Laplace transform as rotation. In what space?
mclaudt
Sorry for thumb terminology, I just would like to grasp the main idea, as a physicist, without unnecessary complications, associated with system of axioms and definitions.
Fourier transform can be seen as rotation of basis in space of all complex-valued functions from basis of delta-functions to a new basis of waves e^{i\omega t}.
Laplace transform can be seen as generalization of Fourier transform to complex frequencies. Is it correct to see the Laplace transform as a rotation of basis in space of complex-valued functions of complex argument, from delta-functions basis to a new basis of e^{(\alpha + i\beta) t}and, if it is so, what is the basis in that space, and why does summation go only along line (-\infty, +\infty) in direct transform and (\gamma - i\infty, \gamma + i\infty) in reverse transform?
There is also an operation known as Wick rotation, it is a candidate to interpret the interconnection between Fourier and Laplace, it could be interesting if they both constitute some beautiful scheme.
It seems that the key point is the analytical continuation. The raw form of Laplace transform is F(s) = \int_{ℂ}e^{-su}f(u)du, where f(u) is analytical continuation of f(t) to complex plane. And in that case the Laplace transform will be the rotation of basis in {f(u)} space of complex functions of complex argument, just as Fourier transform is the rotation of basis in {f(t)} space of complex functions of real argument, and integral is in both cases just a generalization of matrix multiplication to infinite dimension.
It's just guess, I'm not sure if it is correct to define F(s) that way.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
