extending infinitely far in all directions. This forms a grid. Place identical point sources or a point sinks alternately at each of the corners of this grid. Fluid flows out of or into each of these point sources or sinks, respectively. The streamlines of the flow will be the lines of constant G in our problem, and the "stream function" values will be directly proportional to G. The stream function for the entire array of sources and sinks is just the sum of the stream functions for the individual sources and sinks. The stream function for an individual source or sink is simple to express analytically.
Chet
  • · Replies 22 ·
  • · Replies 16 ·
