Laplace Transform of t cos(2t)
The Laplace Transform of the function f(t) = t cos(2t) can be computed using integration by parts. The discussion highlights the importance of splitting the integral correctly, suggesting the use of u = t e^(-st) and dv = cos(2t) for effective integration. The key takeaway is utilizing the property L[t f(t)] = -F'(s) and the known transform L[cos(2t)] = s / (s^2 + 4) for s > 0 to simplify the process. This approach allows for a more straightforward calculation of the Laplace Transform.
  • Understanding of Laplace Transforms and their properties
  • Familiarity with integration by parts technique
  • Knowledge of trigonometric functions and their transforms
  • Basic calculus skills, particularly in handling integrals
  • Study the derivation of the Laplace Transform for various functions
  • Learn advanced integration techniques, specifically integration by parts
  • Explore the application of Laplace Transforms in solving differential equations
  • Investigate the properties of Laplace Transforms, including linearity and shifting
Students studying engineering mathematics, particularly those focusing on differential equations and control systems, as well as educators teaching Laplace Transforms in calculus courses.
rhololkeolke
Find the Laplace Transform from the definition of f(t) = tcos(2t)
\int e^-^s^ttcos(2t)dt
I started by doing parts
u = t
du = dt
dv = cos(2t)e^-^s^t dt
but I get stuck on v and as far as I can tell doing parts on v won't help because neither term will be reduced when differentiated.
I'm looking for some direction on how to solve this integral.
Thanks!
You might try splitting it up differently. Try
\begin{align*}<br /> u &amp; = t e^{-st} \\<br /> dv &amp; = \cos 2t<br /> \end{align*}<br />
You'll have to integrate by parts at least twice.
Thanks. I was able to figure it out after starting with it split how you suggested.
A sneaky way is to use the fact that L[t f(t) ] = - F^{\prime}(s). You can use the fact that L[ \cos (2t) ] = \frac{s}{s^2 + 4} for s>0. This way you are taking a derivative instead of integrating!
