Laplace transform of unit step function
The discussion revolves around the Laplace transform of the unit step function, specifically focusing on the implications of using u(-t) in the context of the transform. Participants are exploring the behavior of the unit step function and its application in Laplace transforms.
  • Exploratory, Assumption checking
  • Participants are questioning the value of u(-t) and its implications for the Laplace transform, particularly whether it results in zero. There is also speculation about potential misunderstandings regarding the problem's notation or transcription.
There is an ongoing exploration of the problem, with participants providing insights into the definitions of the unit step function and its behavior under the Laplace transform. Some participants express uncertainty about the completeness of the problem statement and whether additional context or information is needed.
Participants note that the Laplace transform is defined for functions on the positive real numbers, which raises questions about the setup of the problem involving u(-t). There is a suggestion that the problem may involve a shift rather than a straightforward unit step function.
Icetray
I know that u(t) is a unit step function and holds a value of either 0 or 1. In laplace transform, when we integrate f(t) from 0 to infinity, we take u(t) to be 1.
In this case, since u(t) is u(-t), does this mean it holds a value of 0? Does not make sense to me that both answers are 0.
Thanks in advance for the help. :) Any links to notes on similar laplace transforms would be very much appreciated as well! :)
I don't understand what you want to do. The Laplace transform is defined only for functions on the positive real numbers. u(t) is 1 for [tex]0\le t\le 1[/tex], 0 otherwise. So u(-t) is 1 for [tex]-1\le t\le 0[/tex]. Since both of your x(t) is 0 for all positive t, their Laplace transform is 0.
Thank you so much for your reply Halls of Ivy! It's much appreciated.
The exact question is actually just "Find the Laplace transform of:". I apologize for leaving it out.
So just to confirm, the answers for both questions are actually 0? Seems a little weird that they've give us two questions on the same "concept".
Could it be possible that instead of a unit step function, it could be some sort of shift?
Once again, thank you so much! :)
Careful: the usual definition of the unit step function u(t) is
[tex]u(t) = \left\{ \begin{array}{cl}1 & \text{ if } t \geq 0\\<br /> 0 & \text{ if } t < 0.<br /> \end{array} \right.[/tex]
So, as said already, your functions are multiples of u(-t), so are 0 for t >= 0. Thus, their Laplace transforms are zero.
I agree. I would almost bet there is something missing or misunderstood about notation or transcription here. Have you copied the complete problem exactly, word for word?
Yups, that's all the question says. Nothing before that and no hints after that. :( I guess I'll just stick to 0 then.
Is it possible though that it could be a shifting problem instead of a unit step function?
