Laplace transform heavyside function
elcotufa
find the transform of
[tex] sin (wt) u(t - b)[/tex]
I have to get it into the form for the time shift but I do not know how to deal with the unit function
help appreciated
The Laplace transform is defined as:
[tex]\mathcal{L}\lbrace f(t)\rbrace = \int_0^{\infty} e^{-st}f(t) dt[/tex]
Now, let's put in
[tex]f(t) = g(t) u(t-b)[/tex]
where u(t-b) is zero for t<b and 1 for t>b. Plugging this in:[tex]\int_0^{\infty} e^{-st}f(t) dt = \int_0^{\infty} e^{-st}g(t) u(t-b) dt[/tex]
Now split this integral into two parts:
[tex]\int_0^{\infty} e^{-st}g(t) u(t-b) dt = \int_0^{b} e^{-st}g(t) u(t-b) dt + \int_b^{\infty} e^{-st}g(t) u(t-b) dt[/tex]
The first integral vanishes, since u(t-b) is zero on the integration domain. In the second the u-function is simply 1. I'll let you solve the remaining steps.
ahhh cool
now let's say I have
[tex] (t-1)^4 u(t)[/tex]
function is 1 from 0 < t < 1 and [tex](t-1)^4[/tex] for t> 1
I can easily do the transform of t^4 how would i play with it to just do a time shift after the transform or do I have to go the integral route and do parts?
If you do not have to work it out from first principles (and I do not think you have to), you could do it by using this L-transform formula:
[tex]L[f(t-a)u(t-a)] = e^{-as}F(s) \text{ where F(s) is L.T. of } f(t)[/tex].
Of course in the case of [tex](t-1)^4 u(t)[/tex], it's not in a form which yields itself readily to that formula. In such a case you may have to work out the binomial expansion of (t-1)^4 before applying that formula.
